(Post Crash Chassis Swap) Project Reincarnation / Project Beat Jason
  • max.rodriguezzz
    • Sep 2024
    • 78
    #46
    Now that the interior is in the reassembly stage, and its out of the car already, I decided I'm going to do a full refresh of the HVAC unit / heater box. So here's this -
    Untitled by Max Max Rodriguez, on Flickr
    I honestly didn't quite know what to expect with this one, in terms of teardown and reassembly. Back in the day I rebuild my entire sunroof system, no instructions, just worked slowly, analyzed how everything was put together, and just stayed mindful. It was a great play and worked well, so I just approached this one with that same kind of game plan and mindset. I know there are several videos of it online, of which I watched before taking on this process, but regardless I knew it was a project that I needed/wanted to do.
    I began by taking apart the major components - I removed the evaporator, heater core, blend door slider mechanisms, slider cables, blower motor cover, and blower motor itself.
    ​Untitled by Max Max Rodriguez, on Flickr
    after this it was time to begin splitting the case. Everything mounted to this case comes off before it can be fully split. That being, the blend door actuators, slider cables themselves, and some other brackets maybe?? honestly I kinda forget, its been a few weeks since and I'm too lazy to utilize my full brain power recall just exactly what. After that the case comes apart in 3 major pieces. The case goes together side by side (left/right) then one major piece on the bottom.
    ^ Bottom cover piece
    the slider for this section controls airflow to the foot vents I believe, its just one major blend door
    ^ the left/right case pieces
    The left/right case pieces slide together, and are held together with a total of 3 riveted plates, and 2 screws.
    These rivets need to be drilled out. I did this at my friends place, I nor he had any cutting lube, so I used cv axle grease, and it worked surprisingly well
    After this the 2 screws need to be removed. On late model heater boxes these fasteners are Philips head, on early models I believe these fasteners are actually torx head screws. These screws are buried deep in the case, a very long screw driver is required in order to remove them. I got a 12" screwdriver for this.
    here's a photo of it next to my foot for size comparison, I wear a size 8
    after this, the case can now be split apart.
    At this point the wiring harness can be removed, as it is routed in between a tunnel like thing in the blower motor area where the two sides piece together.
    In between doing all of this, the actual blend doors got removed. To remove them I just carefully pried the openings and finagled them out.
    Now it was time to clean the case, and scrape all the foam off of the doors. To clean everything I used soapy water, glass cleaner, razor blades, scrapers, flat heads, and some brushes
    The glass cleaner was very helpful for scraping away the flakey foam. Also I used the glass cleaner because I am a fan of the smell, hoping it would get rid of the 40 year old heater box mustiness.
    Here is a photo of everything cleaned
    Now its time to work on the refreshing. I pealed away the old tape, and rewrapped the wiring harness
    with friction tape
    I then lubricated all the slider cables
    Next I refreshed all of the foam for the blend doors. This step is kinda the whole point of tearing down the heater box. Fresh foam allows the blend doors to properly seal and resist any air from slipping past when closed. I used some neoprene adhesive backed foam from amazon (everyone uses this to refresh these it seems)
    At first I cut the foam the specific shape to fit
    this was a pain in the ass so I decided to try an do it this way -
    I did a few this way, however I thought it looked really dumb and low effort. I got ocd'd out and peeled all away then redid it the first way -
    I was cutting foam for like 2 hours and it fucking sucked. I was working on the floor and my lower back was screamingggg
    These 2 doors specifically were a pain to get out and put up hell of a fight. I wasn't comfortable with how difficult they were being, So I left them in the case. I ended up cleaning scraping, and refoaming them with them still in the case, and it sucked.
    now that all the new foam was complete, it's time to reassemble the case / whole unit
    At this point in the project it was late and I needed to go home. I wasn't able to leave everything at my friends house, which is where I began working at, so I needed to take everything and finish it in my room. This was the set up, the genuine working AND LIVING conditions for the next few days, lol -
    ok anyways, back to the reassembly. To connect the cases I used some silicone sealant, granted the "grommet" (its like a strip of rubber basically, noting special) seemed to be not damaged, but I figured it'd probably be worn from the years, so I left it in place and used the silicone sealant. It's only supposed to keep out air, and liquid if somehow ever it makes its way in to there
    When reassembling the side by side cases, theres a metal rod that is press fit into where the blend door meets the case. I cleaned it up with some steel wool to look pretty, and put a dab of assembly lube to make life easier when sliding them together.
    same type of deal with the silicone sealant for the bottom of the case
    To me, the reassembly was a bit of a puzzle. It was a lot of reassembly, inspect, make sure everything moves and functions, find a component I forgot / didn't realize its supposed to go on prior to last step, take apart, reassemble, repeat. One of those things was the slider arm for the food vent blend door. It has a little cut out in it, The cut out on the arm is supposed to sit PAST the case, not in the case. That little detail took me a bit to figure out, cuz at that point the case is so incomplete (in terms of reassembly) it was hard for me to catch that detail until things were put back together and the slider cable would only move like a fraction of a turn. Heres a pic -
    Another thing I messed up on skipping over was routing the wiring for the blower motor/resistor. As previously mentioned, there is like a little alley way for the wiring to go through, as well and many plastic pillars, which hold the connector in place in order to properly allows the resistor to effortlessly slide into place when servicing is needed.
