'90 325i sedan. (bronzit content)
  • jaywood
    • Jul 2010
    • 4528
    #226
    Got the exhaust done the other day. The photobucket app was sucking dicks so I couldn't upload any pictures.
    Oh yeah, sound clip :)
    • Dj Buttchug
      • Jun 2010
      • 7686
      #227
      gettin there. nice work
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • kingston
        • Jun 2010
        • 2669
        #228
        Oh, man, that's going to be soooo cool!
        Originally posted by LJ851
        kingston is the play by play announcer for this thread.
        ‘Tis by the grace of God that my cars run!
        Originally posted by unloadedak
        #teamross
        Siobhan's Build Thread - UPDATED!
        • theryp
          • Jul 2010
          • 38
          #229
          gets better and better
          http://www.flickr.com/photos/theryp/
          :p
          • jaywood
            • Jul 2010
            • 4528
            #230
            Thanks ^^ ;)
            • jaywood
              • Jul 2010
              • 4528
              #231
              Little by little
              30lb injectors replacing stock
              When taking out the old injectors, make sure you get ALL of these pieces out (pintle caps, o-rings, washer).
              These ones got stock so I used this to get them out
              New injectors in
              Wideband LC-1 came in
              Welded bung onto downpipe
              Metric blues in
              Turbo chip in (no MS, sorry :))
              • Pantless Spency
                It's McRib time!!!
                • Feb 2011
                • 7283
                #232
                god damn man the progress with your car never stops!
                you gotta help me when i start to rebuild mine 8)
                i've never even opened a valve cover, i know ill need some help from someone who knows that they're doing.
                • jaywood
                  • Jul 2010
                  • 4528
                  #233
                  Thanks pantless :) , school starts tomorrow (thursday) so I am going to try and get it running by then
                  • Pantless Spency
                    It's McRib time!!!
                    • Feb 2011
                    • 7283
                    #234
                    you going to SBCC?
                    my sister just started her first semester there.
                    or are you still in high school???!
                    you gotta come help me man! lol.
                    • jaywood
                      • Jul 2010
                      • 4528
                      #235
                      Still in high school :(
                      SBCC already started I think
                      Haha, what are you working on? Come to sb and I'll try to help you :)
                      • Pantless Spency
                        It's McRib time!!!
                        • Feb 2011
                        • 7283
                        #236
                        yeah she started on saturday
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7283
                          #237
                          i mean monday wtf. lol
                          • Wh33lhop
                            • 11705
                            #238
                            Because you can't, you won't and you don't, stop
                            Do it!
                            paint sucks
                            • jaywood
                              • Jul 2010
                              • 4528
                              #239
                              I don't really know where I left off last, but I'll let the pics do most of the talking
                              Exhaust hangar
                              Homemade adapter for the AFM (and yes, eBay does have these things for $9). I needed it that day so I decided to make my own out of 2.5" exhaust piping and a little square of steel. I milled out a square in the center and welded the pipe on. I ended up cutting the pipe in half (wayyyy too long) so it fits better now.
                              Welded the bung in the wrong spot, so I had to grind it out, fill the hole, and then reweld it back on.
                              Wiring the wideband in
                              Got the intercooler in place/plumbing all done
                              Vacuum lines all good to go
                              Adjusting AFM wheel
                              So then once everything was hooked up, the fucking car wouldn't start.
                              First thing to check was the plugs. I'd have to say they were horrible.
                              So than I replaced the plugs with some NGK's, and it still wouldn't fire up. It would crank over, but it wouldn't run. Checked the plugs, they smelled like fuel, but they weren't soaking. I figured I was getting fuel. Then I got worried I wasn't getting spark, so I checked the spark plug and it had a strong spark. So my battery started to die and I couldn't find a charger. Sooooo I had my brother jump start me ;)
                              ~3 minutes of trying to get it to start, it finally fired up. I sat on the throttle for a minute to get fuel through all of the lines/injectors and when I let off it idled amazingly. It was idling at 15.3 AFR (too lean) so I will adjust that tomorrow. Other than that, it seems to be run pretty well. I know there is a tiny exhaust leak coming out of the wastegate (a gasket is blown or something) so I'll take a look at that as well.
                              • theryp
                                • Jul 2010
                                • 38
                                #240
                                yesssssss
                                :p
