Mike's Alpine White 1991 318is
  • Tzantushka
    • Nov 2018
    • 389
    #781
    Awesome photos as usual.
    But the best part is watching you enjoy the car from afar.
    i.e. all the work you've done in the previous 19 pages of this thread are paying off - just turn the key & go.
    E30 320i vert
    But daily drive is Volvo V60 Polestar
    • mike.bmw
      • Dec 2015
      • 1745
      #782
      Thanks! That has been the goal - turn the key and go!
      • mike.bmw
        • Dec 2015
        • 1745
        #783
        Yesterday I replaced the alternator on my E30 318is. The only one I could find that wasn't in backorder was a reman unit from CarQuest, which happened to be what was already in the car for the last 7 years.
        Last year my 318is battery died due to a completely worn voltage regulator. So after replacing the VR and battery everything was good. The battery died in my wife's car recently, so I decided to recheck the charging voltage of the 318is. It was below 13, which prompted me to replace the alternator.
        The CarQuest replacement is garbage. The bolts holding the housing together were too long, one cracking the plastic that routes the wiring on the back. Another making contact with a power steering hose when installed. I transferred the good plastic from my old one and swapped the long bolts from old to new as well. The threaded holes in the new housing were all stripped, so I had to tap new threads and use new bolts.
        After a couple of hours of problem solving, the reman unit is installed and charging the battery at 14 volts. We'll file this under #vintageprep.
        2023-01-06_06-49-24 by mike.bevels, on Flickr
        2023-01-06_06-49-36 by mike.bevels, on Flickr
        2023-01-06_06-48-51 by mike.bevels, on Flickr
        2023-01-06_06-49-13 by mike.bevels, on Flickr
        2023-01-06_06-49-02 by mike.bevels, on Flickr
        2023-01-06_06-48-20 by mike.bevels, on Flickr
        2023-01-06_06-47-44 by mike.bevels, on Flickr
        2023-01-06_06-47-08 by mike.bevels, on Flickr
        2023-01-06_06-47-31 by mike.bevels, on Flickr​
        • mike.bmw
          • Dec 2015
          • 1745
          #784
          Yesterday I took my 318is for its first drive in weeks. What can I say, I've been busy with the E36 M3 sedan.
          This was the first drive since installing the new alternator, a CarQuest 90A remanufactured unit purchased through Advance Auto Parts. Things were going well until the new alternator start making horrible sounds and shooting sparking everywhere. Sparks like I was taking a grinder to metal. So, after calling Advance Auto Parts customer service to complain, I was transferred incorrectly THREE times, exponentially increasing my level of frustration.
          Removal only took 15 minutes this time around. I returned it to a local store, where the store manager was actually very nice. Given I have no other options, I rolled the dice and ordered another one which should arrive next week. In the meantime, I've ordered new alternator bracket bushings as the old ones are a little tired.
          I did manage to take some photos before the "new" alternator went south.
          DSC_0586 by mike.bevels, on Flickr
          DSC_0597 by mike.bevels, on Flickr
          DSC_0614 by mike.bevels, on Flickr
          DSC_0605 by mike.bevels, on Flickr
          DSC_0623 by mike.bevels, on Flickr
          • moatilliatta
            • 6119
            #785
            You'll be a veteran mechanic before you know it. I feel your pain!
            Ride looks great Mike!
            Do you still have the original Alternator? I find better luck finding an alternator / Starter repair shop that been around for a bit with an old dude to rebuild them
            @Zakspeed_US
            • mike.bmw
              • Dec 2015
              • 1745
              #786
              Thanks! Unfortunately the alternator being replaced is the same CarQuest make and model, not the original. This one lasted 8 years or so. Otherwise I would definitely get the original rebuilt!
              FCP Euro sells an 80A version, but I believe my car requires the 90A version. Though I don't know if it really matters or if the housings are any different.
              • roguetoaster
                • 7736
                #787
                You can get a Bosch reman AL0152X on ebay for ~$250, or an AC Delco 3341893 reman on Rockauto for ~$165 plus shipping. You may also simply try a new regulator 12311726022, which is about $20 for the Hella unit, on your original alternator.