    I spent so much fucking time and struggle attempting to pull the cases apart just enough to persuade the wiring and connector in place. All that struggling to avoid splitting the case and compromising the silicone again. I finally got it ! only to later find this piece-
    but where did it go? I had no fucking idea, so I did some diligent research, aaaannnnnddddddddd
    soooooo I split the case yet again
    Sliding the side by side parts of the case back together was a bit of a challenge, since there is a handful of things that needs to stay in place and make it into its designated spot on the other side of the case. Took a few attempts.
    Now time to reconnect it, used the long ahh screwdriver, and now was ready to re rivet it. As you can see here the riveted plate takes up for that bit of slack that is left over after the screws are fastened.
    but uuuh I realized I don't actually have a rivet gun, so yakwtfgo
    doesnt cost much to change your life
    Admittingly, I've never used a rivet gun, It was pretty straight forward tho.
    I got the top plate in
    then while doing the bottom plate, I got just a little bit too excited and forgot the actual plate it self
    so I drilled it out and corrected my wrong doings lol
    Ok, now to continue with refreshing everything, I got stuck paying money for some bullshit and was yet again victim to the bmw tax
    freshened up the foam for the vents too, as well as cleaned ALL of the vents that go behind the dashboard and carpet
    I harvested the slider mechanism off of the new cars heater box, because the fiber optic light for one of the sliders on the original unit had cracked off at one point in time, leaving the wire shorter than it was supposed to be, and as a result it would slip out of the holder for it, and leave one of the slider knobs not illuminated.
    There were a couple non crucial spots of plastic that ended up unfortunately cracking during the rebuild, so I took care of them with the good ole JB
    I also used my variable power supply to send 12v to the blend door actuators to confirm they are still working, and yes they are. no photos :(
    Lastly, I gave the whole thing a quick little "polish" with this stuff
    and that's basically it
    also I refreshed the foam for & reinstalled the evaporator and the heater core yadda yadda. I didn't replace the units because 1.) they worked fine before 2.) I saved hundreds of dollars not doing so and 3.) they are easy enough to access to replace while the unit is in the car if necessary.
    and... while bleeding the cooling system (spoiler alert) the blower motor itself was making a horrible noise. It did not make this noise before the crash, but after the crash and before the chassis teardown began, the blower motor was making that noise. At the time I had assumed it was a byproduct caused by the way the firewall crumpled. But after tearing down and reassembling the unit I saw absolutely no visual signs of physical damage. So my conclusion is that the impact of the collision caused the blower motor internals/bearings to take some damage. I decided I'll get a new blower motor when I have the $230 to spare. For now might harvest it out of the new cars heater box, or more realistically, once I realize that being in a car in the summer heat with no airflow is the same way that dogs die, I might fork it over. But now that I type this, I think the actual realistic outcome is I just get a new one whenever the ac system gets converted and working again.
    Till next time
    • Panici
      • Dec 2009
      • 2569
      #47
      Damn, that HVAC rebuild doesn't look like an easy job. But I guess while you're in there, might as well do it right.
      Originally posted by max.rodriguezzz
      do you have a build thread for your Miata? aside from being an e30 nerd, I love those cars. In the future, the next build I want to pour my soul into is a Miata
      Build Threads - [NA] Rescuing a 1990 Miata - This Sparks Joy! - - 1990 Mazda Miata Turbo [NA] Build Thread & Ownership LogIndex: Post 1-4: Purchase Story, New Floor, Mold Removal, New Wheels, Exhaust. Post 5-12: Paint Restoration, Custom Hood Paintjob, Hardtop, Autocross, Trackday. Post 13-14: More New Wheels, Second...
      Sadly it's been sitting outside for 2-3(?) years after the motor went. Have a spare 1.6L engine but it's pretty far down the list of things I need to get done. Eventually.
      • 2mAn
        Señior Mod
        • 21017
        #48
        Remind me to never rebuild my HVAC system LOL
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • JasonWilson48
          Not my real name
          • Jan 2025
          • 249
          #49
          Facts. I would rather eat that 30 year old crumbling foam then do this. This is some serious work. Also, I think this one post has more pictures than like my entire chassis swap thread. Serious time went into documenting this and drafting this post.
          Good job, Max. Feel like you should follow 2mAn and film yourself doing more of this stuff. Even if it isn't youtube, maybe you go Tik-tok instead. Like that one guy with the 2 supras who is building an Acura Integra (or similar) and making informative videos on Tik-Tok. Than suing whatever money he makes, and putting it back into the build. You could do it for the E30 if you have the desire or time.
          89' Build
          2009 Honda Element (Daily/Beater)
          • 2mAn
            Señior Mod
            • 21017
            #50
            ...and with those feet you could even start a OnlyFans
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • calvino
              • Feb 2025
              • 102
              #51
              Great updates Max!! I also refreshed my HVAC box, thought i was not brave enough to separate the halves. The recirc flap doors that you glued will crack again. The motors that drive them basically move them until they hit a hard stop and they sense the current spike. What this means in practice is every time the flaps close the plastic is really heavily stressed in that area. I superglued my flaps originally and they recracked. The Z3 HVAC system is very similar to the E30 and many of the parts cross over. You can harvest most parts from a Z3, which is handy because the parts are about 15 years newer. The recirc flaps on a z3 don't use the same ball stud that the e30 uses, so that part isn't cracked. you can easily drill it out and use a 6mm ball stud or ball nut from an RC car, which is what I did. I have also CAD modeled the recirc flaps but never actually tried to 3D print them, if you'd like to be the guinea pig let me know.
              z3 recirc flaps - it has extra tabs that the Z3 uses to actuate the flaps. Cut them off with side cutters.
              Drill out the hole and use a 6mm ball stud/ball nut for an RC car.
