Andrew's 1989 325i Project
  • 5Toes
    • 9836
    #316
    Airbox off... now that i know how to do it took 3 minutes! woot!
    But now all the vacuum hoses are being stubborn! I hate the OEM hose clamps... am I nuts to want to replace all of them with the screw type clamps???
    How does one coax off a hardened vacuum hose (brake booster for instance?)
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7284
      #317
      not nuts at all,
      the screw clamps make it much easier to work around your vacuum lines and what not,
      i did a few of mine when my eta was still running,
      and the clamps are dirt cheap anyways.
      i think i used 1.5 inch clamps but im not sure.
      • 5Toes
        • 9836
        #318
        Yeah the clamps are like $.60 to $1 each... not too bad. Looks like I need new vacuum lines too.
        cha ching cha ching cha ching
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7284
          #319
          buy them in bulk,
          pack of 15 for like a couple bucks.
          • 5Toes
            • 9836
            #320
            Yeah, duh. Why didn't I think of that! lol
            • bernzpeed
              • 3917
              #321
              this is funny. do you have the vacuum hoses already, I've got some extra? also if you a pick tool, you can hook it up at the bottom of the hose and pull up. that's what i did with mine.
              89 E30 S52
              Transaction Feedback.
              • 5Toes
                • 9836
                #322
                Pick a tool? What do you mean? Give me direction!
                I was going to try and save the hoses that I could, but I guess I will end up buying new ones.
                • Pantless Spency
                  It's McRib time!!!
                  • Feb 2011
                  • 7284
                  #323
                  whatever you do just make sure you put them all back together correctly :P
                  • bernzpeed
                    • 3917
                    #324
                    Saturday morning my starter went out. It wont even click on. Some beating on it and it still wont do anything... so Im in a pickle. ugh
                    tap on the starter housing to shake the dust inside out and clear the contacts and try starting again.
                    Pick tool.
                    you can't save those if they're old. they become brittle.
                    if you want some i have almost 2' in length. $15 shipped. you can use them
                    89 E30 S52
                    • 5Toes
                      • 9836
                      #325
                      Well the tube size I need is like $1 a foot at Oreilly... so Ill pass. Thank you though
                      • bernzpeed
                        • 3917
                        #326
                        np, i bought this at the dealership is why.
                        89 E30 S52
                        • 5Toes
                          • 9836
                          #327
                          Finally made some progress. Yes I work really slow...
                          Got the T/B off and now I am working on the intake mani bolts. I borrowed some wobble extensions from my neighbor
                          • 5Toes
                            • 9836
                            #328
                            Im making progress... sent the intake manifold off to the powdercoater today
                            M50 injectors are going in... which means old ones are up for sale.
                            eBay chip in the next month. Woot!!!
                            Sadly though, my C191 plug is broken and I cut the harness 2 inches up to get the mani off... I cut way too far up. So now I am going to use a weather pack connector and splice in longer wires.
                            • Balleristic31
                              • Aug 2009
                              • 4198
                              #329
                              Did you find some other injectors?
                              -NICK
                              • 5Toes
                                • 9836
                                #330
                                Actually I found some local Ballertistic, sorry I never got back to you man!