                As to amperage, I think the 90a is for our typically equipped A/C cars, whereas it might be easy enough to find/use a 65a alternator on a more typically equipped Euro 318i with no fogs, no AC, and a very basic audio setup. An 80a might work, but running the AC, stereo, and all of the lights at night in summer might be a struggle to maintain battery charge.
                • mike.bmw
                  • Dec 2015
                  • 1745
                  #788
                  Thanks, roguetoaster! I didn't know these existed. The AC Delco unit looks identical to the CarQuest unit. The Bosch unit looks nice.
                  The second CarQuest alternator is being delivered today. When the new bushings arrive next week I'll install it. If it's DOA, I'll go with the Bosch AL0152X for round three.
                  The voltage regulator on the old unit is fairly new. I replaced it about a year ago as the original was worn down to nubs. So I think that's still working correctly, it's just a tired alternator.
                  • mike.bmw
                    • Dec 2015
                    • 1745
                    #789
                    Today I installed alternator number two. The second alternator came in MUCH better condition. No stripped threads. No broken pieces. It did have the extra long bolts, but I swapped those out quickly from my existing alternator. The plastic wiring guide was also different (but not broken), so I swapped that as well.
                    2023-01-17_07-57-04 by mike.bevels, on Flickr
                    I ordered new alternator bracket bushings, which arrived today. The old ones were quite past it. The alternator sits nicely (and securely) with the new bushings pressed in.
                    2023-01-17_07-49-31 by mike.bevels, on Flickr
                    2023-01-17_07-49-27 by mike.bevels, on Flickr
                    Bushings installed (the old ones just fell out):
                    2023-01-17_07-49-16 by mike.bevels, on Flickr
                    Here is the difference in the plastic wiring guide. The curved piece is what was installed on the previous alternator (and is what works):
                    2023-01-17_07-48-57 by mike.bevels, on Flickr
                    The new one even came with a new supressor installed, where as the last one did not. And some beauty shots...
                    2023-01-17_07-50-29 by mike.bevels, on Flickr
                    2023-01-17_07-54-05 by mike.bevels, on Flickr
                    And it's in:
                    2023-01-17_07-48-49 by mike.bevels, on Flickr
                    And it's charging (even better than the last one):
                    2023-01-17_07-48-36 by mike.bevels, on Flickr
                    Tomorrow I'll go for a drive. Fingers crossed it doesn't end in sparks like the last time.
                    2023-01-17_07-47-34 by mike.bevels, on Flickr
                    • econti
                      • May 2014
                      • 1082
                      #790
                      14.2 is quite high for a charge, if at that level consistently it will kill batteries
                      • mike.bmw
                        • Dec 2015
                        • 1745
                        #791
                        I think 14.2 volts is within spec. The voltage regulator is rated for 14V. Everything I've read indicates that when the car is running, the voltage at the battery should be between 13.8 and 14.2 volts.
                        • econti
                          • May 2014
                          • 1082
                          #792
                          Keep an eye on it, I've had motorcycles melt batteries at 14.5, which is not a fun experience
                          • monty23psk
                            • Mar 2008
                            • 1289
                            #793
                            This is right for all e30s. Just need to be above 14v for optimal charging but nothing above 14.5.
                            Alex 88 m5 | 91 318is | 19 Subaru Ascent
                            BMW Tool Rentals & Fender Roller
                            • mike.bmw
                              • Dec 2015
                              • 1745
                              #794
                              When worlds collide...
                              DSC_0588 by mike.bevels, on Flickr
                              DSC_0728 by mike.bevels, on Flickr
                              DSC_0621 by mike.bevels, on Flickr
                              DSC_0719 by mike.bevels, on Flickr
                              DSC_0711 by mike.bevels, on Flickr
                              DSC_0684 by mike.bevels, on Flickr
                              • moatilliatta
                                • 6119
                                #795
                                Pulled some film out? Cars are looking pretty joyful!
                                @Zakspeed_US