ID:	10162754​Click image for larger version
              • max.rodriguezzz
                • Sep 2024
                • 78
                #52
ID:	10162754Click image for larger version
                Oh wow that's fascinating. Good to know. Since I have to get in there again to do the blower motor, I'll probably get at it with the Z3 doors. I'd love to reach back out to you when that time comes, being the guinea pig for some 3d printed solutions sounds fun! Thankfully that area is accessible from the engine bay side, rather than removing the entire dash and heater box again!
                • max.rodriguezzz
                  • Sep 2024
                  • 78
                  #53
                  Alright here we go, another meaty update from the last few work weeks
                  The biggest challenge through all of this was that my buddy who has been letting me store and work on the cars at his place (which I am eternally grateful for) told me like, Yo I kinda need my space back. Which is totally understandable and valid. So... the pressure was on, and I kinda slacked getting photos because of this. sowwy >.<
                  After getting the heater box finished, the interior is ready to go back together. At this point the harness is in, but not fully routed, so I began with:
                  routing the wiring for the trunk
                  - tail lights
                  - trunk/license plate lights
                  - gas tank lock module
                  - antenna stuff
                  - 2 other modules near the antenna (tbh idk/forgot what they are)
                  - trunk lock module
                  (and uuh that's all I can remember while writing this)
                  - rear bumper lights
                  everything for the rear seat area
                  - defrosters
                  - 3rd brake light
                  - wheel speed sensors
                  - speedometer
                  - fuel pump / level sensors (this one is the whole reason why the tank needs to be dropped in order to do the harness)
                  - and everything else that goes through the grommet into the trunk
                  ​​​​​​Untitled by Max Max Rodriguez, on Flickr
                  After this I got the rear end underside finished up, that being:
                  - fuel tank back in, JasonWilson48 said awhile ago about how much of a PITA it was to put in with the subframe still in, so I was a little nervous. But tbh, it was a piece of cake for me ¯\_(ツ)_/¯. Hot take opinion but I honestly prefer working on the ground/jackstands/my back when it comes to large underside work because I find it easy and coinvent to use my legs and hips to lift and hold the things into place, and that way my hands are free to do the nuts and bolts.
                  while I was at it I took the time and effort to clean up the plastic pieces that cover the edged of the tank/fuel filter, as well as replace all fuel hoses and clamps.
                  fuel filter off the crashed car was recently replaced so I didn't bother replacing it.
                  While under there I noticed the filler neck hose was pretty hard and was starting to show some age and dry cracking. So, I ordered a new one. I was already in the reassembly stage, so I decided I'll swap it out whenever I take on refreshing the rear subframe in the near future.
                  Picture of the new hose-
                  Here's the notes I took when removing the tank, so I could use as minimal brain power as possible when hooking the lines back up
                  Only I understand my own madness
                  After that, I got the driveshaft in. I decided to use the driveshaft, csb, and guibo from the new car, as I didn't want to risk any possibility of using damaged components that coulda been caused from the impact of the crash, then needing to replace them later. The transmission ears had been reinforced, and in the crash both the trans mounts completely sheered in half.
                  I got the undersheilding and cross members in too
                  As well as reinstalled the god for saken exhaust. GENUIENLY FUCK INSTALLING THE EXHAUST. I've done it alone so many times (don't ask me how many times I've had to drop the transmission during my ownership) Every time I do so my will to live is slightly diminished. Two, Three, however many floor jacks it will still be hell.
                  The muffler end from the crashed car had always been rusted out, the muffler from the new car was obviously replaced at some point. SO, what I decided to do was use the downpipe and cat side from the crashed car (because I know that cat is healthy) and pair it with the non rusted out muffler side off the new car. And I will be saving the other exhaust system for future plans of which I will disclose later...
                  After this I swapped over the trunk lid, because the new cars trunk previously had some unknown wing on it, and the last owner didn't bother to patch or paint up the holes. Meaning, rust. ALSO my original trunk lid has the iS wing on it too sooooooo. Additionally, I swapped over the trunk lock too
                  I called up a second set of hands to help me swap the doors too, I did this because-
                  1.) overall better exterior condition
                  2.) they ACTUALLY have REAL door cards
                  3.) Door cards are already assembled
                  4.) Central locking did not work
                  5.) I get to keep the original locks and key :)
                  new car had a different key for the ignition and door locks. Also, if you recall from a previous thread post, that different key broke off in the ignition
                  ignition lock cylinder got swapped too
                  ​​​IMG_8493 by Max Max Rodriguez, on Flickr
                  ended up replacing the circlips that locked the pins to the hinges, because the original ones were hella ran through and stretched out when attempting to insert again ​​​ I just bought the variety pack from harbor freight. The new ones are tiiiiigghtttt ​​​
                  also I swapped over the quarter panel pop out windows, because, the ones off the crashed car did not have tint on them. Personally, I hate tinted windows, especially dark tint. Look at this bullshit-
                  Oh yea, funny thing to mention, back when I was on the mission of getting this thing home from NorCal to SoCal, I did most of the 7 hour drive with the windows down. I COULD NOT SEE SHIT out of this dark ass tint, at night, moving through the central valley wine country, downtown Sacramento, and through LA. ALL of my last 3 project cars have had shitty tint. THE LAST thing I want to do anymore is spend hours peeling off shitty tint that separates from the plastic film and leaving the dark adhesive on the window glass, AGAIN.
                  I picked and chose the best out of all of the window and rubber weather seals, now that I had two.
                  Now that the underside is buttoned up, and some misc items have been taken care of time to FINALLY continue with the interior.
