Eta-to-M50: Build thread
  • AndrewBird
    The Mad Scientist
    • 11898
    #631
    Originally posted by MattM
    Also, BMW seems to have superceeded the short bolts with the long ones... i could not get brand new short bolts, so i had to get the i CV's
    You realize they are just bolts and can be bought at any hardware store, right?
    It's kind of sad to think that most of the valve cover will be covered with the coil cover.
      • 34839
      #632
      you can buy grade 10.9 metric allen bolts with anti rust coatings at your local hardware store? lucky you!
      • ck_taft325is
        • Sep 2007
        • 6880
        #633
        Need a part? PM me.
        • Jand3rson
          • 37587
          #634
          I'm probably not going to be using the coil cover. The red is just to beautiful. I test-fitted the coil cover last night, and I hate it.
          • dude8383
            • Jan 2005
            • 10387
            #635
            Fucking epic man. Good job :up:
            When I have the balls to drop my motor back out and install an S54 I will clean everything up just like you did. Truck bedliner ftw.
            I'm really diggin the red valve cover as well, I was thinking about doing the same thing with mine to add some more color. It would match well with my ffd fans as well as my red strut tower bar.
            Once again, GOOD JOB!
            • FredK
              • 14761
              #636
              You can actually get metric grade 12.9 SHCS at Lowes, especially for common lengths like M10x50. Now, they'll be expensive, be made overseas, and have no certs, but that's another can of worms.
              • Jand3rson
                • 37587
                #637
                Ok, finally got time to pick up and install spark plugs today, and I got the plates and ground straps figured out. Also picked up some killer looking stainless machine cap screws for the injector rail and injector harness, I love the way these screws look.
                • e46s54dr
                  • May 2008
                  • 1059
                  #638
                  Damn, That valve cover is freaking awesome. I just got done powder coating my valve cover wrinkle black or else i would have had to bite your style. lol. I think it would look killer with a matching red wrinkle painter plastic M Power cover. Yes?!?!? Do it!
                  • Jand3rson
                    • 37587
                    #639
                    Not an M Power cover, it's not an M engine. I've kicked around wrinkle coating a coil cover, I'm just not sure it will wrinkle properly. Might have to just try it.
                    And for hardware, I use the hardware section at ACE. It is... incredible, they have everything.
                    • YAN-3
                      • Jan 2004
                      • 6018
                      #640
                      Josh I have a cover if you want to practice on, or if you need it. I can snap photos and send it to you, to make sure its the right one. shoot me a PM or TXT me
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        #641
                        I would totally wrinkle a cover and at least test it. I don't think it would look as clean without it, and worse case, ribs removed, smoothie style with gloss paint would look good too.
                        • Jean
                          • 18228
                          #642
                          Replace that ugly old ground strap man, it's way too ugly for that pimp engine!
                          • Matt-B
                            The Waffler
                            • 3856
                            #643
                            my grounds are on 1 and 6, interesting (before removal)
                            • Jand3rson
                              • 37587
                              #644
                              They're on the right ones. There's little cutouts for the lead that connects to the valve cover down in the hole where the valve cover bolts go, the ones with the studs on them.
                              Totally forgot, my headers came today! They're the ebay specials, not off-the-shelf-new, but never been mounted by the seller and I got them for a killer deal, with a new Turner stud kit. The PO painted them black, so I'm going to strip them and paint them hi-temp silver, then get them mounted up.
                              • AndrewBird
                                The Mad Scientist
                                • 11898
                                #645
                                Uh... yeah. Can't you?
