Absorbantnut's '87 325is
  • TimKninja
    • 2131
    #166
    I cant even imagine dude. All that paint wasted . And time.
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • AbsorbantNut
      Non faccio funzionare questa merda
      • Jun 2010
      • 2491
      #167
      Well we only did 1 1/2 coats all said and done. I still have a whole gallon of paint:p So things will either be fixed later on, or I'll sell the paint & recoupe my losses.
      As a mini update I installed solid motor mounts, transmission mounts, and offset CABs from my man Carlos(silence);) I have a solid diff mount ready to go in as well, but I'm waiting to do all the rear end as one item. Trailing arm bushings, subframe bushings, and the sorts. I also have a new center support bearing for the driveshaft ready to go in when I get enough time. Having a job is quite a blessing:)
      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      • squidmaster
        • Aug 2011
        • 2666
        #168
        You're investing a lot in this so far, and it looks great. The paint color is perfect, and what I've been thinking about doing. Can I hire you guys for a job? (seriously)
        It seems like FL cars are never a just build, it's mostly a restoration.
        • AbsorbantNut
          • Jun 2010
          • 2491
          #169
          Hahaha, I'd love to help out, what did you have in mind?
          Wiring in some trunk lights and such today. I got some rear 4" 600lb springs from einstein57 on here yesterday, he's a fantastic business man! I made the order late monday night, and he shipped them across the country with priority mail at no extra charge. Products arrived and look great! I would gladly do business with him again.
          I have the rear adjusters, top hats, and springs in, and it's low! I need to raise it up a tad more because my exhaust lays on the ground :( No exhaust hangers FTL
          I'm going to the Towers meet tonite in SFL, so hopefully I'll see some of you e30 nuts out there!
          • squidmaster
            • Aug 2011
            • 2666
            #170
            Just a spray! I'll buy the paint, do all the prep, whatever, just need someone to spray the car. Probably the same color or a brighter silver. Maybe white... but white is played out, right?
            • AbsorbantNut
              • Jun 2010
              • 2491
              #171
              Hahahaha, I'd rather you spray the car. Ill help out with everything else :) White would be the best to spray it in, light colors in general, because they hide imperfections;)
              • squidmaster
                • Aug 2011
                • 2666
                #172
                But the car is a faded blue, so the engine bay and everything else would look like poop.
                I'd be down to spray it myself, it's just a beater DD and the paint isn't a huge issue to me, but I've never done it, and I don't have the equipment :(
                • AbsorbantNut
                  • Jun 2010
                  • 2491
                  #173
                  Well I've dropped a fairly large chunk of money on an e30tech adjustable camber/toe kit for the rear subframe, hopefully I'll recoupe my losses in the amount of money I'll be saving on tires! Other than that I touched up a few black paint areas, wired & installed the front turnsignals after a few run-ins with the local police......and thats about all! I need to order my front & rear crankshaft seal and an oil pump seal next time I get some scratch.
                  • RedDefiance
                    • Mar 2012
                    • 41
                    #174
                    nice!
                    My VW build page - http://forums.vwvortex.com/showthrea...ic-intensive-)
                    SELL ME YOUR E30 IN ARIZONA!!
                    • AbsorbantNut
                      • Jun 2010
                      • 2491
                      #175
                      Took some terrible pictures, but it shows the car in its current state, figured I'd throw them up :p
                      Almost forgot to mention, my friend Ben tuned the car for me! It was running a 735 ecu for the longest time, a few months at least, and it was guzzling gas and had a stupid lopey idle hahaha. But he worked his magic on it and now it runs like a dream :)
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        #176
                        Put the ellips back in & I recieved my adjsutable subframe kit from e30 tech(camber and toe!). I just placed my order with Blunt for a lower gasket kit and ordered some transmission fluid, which will hopefully solve my mystery grind in 4th gear :P
                        • freeride53
                          • 11972
                          #177
                          haha holy shit you psycho, you fixed it!
                          mad props man!
                          1983 Peugeot 505 STI
                          1992 Volvo 240 Wagon
                          • irish44j
                            • 2763
                            #178
                            Well, I've lurked on this thread for several months getting ideas (and thinking that I really need to get on my welding and painting skills!), but since you dropped into my build thread I think it's time I say a legit "good job" to you - alot of tough work going into the rust issues especially. When I was 17 my idea of restoring a car was pulling off random parts and rattle-canning them, and maybe changing a clutch or brake pads. So it's all the more impressive what you've done being 17 - things that I can't even do when I'm 20 years older, lol.
                            keep it up. want to see this thing on the track!
                            Stage rally/rallycross e30 build/competition journal
                            Track/street e21 build
                            visit Condor Speed Shop
                            visit Motorsport Hardware
                            [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
                            • AbsorbantNut
                              • Jun 2010
                              • 2491
                              #179
                              mad props man!
                              Haha, thanks man, it's a blast:D
                              Thank you, my friend! I can't wait to see what we each get done in the next year on our cars!!
                              So the car is currently in the shop getting AC...here I come cold air! I have never had a car that had AC before, so this should be a real treat living in south Florida:p I'm making a trip up to Jaxonville for Track States to watch my sister in the car Thursday; hopefully this thing can make it! I'm so excited to go!!
                              I changed out the trans fluid & filled it up with some ATF gear oil, and 4th gear doesn't crunch as bad. Other than that, not much has been done. I haven't had a chance to put the lower seals in, so I'll need to bring some oil with me on the trip. I'm ordering ball joints next and possible a power steering delete from one of my favorite people, silence8 :o
                              • AbsorbantNut
                                • Jun 2010
                                • 2491
                                #180
                                Well, I'm late on updates as usual. The CPS went bad one night. So that meant no spark or fuel. I went wire tracing and relay checking, and ended up at the front of the car with a bad CPS. "Stole" one from my dad's vert which sits in the backyard to put in the car to keep it running:p
                                Then I swapped out the antifreeze for some waterwetter, put on some four year old RA1's and went to the track event at Homestead, FL!!!!
                                I did the hyperdrive and it was such a blast, I am for sure going back for a whole weekend next time:D Now onto some pics!
                                And the end of the day with all of us leaving:o
                                The car handled much better than I ever thought it would, it really has come a long way since when I got it. However, the exhaust still needs some work because according to everyone else, I sound like a tractor