                  Spent a surprising amount of time getting the wiring routed, and reviewing my reference photos... sitting on pinch welds HURTS
                  The I got the floor vents cleaned up (hose water, brush, and glass cleaner) and installed them
                  After this, got the good carpet from the crashed car installed. Its crazy how much this alone transformed the interior
                  After this, I played a little game of e30 pedal box... no fun. On my list of favorite things to do, its right next to reinstalling the exhaust
                  a few months ago I took the time and effort to refresh the pedal box. This included: the garagistic brass pedal bushings, Delrin throttle bushings, and aluminum throttle cable bushing. Along with this, I swapped over both the throttle and hood release cable from the crashed car, as those had been recently replaced too.
                  I took the master cylinder, stainless steel clutch line, and slave cylinder off the crashed car to use on this new one (again because recently replaced). While I was at it, I took the brake fluid reservoir, and line to the master too. BECAUSE whoever manual swapped the car cut the nipple on the fluid reservoir too short, so the line JUST EFFORTLESSLY FALLS OFF. Its So short not even a hose clamp could bite onto anything. Ridiculous IMO. Definetly not safe. Oh also, probably that same genius put the slave cylinder in upside down, most likely so the bleeder is easier to reach, but uuuuh the air...? Yea, good riddance.
                  While removing the fluid reservoir, some residual brake fluid landed on my PERFECT fuse box cover, and my water didn't neutralize it enough, Another fuse box cover victim to brake fluid </3 I have like three of them now
                  So, the brakes and clutch got a full flush and bleed, and so did my left eye... yes.
                  To continue moving forth with the interior- heater box in, dashboard in, wiring plugged in, and brackets for under dash modules in. I found a video on youtube of some dude over seas (Philippines I think) showing how and where all the brackets for the under dash modules go in. Talk about coinvent
                  I used the dashboard from the crashed car, because unlike the one off the new car, it does not look like a dried up pond in the desert. That being said, the VIN needed to be swapped over. I was excited to be able to have another opportunity to use my new awesome rivet gun, but harbor freight does not have plastic rivets small enough. So... uuuh... I used screws... It's funny because months/years ago I'd often make jokes about having the vin held in with Philips heads, and now I'm actually living it
                  LOL
                  Next, evaporator and heater core fins straightened, foam refreshed, and reinstalled
                  ok next, turn signals, gauge cluster and ecu in -
                  Now at this point, theoretically, the car is put back together enough to start, I give it a few long cranks and it runs!!
                  I went ahead and bled the cooling system, since it needed to be opened up for the harness and heater box removal. It took a along time for it to fully bleed, probably due to the heater core coming out, but it got done. this task proved that the car can solidly idle though!
                  And I got the front valence, bumper and iS lip back on, and all the wiring plugged in
                  Ok so now at this point the car is THEORETICALLY driveable. So I went ahead and installed the seats, and packed up all of my loot and spare parts that have been infuriating my buddy's space.
                  Way back in the day I thought I got a killer deal on a pair of $400 sport seats, but they are CHOPPED. The vinyl was rock solid and began cracking as soon after installing them. Also I figured it had the typical seat lean due to a blown seat shock, but no, the actual seat frame itself is rusted out and cracked. Resulting in the seat just infinitely fully reclined, like neck behind the B pillar, no matter how 90° the actual adjuster is. So, for the last 2 years or so I've had 2, 2x4 blocks of wood underneath the crack in the frame, and wedge between the adjuster gear, It worked enough for it to not recline, but the thing still wobbled like a mf, and had no adjustment abilities. I think this is probably why I got such bad whiplash in the accident, eek.
                  So I put one of the storage bins behind the seat to keep it at like 90° (I am kinda short and like sitting close to the pedals... don't judge)
                  some pics of how boof the seats are. Old phots, but duct tape can no longer save these -
                  that was 70lbs in coins btw
                  okok back to the car now,
                  so at this point it is drive able, all that is necessary for it to drive is hooked up, and the car runs and idles. I was having a weird issue with the turn signals and hazards. They were unresponsive and when activated, the flasher relay is just buzzing, then eventually the fuse blew. Electrical issue to sort out once the main goal is finished - get my buddy his space back. So, the car was now to be relocated to another friends house. I'm so grateful to have such rich friendships with such great people :) I had my friends escort me there - one in front, one in the rear, me in the middle, because no flashers.
                  since the sunroof had be disassembled awhile ago to analyze the rust, I did not have the time to put it back together, so the drive was completed with no sunroof
                  The car drives fine, and made it where it was supposed to -
                  Ok, the job is not over yet, the crashed car is still in my buddies space and needs to be prepped for (hopefully) sale.
                  This being, fully stripped of everything I want off of it, and engine/trans pulled.
                  and well,
                  Everything in this side yard has been cleaned up, organized, and most importantly swept. Doing my duties, and leaving the space cleaner than I found it. (Didn't get photos, but know it happened)
                  As for the original engine, I have plans...
                  You all will find out what they are sooner or later.
                  Now its time to focus on sorting out the electrical issues post harness swap, and get the care safe to drive.
                  what wasn't working:
                  - turn signals
                  - hazards
                  - flasher relay just buzzing
                  - brake lights always on
                  - windows not working
                  - electric mirrors not working
                  - central locking not working
                  I began with the flasher relay, figured it probably fail. It was cheap enough, so I ordered up a new one
                  Got it plugged in and unfortunately, it was not that simple. Time for real electrical diag.
                  when the issue is eelctrical by Max Max Rodriguez, on Flickr
                  I forgot my back probe kit at home, so I had to come up with this solution-
                  I began by testing the flasher circuit in sections, unplug, and test between that section for a short straight to ground.
