Originally posted by jaywood
View Post
'90 325i sedan. (bronzit content)
Originally posted by jaywood View PostFirst thing to check was the plugs. I'd have to say they were horrible.
89 E30 S52
Transaction Feedback.
sweet..im wondering tho..did u fabricate that piece the back of the intake manifold for the vacuum hoses yourself?...what did u do about the oil cooler? and last what did you do to your AFM. ive heard there is a trick that u can do to even a stock motor with the AFM for added power. is that what was giving you idle problems in the end or it eventually just started right up.
Im going to be building my turbo this winter so im reading up on alll the turbos i can. nice job tho. wheres the donuts/tires screaming clip?m20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
(.Y.) those are you for, for your hard work...
nice fcukin work-Brad, AlphaTeam Motorwerks, LLC
91' 318iS - S54/6MT Swapped
08' E90 M3 6MT - Daily
Originally posted by IronJoe
Originally posted by 2mAn
Originally posted by ROLLingKING View Postsweet..im wondering tho..did u fabricate that piece the back of the intake manifold for the vacuum hoses yourself?...what did u do about the oil cooler? and last what did you do to your AFM. ive heard there is a trick that u can do to even a stock motor with the AFM for added power. is that what was giving you idle problems in the end or it eventually just started right up.
Good luck. Do more research then you think you need to. Don't start buying shit till you know what every single part of a turbo setup does and how it works.
Originally posted by spiDmang View Post(.Y.) those are you for, for your hard work...
nice fcukin work
Appprreeciate it a lot man ;)
Thanks
Originally posted by Wh33lhop View PostIs it fast yet?
Stop painting fucking oil pictures and update.
Got my AFR's all dialed in, RRFPR installed with some new fuel lines, and other misc stuff. I still need to make a gauge pod thing. Right now the wideband and oil pressure gauges are just sitting in the center console where the coin tray used to be. The boost gauge is resting where the OBC used to be (wedged in)
Naw i was talking about a pic on page 16.lol i can figure out my intake boot. But its the little triangular piece thats right above the valve cover. ya know where the intake manifold and and valve cover are bolted holding up the intake manifold. its all new and shiny in one pic and u have 2 more vacuum hoses coming out of it. it looks really clean.
I saw in another build someone just split the main hose and put in T fittings to fit the rest of the extra vacuum lines for turbo.
So u can safely rock no oil cooler at all huh? is that safe for performance runs tho where temps creep up? cause once i put my intercooler in im not sure about the cooler. or does everyone delete it when turboing. im pretty sure ive seen a few actually UPGRADE the cooler.
And i hear ya on the reading as much info as possible! building a turbo on 209K miles makes me a little nervous. I dont want to blow the motor and get laughed at.lol I have time before i do my turbo..maybe a year from now but im really aiming for about 6months from now.
Great work. whens the dounuts clip comin out?lolm20 is plenty. im simply a drifter.
