good friggin job! it looks great!
e30mclow's e30 #14 - Now 1.5jz + 6 Speed
89 325i 4dr s52
02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
21' Toyota Tacoma TRD OR 4x4 6 speed Manual -
I got another little bit done on the weekend, which I now believe constitutes the "tipping point". By that I mean that from here on out, it is reassembly and instant gratification versus slow progress.
First I set about doing the stone chipping around the lower extents of the car. This is always a dead giveaway that an e30 has been messed with, as the texture is hard to match. With that, I did the front, back and sides all at once.
I then had to lap back over some of that with color and clear, before doing the lower details in black, which is how it would have been originally.
I'm very happy with it, especially as it used to look like this back there lol
I had forgotten about all of the fixes as it has been a year, but there was a lot in it over time
Another job I was pi55ed off with, that in the end only took an hour, was re-clearing the engine bay. I never thought that overspray could have infiltrated my masking, but it did, reducing the bay to a dull finish. It took longer to mask the car than it did to scuff and spray the bay this time.
Dullness
All masked up and then just dripping in lovely deep gloss
..and with all of that, the painting related tools and consumables are banished, and I can slowly start putting things back together
🥰 1👍 1Comment
U-Pol tintable Raptor Liner. Sprayed at 40psi (at the provided gun inlet), about 1-1.5' off of the panel, semi slow movement, one heavy-ish coat.
Be careful with overlap, or say sweeping half of a horizontal area at a time. This stuff stacks up so fast that you effectively need to blow past the panel at the ends rather than let go of the trigger. This means that the wall and your tools are going to get coated unless they're covered. You need to work/walk the length of the panel with each pass.Last edited by e30mclow; 10-13-2026, 07:50 AM.👍 1Comment
Oh nice, I've used raptor on a few projects. I have some flecks of it on my garage door from an accidental trigger pull! haha I was thinking of using the 3M schutz with my raptor gun but will probably have to play with the psi on a test board.
Things are less exciting here now as we enter the phase of putting things on and off. On, because they can go on now, off again, because they don't look nice enough.
Firstly I put the dashboard sound proofing back in after thoroughly scrubbing it. This was from the rat infested donor car and smelled accordingly. These are now $650+ from the dealer, so I'm glad I decided to keep the stinky thing.
That was followed by the now non-airbag column and modified pedal box.
I cut and welded the clutch pedal to move it over about an inch as I've always been annoyed by how my big goofy feet clip the brake pedal. Moving to a non-airbag column got rid of needless joints and telescopic sleeves, which all have play now due to age. Before putting it in I painted the column, as every car seems to come with rust there from factory, even now. I should be able to install the front subframe and rack soon, once I modify the UJ at the bottom of the column. I'm thinking of spacing the column down slightly to make the wheel a little lower in my lap.
Then things got incredibly detailed. Anyone that has sat in an e30 knows the heater blower fan either whistles, doesn't work, or blows air out anywhere but where it is needed. Well, down the rabbit hole I went. No exaggeration, this was less fun that swapping the roof over.
I took it completely apart and made cardboard templates of every piece of foam, then made those in closed cell foam of varying thicknesses (26-ish individual pieces). I also cleaned all wiring and rewrapped the harness - a taste of what is to come with the overall body harness
New AC core and heater core
There is a little flap deep in the box that I assume is to prevent blowing the seals out when you slam the door, This was remade using the old packaging from a box of screws. Niceeee
Putting it back together took a number of attempts, but in the end we have a 100% sealed unit. Running it on the bench, I could feel air coming out of the joints in the casing, so I went back over them with a thin skim of black sealant, which sorted it. The final piece was the only seal I couldn't replicate, which came from BMW.
I'm glad that is now absolutely perfect. It moves more air than I've ever seen in an e30, while also being silent.
I don't think I'll have the AC working in 2027, but will be putting things in place to run modern AC refrigerant etc. The pump is on the wrong side of the JZ engine so I need to either relocate it, or figure out how to make my own lines.
During the week I hope to cleanup the wiper linkage and motor, as it is easier to install that before the heater box. Then it is onto stripping the wiring harness and making a new one for the additional circuits that are needed.
☕ 1Comment
Another overdue dump of information from a local forum.
As mentioned a long time ago, I made the decision to skip a lot of the underside cleaning and painting to focus on the exterior while I had the weather. This left me with a very nice exterior and increasing paranoia about then spraying anything under the car and in the arches.
I ended using what was left of my 2k epoxy primer as a brush on application inside the inner arches. This covered the bare mental bits and seemed to really eat into the original coating. Before putting the suspension and such back on I'll need to circle back and brush on seam sealer over the repairs, but for now it is nicer to look at while working on it.
