Eta-to-M50: Build thread
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #481
    Yes, bedliner coil cover required.
    • Jand3rson
      • 37587
      #482
      Ha. Don't think so, I already has plans for that...
      Just finished doing bedliner on the firewall and trans tunnel, I'm really quite excited at this point. Finishing off the engine bay marks the point of starting to put things back together. I just bolted the fuse box back down, and that was the first step. Monday, I'm ordering my clutch kit, my headers, engine mounts, and a whole shitload of little parts from blunttech, pretty much everything I need to completely put the engine back together. Just waiting on a flywheel.
      • Matt-B
        The Waffler
        • 3856
        #483
        Cool beans, see you tonight ;)
        • blunttech
          • 12850
          #484
          when Im wrong Ill admit it. That looks great. Nice recovery Josh
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • Jand3rson
            • 37587
            #485
            Das one clean muhfucking ABS pump!
            Cleaned all of the hardlines too, planning to clean and paint the master cylinder, and put them all back in tomorrow, along with the new 944 booster. Going to hopefully run all the wiring back into the engine bay, too.
            • Jand3rson
              • 37587
              #486
              Didn't get as much done as I wanted to today, but I did get the ABS pump and the hardlines back in, as well as started working on getting the wiring back in. I decided not to do a wire tuck since I'm not really too hot on extending everything, but I did want to get it up off of the wheel wells, so I got some rubber-coated wire clamps, and mounted the harnesses up along the underside of the fender. Those 2 harnesses are still the only one's you'll see, everything else up on the firewall will be behind M3 firewall covers.
              • White325is
                • Oct 2006
                • 5947
                #487
                I like. Reminds me of the old mopar engine bays where the car would be any color and the engine bay was always black.
                • Jand3rson
                  • 37587
                  #488
                  I kind of thought it gave the engine bay a little more of a "motorsport-y" look, kind of along that same vein. I'm just lucky that my car is black. :D
                  • ShowStopper
                    • Jan 2008
                    • 1845
                    #489
                    So clean..keep it up josh.
                    • Dave
                      E30 RAT
                      • 11675
                      #490
                      Looking good, dude.
                      What flywheel are you waiting on?
                      Current Cars
                      2014 M235i
                      2009 R56 Cooper S
                      1998 M3
                      1997 M3
                      • parkerbink
                        • Jun 2004
                        • 10134
                        #491
                        HOLA Dave!!
                        Very nice work Josh..
                        • Jand3rson
                          • 37587
                          #492
                          Originally posted by Dave
                          Looking good, dude.
                          Just need an M20 flywheel. white325is is supposed to be getting one for me and doing the shave on it so it clears the oil pan bolts, along with one of his tranny mounts for the 260.
                          • Jand3rson
                            • 37587
                            #493
                            Andrew and I completed modifying the booster input rod on my 944 booster tonight, should be able to get it and the master cylinder back in the car soon, once I get my new expansion tank. Also fixed the broken bleeder screw on my M42 radiator, we just epoxied in a new threaded insert, and put a new nylon bolt in for a brand new bleeder.
                            • Denny
                              • Jan 2010
                              • 822
                              #494
                              I did the same thing but my interior floor pans came out good....ditched the moisture trap carpets..
                              A good and very resistant cheap paint for underhoods, trunks..etc.. ius rustoleum
                              Denny
                              ___________
                              1990 BMW red 325IC M30B35 all stock Girlfriends ride
                              1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                              Blogs:
                              http://bmw325e30.blogspot.com/ (restoration)
                              http://bmw325e30turbo.blogspot.com (Twincharge M20)
                              http://bmw325e30m62b44.blogspot.ca/
                              • samiam3356
                                • Jul 2009
                                • 1901
                                #495
                                Interesting choice for the bay. If I had not seen the pictures 1st I would have been in the no way this will turn out group. BUT it really looks fucking good man. Great job on going against the grain and proving that it can look good.
                                Looks like I'm about to switch to a Porsch booster as well. Think mine is toast and have a friend with an extra one. Need to go research on what you have to modify to make it work.
                                Sam
                                Originally posted by Roysneon
                                $5 shipped?
                                Originally posted by MarkD
                                You are a strange dude, I'n not answering any more posts from you.