                  I was not coming up with any real hard evidence of a short to ground between the sections of the turn signal stalk, turn signal stalk wiring, flasher relay, hazard switch wiring, and fuse box. It was at this point where my mid level electrical diag skills were beginning to dwindle, and ,my brain needed to operate more primitively -
                  this was done in an attempt to rule out the possibility of a short from the direct turn signals themselves, to the bulkhead connector near the steering column area. And well, after a good like 2 hours, I found the issue... the flasher relay itself was plugged in wrong -_-
                  keep it simple stupid... shoulda started there
                  ok well now the flashers work so yay.
                  onto the next item of business, the windows. For this diag, I decided to go straight in for the kill and send 12V directly to the regulator
                  and well the window worked, so its not the regulator. So I began with checking for voltage at the connector itself
                  e30 door pin out by Max Max Rodriguez, on Flickr
                  it was there.. so what was wrong? my findings was that the c404 / c405 connector itself was not fully getting plugged in. The cutout in the doorsill for it was pried open by one of the last owner (fucking how?)and had some rust. So what I did awhile ago was bent it back as best as I could, rust reformer, and seam sealant (because metal was splitting). What ended up happening was that the thin layer of sealant was just not quite allowing the connector to fully clip together, After trimming down some of the sealant and getting the connector to clip together, that then fixed the issues with the windows, mirrors, and central locking.
                  While the door card was off, I used some of the 3m spray adhesive to get the corner of door card vinyl in place again, from where some stables had fallen out
                  Issues with the license plate and trunk lights was due to the female end spade connectors making contact with the trunk lid panel and shorting to ground, because the load was not plugged in, lol
                  As for the brake lights always being on, the switch just wasn't adjusted properly, easy win there.
                  My collection of blown fuses from the day-
                  Well now all of the electrical issues have been solved! and the interior was more put together. that being:
                  - rear seats
                  - center console
                  Now, time to
                  1.) FINALLY wash the car
                  and
                  2.) take it for a real, longer shakedown drive
                  For the actual shakedown drive, It was a long one like 1 hour plus. Everything was going fine and working how it should. I was having some fun with the car and doing some fun pulls. I love my ecu chip. But remember the sun roof? Yeah, well, I had a 2x4 placed securely in the rear of the tray. This was done so in an attempt to hold the sunroof in what would be the "tilt" position. In hopes that aerodynamically, the sunroof does not lift. And also remember how I said the drive was long? Well I kinda got too focused on driving and enjoying the car, I forgot to stay mindful of the sunroof panel. While driving I hit a BIG ASS bump in the road, I hear the tires rub, then wind noise... I then look up, and just see the night sky... So what I can logically conclude happened was that hitting the bump disrupted the sunroof panels resting position, causing it to lift a little, air getting underneath it, then the panel itself becoming airborne, and FLYING off the car. I had to turn around and retrieve it from the middle of the road. When it landed and hit the ground, the corner of the panel got pretty badly bent. It's a bummer because my biggest lust for life is the sunroof, but I can't be too upset, because at least it happened in a really funny way. Unfortunately, the sunroof panel the car came with was entirely rusted out, so this panel that took the damage was the good one off the crashed car. Now, I gotta add "get a new sunroof panel" to the list
                  As for what's next for the car:
                  - finish/FULLY put together interior
                  - Reinstall sound system
                  - address sunroof
                  Then, I think I want to focus on the cosmetics, try and make the car look pretty and less ugly
                  - paint correction
                  - body work
                  - repaint plastic trims
                  - replace broken impact strips
                  - fix broken headlights (get depos)
                  - replace burnt out bulbs
                  potentially:
                  - reupholster seats (time consuming, and expensive, so we'll see)
                  Until the next update, most of my time will be spent here-
                  enjoy this silly photo
                  • calvino
                    • Feb 2025
                    • 102
                    #54
                    Great updates Max!!
                    • JasonWilson48
                      Not my real name
                      • Jan 2025
                      • 249
                      #55
                      I could only turn the box wrench like 1/8 of a turn at a time, and kept dropping it. Probably just a skill issue on my end.
                      89' Build
                      • Panici
                        • Dec 2009
                        • 2569
                        #56
                        And it's on the road!
                        Sorry about the flying sunroof panel, reminds me of the first fast & the furious movie and the Supra roof panel.
                        • evrgrn
                          • Oct 2024
                          • 32
                          #57
                          Nice work dude! How did you get the ignition tumbler out?
                          • mmoyer11
                            • May 2015
                            • 205
                            #58
                            Wow…such inspiration and realization I’ll never be this technically inclined. My stomach started to turn in the AC rebuild section. For a second I got fired up to finally figure out AC in my car and then just slowly lost hope…well done!!
                            • max.rodriguezzz
                              • Sep 2024
                              • 78
                              #59
                              Right now I’m typing this as I’m on an airplane to Missouri to go visit my mom and my dog.
                              It’s been about a little over a month since the last update, so here’s literally everything!
                              From where the last update left off, the car had been relocated to another friends house, electrical faults were solved, and my sunroof went airborne haha.
                              Rather than going in chronological order, I think I’m going to do this update by category (if that makes sense)
                              I’ll start with the least significant then end off with the most significant-
                              Quest #1 - Finish Where I left off / Make the Car Look Less Chopped
                              To finish where I left off, I need to finish fully reassemble the interior. To begin, I chose to swap the power cables that go from the battery in the trunk, to the engine bay. I chose to do that because the current power cables had lots of corrosion, and a non factory crimp connector done to it, and better condition power cables were at my finger tips, so why not right?
