Kamotors E30-Turbo to ITB M20
  • Wanganstyle
    • 2828
    #1621
    Originally posted by FLG
    Have z3 cover on standard e30 lsd, no issues.
    Sent from my SCH-I545 using Tapatalk 2
    You have a diff built with the e30 larger speedo ring to suit z3m diff cover. Z3m and Z3 non m covers are not directly compatible; total pain in the ass.
    Z3 non m has a different offset cover that places the stubby speedo sensor close to the smaller diameter speedo ring.
    Originally posted by kamotors
    who has an LSD they want to sell me?
    Looks like you just need a speed sensor ring; it presses right on. I have a few on the shelf if you need one for a e30- PM me
    • FLG
      • Sep 2011
      • 3165
      #1622
      Sorry I meant z3m cover... The direct fit finned one.
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • kamotors
        • Nov 2007
        • 7102
        #1623
        forgot to update I pulled it out and put a new recluter ring one.
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #1624
          7speedshop.com
          • Luke Girard
            • Dec 2013
            • 738
            #1625
            Nice e34 =)
            Sent from my Delorean
            • kamotors
              • Nov 2007
              • 7102
              #1626
              just got the engine and trans actually
              7speedshop.com
              • Luke Girard
                • Dec 2013
                • 738
                #1627
                That's right for the engine swap! Nice
                • kamotors
                  • Nov 2007
                  • 7102
                  #1628
                  M30 is so simple I love it.
                  weight reduction
                  head has around 30kmiles but I'm still going to do HD rockers, and more aggressive cam if I have the funds left after the bottom end rebuild..
                  7speedshop.com
                  • RagtopE30
                    • Dec 2010
                    • 1869
                    #1629
                    Oh this is going to be good!!!
                    450whp 524 lb-ft 1988 336ic In progress
                    http://www.r3vlimited.com/board/showthread.php?t=250709
                    • kamotors
                      • Nov 2007
                      • 7102
                      #1630
                      Thanks, your build was a huge inspiration.
                      7speedshop.com
                      • RagtopE30
                        • Dec 2010
                        • 1869
                        #1631
                        Thanks man. I feel like yours will be inspirational to me as you go along. I am planning on running a Cat Cams turbo cam and upgrading my rockers since I am pulling my head again anyways. From your research what cam profile and brand are you looking at?
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1632
                          Ill likely go with a bimmerheads regrind if I can get it for the correct price;). This head already has a 272 but I feel it will be too tame and leave me wanting more.
                          7speedshop.com
                          • RagtopE30
                            • Dec 2010
                            • 1869
                            #1633
                            Ah. The factory cam is a 265 if I am not mistaken and that is what I am currently running. It makes pretty good power but I want my power band to be a bit broader.
                            I am looking forward to seeing how you set yours up.
                              • 37829
                              #1634
                              This is going to be fun. I've always thought of doing a M30 turbo in something myself. Someday...
                              And I don't care what anyone tells you, use your stock M20 harness when you wire this up. It's so easy.
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1635
                                anymore info on how to use an m20 harness on the m30? the injector area is very different.
                                7speedshop.com
