Kamotors E30-Turbo to ITB M20
  • RagtopE30
    • Dec 2010
    • 1869
    #2176
    LOL Yeah go ahead and get the stage 5!
    450whp 524 lb-ft 1988 336ic In progress
    http://www.r3vlimited.com/board/showthread.php?t=250709
    • jalopi
      • 2370
      #2177
      I've never been a big fan of unsprung clutches.
      So what does Spec usually charge for a disc? Tell them $100, then you'll be happy and not flame them. If they can't cope with taking a hit on a manufacturing defect I'd say they either have poor business practices or they have an inferior product. Call them out on it, in a polite way, and I'm sure they'll budge more.
      • IronFreak
        • Dec 2012
        • 3702
        #2178
        ppssshhhhh.....Unspung whozeewhatit?
        You need one of these!
        Instagram @rebellionforge
        • Jb325is
          • 2137
          #2179
          ^ Have you driven your car yet with that? They are a huge bitch to drive on the street or anything under WOT and they wear really quickly since you have to slip it so much at low speeds
          - '88 m54 coupe
          <3
          • kamotors
            • Nov 2007
            • 7102
            #2180
            ok so got the stage 5 disc ordered came to $244, couldn't get it any cheaper
            7speedshop.com
            • RagtopE30
              • Dec 2010
              • 1869
              #2181
              Good! Make progress and move on.
              • LJ851
                • 7919
                #2182
                That's the spirit !
                Lorin
                The M30 is God's engine.
                • jalopi
                  • 2370
                  #2183
                  Goddamnit... so no shadow war against spec? If it's any consolation, I'll never buy anything from them now.. hope you're reading this, spec rep
                  • kamotors
                    • Nov 2007
                    • 7102
                    #2184
                    They still treated me better than a lot of other venders, so they kept my business. lets just hope I have no more issues, I want to crank the boost up:)
                    7speedshop.com
                    • jalopi
                      • 2370
                      #2185
                      • IronFreak
                        • Dec 2012
                        • 3702
                        #2186
                        Yes, a good friend has a 7.25" tilton setup behind his m30 and it streets just fine, noise would be my only complaint in a street car and well.... My car isn't for street use so I'm not to worried. Keep it up Kam, I want to see that thing ripping it hard.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #2187
                          Well...:( :( :(
                          I'm NEVER ordering a clutch from spec again. SECOND CLUTCH disk and its bent again, never been installed, I checked this one as soon as it was opened. Upon Closer inspection one of the rivets isn't even in all the way. They blamed me the first time saying I bent the disk on install but here's proof that that's not the case. Has been tested in 2 transmission. Its just junk. I have a total of $700 in garbage now, original clutch was $500 and now another $200 in replacement disk. have videos of proof.
                          pic of rivet.
                          far right rivet not in all the way.
                          videos soon
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #2188
                            videos of it in 2 different trans rubs on same puck everytime
                            g260 #1
                            g260#2
                            7speedshop.com
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #2189
                              Hopefully they will take care of you with the proof of bad parts. Have never dealt with Spec, good to know.
                              john@m20guru.com
                              Links:
                              • Good & Tight
                                • Apr 2004
                                • 2057
                                #2190
                                Man that really sucks, hope they get it sorted out for you.
                                Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                                ____________________________
                                E-mail Panayiotisx2@gmail.com
                                Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