                              Next I harvested some of the OEM engine bay sound deadening foam sheet things and swapped those over. The ones the cart currently had were all ripped up AND one of the previous owners had tried re-adhesion them by using COPPER COLORED RTV gasket maker.
                              After this I got the trunk carpets back in place, and worked on putting the sound system back together.
                              I re ran all of my speaker wire from the speakers to the trunk. I got the wiring for my sub, amp, and head unit hooked up:
                              (I think It’s like 8 gauge) 30 amp fused power wires off the battery -> amp & sub -> rca cables -> 12v to rca adapter -> head unit, then the speaker wire off the amp feeding the speakers. Something like that, I put the system together like over a year ago.
                              To go along with this, while the back seats were out again, I did more kilamat sound deadening on the rear seat and parcel shelf area, got those reinstalled as well, and the speakers back into place, rear door cards got in, the oh-shit handles, and the speakers covers for the front foot wells too.
                              For the glove box, in the crash the, the way the firewall buckled cause the glovebox to get all cracked. As for the glove box on the new car, idk exactly what the last owner did, but they did some bullshit with self tapping screws and the hinge. I don’t quite remember exactly, but just know that it was dumb and really stupid and it pissed me off. So I fixed that, and I also swapped the locks so that the original key now works with ALL the locks on the car.
                              If my memory serves me correctly, the interior is fully put back together, except for the headliner. This is because the sunroof rust still needs to be addressed…
                              Quest #2 - The Journey For Space
                              So, the new car is out of my buddies side yard, but my engine and crashed shell remain, and had remained… for, awhile. I finally got the hint he wanted it out. With the huge overlying challenge of me not having a garage (or really any car/car part storage space) at my apartment, I needed to figure something out.
                              Here’s where things get a little dramatic…
                              Basically I texted my landlord and he gave me the green light to be able to store my engine in the garage, alongside all of his random loot he has shoved away in there. The catch was that he was out of town until July 10th, and at this time it was like early June, so he wouldn’t really be able to make space for me to store it until after then. Not really a problem tho cuz I had no plan of getting started working on it right away. So, I got the engine, crane, and stand loaded up into my buddies truck, and began transporting. Made it to my place and got everything off loaded, when it came to mounting it on the stand, we ran into a few issues. First the flywheel was still on and I left my tool bag at his house, so SOL there. Second the engine stand we brought was too wide to fit where it needed to go. Third, there was a padlock on the garage door so I couldn’t drop it in there. So, our solution was to use the emergency bald 200tw summer tire that wreaked of rat piss, and set it on there and cover it with a tarp for the time being.
                              I figured it’d be no problem to set it in front of the garage door- right between my landlords car (THAT LITERALLY NEVER HAS MOVED) because only he uses that garage and he’s gone for like a whole month. So things are good for a few days, and some stress is off my shoulders. Until literally like 3 days later. I get a phone call at work one night from a random number. I don’t usually answer but something in me made me feel like I should. On the other end it’s some lady, she know my name and everything and is asking if I remember her. I’m using literally every ounce of brain power I have to recall, and eventually I’m like “I’m gunna be so honest I have absolutely no clue who you are I'm sorry” Anyways, she tells me she lives in the unit behind mine and is giving me hella attitude saying how whatever I have in front of the garage door is a problem. She’s telling me I need to move it (not asking) She’s all sassy and is telling me how it’s extremely heavy and asking how I’m planning to move it, I explain to her the process yadda yadda blah blah. Basically she’s tripping out because she tells me she’s going to be selling a dirt bike in a few minutes (it’s literally like 8pm on a Tuesday) and she’s saying how I’m ruining her plans. I tell her how I asked the landlord if I could store it here in the garage and he said yes blah blah, then this lady literally says to me “ugh I wish you would of told me” (I’ve literally known about her existence for like 5 minutes) ANYWAYS, I’m very apologetic and communicative and apologize for inconvencing her, AND I explained how I was unaware other people WHO DONT LIVE IN MY APARTMENT UNIT USE THE GARAGE, and that I was under the impression that it was only my landlord, and since he’s gone on his trip there would be no reason for the garage door to be accessible. Anyways, I call some friends and tell them what’s up and one of them is available to help me get it moved and mounted the next morning. So I tell the lady that and get it taken care of and now all is well. Also for the record my landlord didn’t really give a shit he just asked me if I was able to move it. Anyways, idk where her entitlement is from but whatever and I keep moving on. Drama saga over
                              Needless to say that stressed me out a bit. Then like a few days later my buddy who’s house the crashed shell has been at was like - yo I have family coming over this needs to get out here in like the next 2 days. So once again I’m stressed the fuck out and don’t really have anywhere for it to go. But yet once again I am so thankful for my amazing and generous friends. One of my really close friends who lives only a few houses up offered to let me store it in her backyard, so after expressing my endless gratitude we make the plans to get it moved. We ended up towing it up the street with my buddy’s truck, I sold the steering wheel off the shell so we borrowed it from the other car. Pretty ghetto but the we got it moved. Spent a few hours helping him sweep and scrub that side yard and thanked him endlessly for letting me store it and work on it there for so long.
