Kamotors E30-Turbo to ITB M20
  • Good & Tight
    • Apr 2004
    • 2057
    #1636
    Hey what's going on in here...?
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    • kamotors
      • Nov 2007
      • 7102
      #1637
      and a quick question my b35 had a massive dual mass flywheel, what are my options to getting something affordable and lighter?
      7speedshop.com
      • RagtopE30
        • Dec 2010
        • 1869
        #1638
        The injector harness from your m20 will work fine. Just remove the beauty cover and then remove all the little zip ties. You will have enough slack to plug the harness into the m30 injectors. I then re wrapped the harness in the new stretched out configuration. Other wise the only change to the harness is the afm plug but I assume you will be using a IAT sensor am you will have no problem. Everything else lines up and is a plug and play.
        450whp 524 lb-ft 1988 336ic In progress
        http://www.r3vlimited.com/board/showthread.php?t=250709
        • LJ851
          • 7919
          #1639
          flywheels:
          M90, E9,E3,E28 533i, and i think E28 M5. All of those are single mass and 14-16 lbs ish.
          The 533 one is prob most valuable since it has timing pick triggers which you do not need with the B35.
          Lorin
          The M30 is God's engine.
          • RagtopE30
            • Dec 2010
            • 1869
            #1640
            You can use a 1983/4 flywheel out of a 733i or 533i. They are factory lightweight single mass flywheels. Or the M5 flywheel. I went with an aftermarket aluminum light weight flywheel for the b34 (has the crank reference tab) and matching single mass Spec clutch
            • RagtopE30
              • Dec 2010
              • 1869
              #1641
              Shit LJ851 beat me to it
              • LJ851
                • 7919
                #1642
                Forgot about 733, thank you.
                Lorin
                • Bimmer_man
                  • Jan 2013
                  • 1477
                  #1643
                  You can use the 3.3 flywheel but it will need to be machined. It's use a bit cheaper than the m5 flywheel.
                  Float like a cadillac sting like a Bimmer!:)
                  • LJ851
                    • 7919
                    #1644
                    ^ What does a 3.3 flywheel need to be machined for ?
                    Lorin
                    • Bimmer_man
                      • Jan 2013
                      • 1477
                      #1645
                      I think the surface is too big and needs to smaller or something of that nature at least that's what Paul told me.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1646
                        sooo big issue. Block has about 5 cracks. need a new block.
                        also cylinder is coolant washed.
                        no carbon in the port
                        7speedshop.com
                        • Bimmer_man
                          • Jan 2013
                          • 1477
                          #1647
                          That outlines some differences
                          The b34 and b35 use the same block 92mm stroke by 86mm bore.
                          The B35 has 1mm larger valves, larger ports and a hotter cam (264).
                          The b35 has larger comustion chambers
                          The b35 uses different pistons
                          The b35 has better intake and exhaust manifolds (more flow)
                          There are 2 different versions of the b34 (the dirty motor (10:1 CR) and the green motor (8:1 CR))
                          The only difference between the two are the cam and the pistons.
                          The dirty motor uses the b35 cam (264) and higher CR pistons
                          courtesy of The Sixer Kid of bigcoup.com
                          so youd need custom pistons i believe for a b34 bottom and a b35 top
                          • RagtopE30
                            • Dec 2010
                            • 1869
                            #1648
                            I know several people with e28's who are running 3.3 flywheels on B34 engines and getrag transmissions with no modifications.
                            • Bimmer_man
                              • Jan 2013
                              • 1477
                              #1649
                              oh sweet will there you go. I looked through my notes and i think i was going to lighten mine i think thats the reason for it for me then. Oops my bad.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1650
                                parting out m20 turbo setup
                                m20 turbo
                                7speedshop.com
