Eta-to-M50: Build thread
  • bimmerteck
    • 762
    #661
    I can't install the gasket when the o-ring is on the outside of the thermostat. The housing smashes it off when I tighten the bolts down.
    No gasket goes there only an o-ring around the outside of thermostat and the orange profile seal that installs into the thermostat housing. ;)
    If you go attempt to look up a part # for #7 you'll find it wasn't used at all after the very early M50s all of which can be updated IIRC by purchasing the later style thermostat housing.
    • Matt-B
      The Waffler
      • 3856
      #662
      orange profile is for plastic housing only, metal has no seal there, and there is a 1 piece gasket for whole thing
      • Jand3rson
        • 37587
        #663
        Fuck it. The old o-ring, which is still good is installed on the thermostat, and the thermostat housing is installed over it, with the new gasket. Moving on!
        • bimmerteck
          • 762
          #664
          Motors built up to 5/92 that haven't had an updated thermostat housing use the paper gasket and o-ring, if you look up a later production m50 the Thermostat housing is superceded to the newer one that uses the orange gasket on the right side of the thermostat. The upgraded housing will have a groove for the orange gasket as shown below. The picture below that is the orange gasket that goes there instead of the older paper gasket.
          • Matt-B
            The Waffler
            • 3856
            #665
            Nice, now to install motor
            • cramer
              • 1812
              #666
              Josh - did you powercoat the original thermostat housing or a new one?
              Chris
              90 Corrado/91 M3/01 M5
              • Jand3rson
                • 37587
                #667
                The original one, the one that was on the engine when I got it. Aluminum housing, but no groove for the orange profile gasket.
                Like I said, it's all mounted on there now with the o-ring and paper gasket. Should be fine. If there's every any problems, I'll swap out for the one with the profile gasket.
                  • 37834
                  #668
                  Are all of those bolts NEW? You crazy son.
                  Grover Beach, California
                  BimmerHeads.com
                  • Jand3rson
                    • 37587
                    #669
                    The only hardware I'm replacing with new is what will be seen. Everything else is just the re-used existing stuff.
                    • einstein57
                      • Jun 2007
                      • 10780
                      #670
                      I reused all the hardware on my driveshaft, axles, etc. My dad never mentioned anything about replacing them. 45k miles and an additional 150+whp later, everything is still together.
                      www.gecoils.com
                      • Jand3rson
                        • 37587
                        #671
                        I'll never re-use locking nuts again, be it nylon or all metal. And I'll be replacing all the hardware on my drive axles just because I've never replaced them, and god only knows when they were last done. A few extra bucks for peace of mind while I'm in there anyway is worth it.
                        • Schnitzer318is
                          • Jan 2008
                          • 2057
                          #672
                          Agreed. Nice work.
                          "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                          91 318is Turbo Sold
                          87 325 Daily driver Sold
                          06 4.8is X5
                          06 Mtec X3
                          05 4.4i X5 Sold
                          92 325ic Sold & Re-purchased
                          90 325i Sold
                          97 328is Sold
                          01 323ci Sold
                          92 325i Sold
                          83 528e Totaled
                          98 328i Sold
                          93 325i Sold
                          • Lof8
                            • Oct 2006
                            • 2827
                            #673
                            That engine bay is gonna be pretty!
                            S50'd
                            Originally posted by TDE30
                            What is this faggy shit I have happened upon?
                            I can always live in a M3. Can't M3 a house.
                            • z31maniac
                              • 17566
                              #674
                              My bronze car had new bolts/nuts for everything that was removed. Subframe/lollipops/etc.
                              Keep up the good work, can't wait to see it finished.
                              www.gutenparts.com
                                • 37834
                                #675
                                Wow, I'm a mechanic and have never "replaced" lock nuts. There's no need man.
                                BimmerHeads.com