                              Ok so now the engine and the shell is secured in safe places, I’m starting to get really sick of my storage bins and all the car loot I’m storing in my room, the (quote on quote) backyard, and at some
                              Friends houses. So, I end up getting a storage unit, it get everything (besides the windshields) moved in and all my loot from everywhere else it’s been being stored at and into that unit. It’s generally such a relief to live in a room without constantly being reminded of the headache this e30 project has been. Stress levels have dropped drastically needless to say.
                              I packed the shit out of my civic and it took like 3 or 4 trips
                              (flywheel on the ground near the pedals because no where else for it to fit lol)
                              This section may not have been that necessary to add, but I feel like the lack of my own work space has been one of the biggest challenges throughout this whole project, so that made it worth it
                              Quest #3 - Save The Sunroof:
                              I was able to pick up a new sunroof panel off marketplace. To make that score even better, the dude was less than 10 minutes from me, the panel was rust free, it was only 100 bucks AND he gave me the sliders, adjusters, cables and everything FOR FREE… score. The panel had been sanded down and painted with primer so unfortunately not color match but hey, you can only win so much
                              So after some throuugh analysis of the sunroof rust on the actual chassis, it appears the worst of the rust is the actual cassette tray itself. So I did some research and learned how to remove it from the unibody of the car. I spend a few hours and got it removed from the crashed shell. I used a spot weld drill bit, angle grinder, couple scrapers, a heat gun, and lots of patients. I then got on to cleaning up some little surface rust that the good tray has. I don't feel like explaining it, but here, something like this -
                              One item that many builders leave in place on a Spec E30 is the sunroof cassette. Reasons vary as to why, but it’s a component that legally can be removed and it carries mass high up in the roof, so it’s well worth the time to remove to help maximize the car’s on-track potential. The […]
                              This is "the good" tray. I wire wheeled down the rust and sprayed the entire top side with some rust reformer just for good measure ^
                              Ok now for the most daunting task, do this removal on the new car, AND the installation. To start off I began by removing the front seats and back seats. I used plastic wrap for the windows and doors and a very large moving blanket for the ground. I masked off the entire inside of the car to keep debris as contained and possible. Please do not undermine how FUCKING HOT the inside of this bitch got, summer heat, plus sunlight, plus black car. On the removal on the first tray I used a variation of Dremel cut off wheels and my 5.5 inch angle grinder blade. The dremel just took way too long and the cut off wheels kept breaking, but for my first attempt at removal I’d rather take the long and delicate way. For the second removal I used the angle grinder, way faster. However I found the 4.5 inch cut off wheels to be too short/clunky, so I got some 6 inch cut off wheels to help out. The separation of the tray and the seam sealant is nothing but a game of delicacy and patience. I used a heat gun and scrapers and a 90° crow car with a filed down tip for a thinner and sharper wedge. I was extra careful not to warp the roof skin with the prying. On the first removal I didn’t care as much since it was the crashed chassis, but this one, I was far more careful. Some of the tray rust bled over into the actual unibody chassis, that being the inner part of the sunroof hole. Thankfully it wasn’t fully rotted out yet, so I just wire wheel and rust reformed it. After several hours of this, I finally got the tray out, and behold, lots of surface rust in the actual roof (which I had know but didn’t know how much)
                              that surface rust went all the way around the perimeter of the tray, even above the front windshield.
                              ^ the rotted tray
                              And, then an abomination ...
                              To break it down a bit to just exactly what this site is, there was a rot hole through the actual roof. Someone along the way tried to do some type of repair. They did absolutely no delegation of the rust, and to patch the hole the used either unmixed or extremely poorly mixed bondo, and a collection of screws, nuts, and lag bolts to act as like some sore of mass filler I guess ? (Yes that’s how much bondo there was) and to enclose everything together they used like a sheet of metal, they drilled screws THROUGH the bondo to hold that metal plate up. Truly creative I won’t lie. So after this very encouraging discovery, we realized we needed to actually do cut and weld rust repair, Which neither of us have experience doing. So I rip all that bondo out, and cut that rot section out of the roof. The plan is to get some steel from Home Depot, cut, and my friend welds. For the record, he’s able to weld, but isn’t by any means experienced. So part of why he was so down to help me with this whole sunroof cassette swap 1.) because he's a wonderful friend, 2.) to get the experience. Up until this point so far the whole sunroof tray swap has taken about like 2 weeks and like 2 or 3 actual work days. For the days at a time when the car was parked with holes in the roof, it was just wrapped up in plastic and duct tape to the roof. So I gotta clean hella residue off the paint, that adhesive has just been baking in the socal sun haha.
                              Anyways, pressure is on because time is ticking. And why is time ticking you may ask? His family is pretty interested in getting this car no longer parked infront of their house/on their street (I don't blame them), and I have a flight coming up. I was going to be in Oregon visiting my sister for a week.
                              Now the pressure is on- I fly out in 1 day, and we both have work. I’m done at 4pm, he’s done 6pm, AND a week prior I agreed to pick my friend up from the airport that night at 8pm. So, the plan- I go straight from work to his house (45ish minute drive), get everything prepped, and rot hole replacement cut and ready, I go to lax to pick up my friend, and he welds while I go. LUCKILY his flight got delayed till about 11pm. So we are able to get it all done before we left to pick him up.
                              I began by wire wheeling down the abundance of surface rust, I end up spraying the entire inside roof with about 3 coats of rust reformer. Next I cut the steel, and prep the area, then it gets welded up and covered with primer. Yes it needs bondo and paint work and bodywork, but that’s to come later, priority was to get the sunroof taken care of.
