Kamotors E30-Turbo to ITB M20
  • downforce22
    • Aug 2009
    • 3192
    #1666
    I saw you changed your cam at the same time, but did you notice a difference in the exhaust manifold?
    I have both at the moment and am debating on which to use. It seems the second one with the long tubes would flow better. Any input?
    • kamotors
      • Nov 2007
      • 7102
      #1667
      are you talking about when I changed my cam on the M20^
      7speedshop.com
      • jute91
        • Nov 2011
        • 581
        #1668
        Hey Kameron, how about twin turbo?
        Also found on Facebook - Juuso Tero, Tampere
        https://www.facebook.com/JuusosGarage
        • kamotors
          • Nov 2007
          • 7102
          #1669
          getting ready to cut the front of the car off. rolled the front sheet metal near the flares to fit more wide, need to cutout rad support-repair/reinforce/repaint. Re wire a few things to clean up that mess, make room for huge intercooler, then finish the 3.5l
          [IMG]
          https://scontent-a-sjc.xx.fbcdn.net/hphotos-xaf1/t1.0-9/10418845_4234346794833_516830921314217527_n.jpg[/IMG]
          7speedshop.com
          • delamaize
            • Nov 2013
            • 1453
            #1670
            first build was pretty epic to read and catch up on.....this one follows suit.
            Dumpster Fire Pilot
            • hfabricius
              • 608
              #1671
              Sub'd cause I will be going M30 turbo soon as well and this will help me lots.
              http://halden-fabricius.tumblr.com/
              • LJ851
                • 7919
                #1672
                Timing belts will soon be a distant memory.
                Lorin
                The M30 is God's engine.
                • downforce22
                  • Aug 2009
                  • 3192
                  #1673
                  Yes, how did your two m20 exhaust manifolds compare?
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #1674
                    Going to be following this closely as you have the same plans as me I'm doing my swap as I post this..
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • kamotors
                      • Nov 2007
                      • 7102
                      #1675
                      got a crack free block and machined crank from Titan Omega. Can finally start putting the M30 together.
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1676
                        parts update
                        good-n-tight t4 manifold
                        machined and balanced crank will need to use first under bearings now
                        oil pump cleaned
                        pistons cleaned
                        new hardware for the trans
                        7speedshop.com
                        • Bimmer_man
                          • Jan 2013
                          • 1477
                          #1677
                          Glad I was able to help I can't wait to see this thing on the road.
                          Float like a cadillac sting like a Bimmer!:)
                          • SterlingMetE30
                            • Mar 2014
                            • 229
                            #1678
                            Love your car, it's awesome you're always toying with it. The m30t will be awesome in that thing. Especially after what you have done already with your m20. I can't wait to do an I swap on my eta, and eventually rebuild the bottom end and have everything balaced and stroked to 2.8. Then when I get bored turbo for a 250-300 ft-lbs range. Nothing huge but a nice wide torque band. Also love the fender flares! I want a set after I fix the few rust spots, respray and have late model bumpers and valences. Glad I picked one of these up.
                            • efficient
                              • Feb 2012
                              • 3312
                              #1679
                              Damn you move pretty quick
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1680
                                SO pulled the m20 and ripped out anything useful from it.
                                For the M30 I dropped off all the bottom end parts to AIMS machine shop and I'm going to have them check everything over and assemble the bottom end.
                                you can see why im doing the m30 swap now, m20s block has been cracked for over a year now due to a pretty bad overheat last year, but crack was minor and I never lost coolant untill last month when all of a sudden a gallon disappeared into my oil, I changed the oil, changed headgasket,and studs but it wasnt saveable. The block finally cracked to the point of not being drivable. Dumped coolant into my oil from head stud hole made a huge muddy mess into the oil pan.
                                7speedshop.com