Now of course, everything going back on looks pure 5hit, so I gave up on cleaning my nuts and bolts and bought new from Tim's Classic Parts in Holland. These were then smuggled in from Ireland as my sister was visiting. Way, way cheaper than trying to piece it all together yourself.
With those, as well as the "good" bucket of scavenged hardware accumulated over the last 15 years, I think I'm set.
Before I could put the heater box in, I cleaned up and greased the wiper motor and mechanism. I went as far as painting it but never ended up with a photo.
Then began losing all of the skin on my fingers by stripping the harness of unnecessary wiring. I could have just left it and things would have just been left unplugged, but I'm a loser.
"Should only take a couple of hours" - 3 evenings later..
Note the shoes and socks (lack of) of a man who prioritizes car parts over clothing.
The entire harness is cleaned and rewrapped. I gutted a bunch of obsolete stuff and kept some things like the original ABS wiring, which based on the wiring diagram will be handy to repurpose later as it has a bunch of inputs I can use.
It all then had to fed in through a small hole in the bulkhead, which was far easier than when I had to take it all out.
Once in, I then chopped the harness in two where it heads for the front panel of the car. I removed some stuff and put in a nice weather proof socket, which will allow me to remove the front panel as a package, with lights, fans, and sensors all coming off with it. Banana for scale.
I'd then be telling fibs if I didn't find myself occasionally going into the garage just to stare into this corner of the boot. This was once the worst part of the car, and it is now oh so lovely and new looking..
The clips that hold the wiring harness to the inside of the sills are NLA, but I came up with a version that clips in easier, albeit you'd need to break them to get the wiring out ever again. Turned out great and had more room than the original ones, for extra wires.
Then came a task that I truly underestimated, making a harness for all of the new electronics.
Can you tell that it is my first time?
No matter how I tried, I couldn't make the secondary fuse/relay box work in the boot. There is just too much wire to fit through the car and the runs end up too long. It will now reside up in the engine bay across from the standard unit, despite it maybe looking a little busy.
Big ole horse of a connector that'll do pretty much everything, while still having another pair of white and blue circuits available if I need to expand. I ended up repining it to try and group the runs of wires as needed to the respective destinations.
Only one photo of the harness half done, which I may regret later when trying to diagnose something.
Some cool little details will be it'll have an OBD2 port for communicating with the e90 abs system..
As well as a simple and discreet two switch setup that'll allow me to turn off/on ABS on the fly. Same with the electronic brake assistance.
This way if the urge takes over to pull the hydro, left foot brake, or do a burnout, there is less of this:
That is how you find out that left foot braking with drastically assisted brakes isn't very good.
As I'm hoping to conclude most of the wiring rough-in over the next couple of weeks, I've started into the fueling, which obviously needs wiring run to it.
This was the old setup in the trunk.
Fine, but it was always on my mind that if there was a leak, the hot exhaust would be the next step for the fuel.
One of two $$$ boxes that arrived. I cannot fault the quality of this stuff, lovely machining and finish!
Like anything now, it is all the small things that add up. I'm continuously finding myself buying new fittings with every slight change in plan, and they start to get expensive.
I laid things out and set some bulkhead connectors in place through the floor, but they looked sort of lonely/vulnerable.
Therefore the 3D printer was fired up for the first time in months to make up something that looks nicer, while also holding them in place for Billy Nomates to tighten the lock nuts on the underside. Ideal
Then it was a story of making lines and such, while trying to squeeze the surge tank between the strut brace and rear firewall.
I put a Walbro 535lph e85 safe pump in the surge tank, which will be fed from the e30 tank by a 350lph pump, so it should be all sweet there.
I also made up a small pad for the tank to sit on level, as I had made a fold in the floor panel that time
The underside, which still needs to be tidied up after all of the plumbing is figured out, looks like this. The four lines just make it around the subframe/tank/trailing arms. I'll need to make a skid plate sort of thing to enclose it a bit.
I still have the inline filter to figure out, but it looks like it'll all fit in the stock location once done.
I gave in and bought a new tank because of a few dents, as they are only $350-380.
Naturally, after the fuel system is about 25% done it made sense to refurbish the electric aerial for no reason other than a shiny new mast came for it.
Then as a last motivator before leaving it for a while, I stuck one of the wheels on a bucket to see the paint against them for the first time. She is going to look awesome when finally together.
🥰 2👍 1Comment
Dude that is very cool and interesting project and good info, i like itComment
that's slick. i can't wait to setup my 3d printer and start learning how to make cool little parts like that. wheels look great against that color also!89 325i 4dr s52
21' Toyota Tacoma TRD OR 4x4 6 speed ManualComment