                              Next it’s finally cassette tray time. Prep the surface, and prep the tray. The cassette slider rails are mounted with some super tacky adhesive tape or something, I didn’t have anything to replicate that, so I ended up using permatex “the right stuff”. I chose to use this because it dries as silicone, and comes off all as one piece, unlike standard RTV where you have to scrape a bunch. Hopefully these rails will never have to come off, but never say never I guess. For the adhesion that the seam sealant did, I bought some actual seam sealant to use... Amazon seam sealant ¯\_(ツ)_/¯
                              For the install of the tray, the plan was to apply seam sealer to the tray, crawl in the car, hold it in place, use a few ratchet straps to keep said tray held in place, weld, done… IMMEDIATELY the plan failed when I struggled to crawl into the car with the tray and dropped it on myself. LOL. I was holding the tray in place and after about 5 minutes of positioning I realized this shit was starting to feel heavier and heavier than it did like 6 minutes ago, and my arms were getting weaker and weaker, and the tray was getting lower and lower. The tray is too rear heavy, so the ratchet strap idea did not work. So the solution I came up with, I lay on my back in the back bench seat area, and hold the tray in place with my feet and legs, and it worked phenomenally, however… When welding, the sparks and hot ass slag is flying everywhere and shit, my friend is wearing the proper PPE, long sleeves, face mask and everything, but me... Me on the other hand, I’m in my work kitchen uniform, and my gooch and taint is practically spread eagle, since I'm on my back holding it up with my feet. The slag and hot shit is just falling all on my bare arms, my shirt, AND MY GOOCH. I had no other option but to close my eyes and take that shit like a champ. My arms end up getting some little burns and little burn holes in my work shirt, I’m COVERED in seam sealant, rust dust, wire wheel wires, and lots of sweat. At the end of the day, to me it’s super funny. but alas NOW THE SUNFROOF TRAY IS WELED IN PLACE!
                              And yes we made it to LAX to pick up my friend, and yes the bmw is FINALLY back home at my place for the FIRST time since I bought it back in like March.
                              My time in Oregon comes and goes,
                              Once I get home from visiting, I get the sunroof mechanism reassembled, sliders all lubed up and everything.
                              Ended up somehow how losing this tip piece, so I took if off one of the spare units I had.
                              After getting everything back together, the actual sunroof panel will not sit flush. And it appears, there’s a dip in the roof right at the end where it meets the panel. That has always been there, even before welding. I suspect at some point in time someone stood on the roof right there and bent it down a bit.
                              A few weeks later, I decide to try and finished things up with the sunroof. I tried to use some heat and try and push it back into place, Nothing changed. Also, I took the whole mechanism apart again to try and figure out a few things-
                              1.) the manual crank mechanism does not "click" when it reaches the positions - fully back, tilt, and fully closed.
                              - What I found was that the crank mechanism is hitting the click when the sliders are in the fully open position, and getting the click about HALF way on the way back into place after being in the fully open position. No kind of click in the tilt or fully closed. To be totally honest I'm not quite sure what is wrong. ? The gear mechanism seems to be fully intact and nothing looks visually wrong? The sunroof mechanism has full mobility and bale to hit all positions, just no click. So for right now with this one I'm honestly kinda stumped
                              2.) Try and figure out why the panel cannot sit flush in the corners
                              - what I found was that no matter how much I adjust the height of the panel, the corners cannot line up. One corner will be flush, the other corner will be off, or vise versa. Also to address the dip- I used a straight edge and measured the dip, its about 1mm, so I do not think that is reason to why the corners cant sit flush. What I'm suspecting... is that the tray wasn't welded in perfectly. because Granted, we were on a huge time crunch, rushed, and working in the dark. So I'm pretty sure it'll have to come out again and get rewelded in. UGH.
                              As mush as I want this sunroof debacle to be over, the story persists
                              Also I gotta get new drain hoses and reinstall them too.
                              Now some miscellaneous stuff-
                              got my fire extinguisher finally mounted, rather than stashed in the trunk, like it’s been the last few years
                              My door locks and windows fully seized for few days, ended up being a bad connection at the door bulkhead plug
                              I got the engine torn down and the bore measured, for… reasons…
                              Been driving the car to work recently, mainly because my Honda was out of gas
                              My old Power steering pump went out on me, and the one the car had came with was already shot... so thats sick
                              Hopefully I can get the headliner installed and interior squared away soon.
                              My throttle cable / pedal FELL APART on me while driving one night. The bushing that goes from the j-hook into the pedal assembly is super gummy for some reason and just fell out. I need a new one
                              Got a handful of body work to learn and do next
                              Admittedly I got super tired of making this car my life, and stressing about it. After things got mellowed out, I took a good like 2 or so weeks off of working on it. And now that things are even more mellowed out and it’s back at my place with me, my goal is to put enough attention into the car where progress is continuously moving forward, yet stress levels remain low, and not let it consume ALL of my free time.
                              Anyways, heres some interesting side quests as of lately-
                              Missouri:
                              city mouse hits the midwest
                              My friends miata:
                              https://youtube.com/shorts/JQFPv61hfAQ?feature=share After getting to drive my friends, like actually drive it, through the canyons and stuff, I'm a miata believer now, I understand the hype. So much fun
                              Silliness:
                              - redo sunroof tray
                              - get sunroof properly sorted
                              - learn/do body work for the weld patch
                              - rattle can paint work
                              - get a headliner
                              - install said headliner, while that's going install the new windshield glass too
                              and then go from there. One thing at a time I guess
                              • Panici
                                • Dec 2009
                                • 2569
                                #60
                                Great update!
                                Big job with the sunroof replacement. Did you get it all sealed up and waterproof?
