Kamotors E30-Turbo to ITB M20
  • LJ851
    • 7919
    #2206
    Before i paper weighted the first clutch they wont take back, i would be trying to bend the wobble out of the center section to see if it could be straightened. Send the new one back.
    What a clusterfuck.
    Lorin
    The M30 is God's engine.
    • kamotors
      • Nov 2007
      • 7102
      #2207
      I cant drive it but I added an AEM secondary methanol injector kit. should be good to over 550hp according to the flow chart and cc's its now moving.
      7speedshop.com
      • LowR3V'in
        • 4209
        #2208
        Is that the one with the built in check valve?
        That means you took out the solenoid correct?
        • kamotors
          • Nov 2007
          • 7102
          #2209
          still using solenoid
          7speedshop.com
          • LowR3V'in
            • 4209
            #2210
            :crazy:
            • kamotors
              • Nov 2007
              • 7102
              #2211
              its one solenoid controlling 2 injectors as it has a y connection after it
              7speedshop.com
              • RagtopE30
                • Dec 2010
                • 1869
                #2212
                What a shame about the clutch! I had a good experience when I got my clutch and have promoted them because of it. If they don't take care of you I will no longer support them by sending customers their way. And I sure as hell will not buy another clutch from them when the time comes to upgrade or replace my current clutch.
                450whp 524 lb-ft 1988 336ic In progress
                http://www.r3vlimited.com/board/showthread.php?t=250709
                • kamotors
                  • Nov 2007
                  • 7102
                  #2213
                  Just got off the phone with ultrarev (http://www.ultrarev.com/), this is the company I originally purchased the clutch from a few months back and they have been EXCELLENT. They reply to emails fast and they gave me a call to make sure it all gets sorted. I talked to Ryan from ultrarev and he's doing everything he can to make sure the issue gets corrected, he's also BMW enthusiast which is a +.
                  They carry a clutchmasters kit so I may go right back to them to purchase a new setup.
                  7speedshop.com
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #2214
                    how much torque does there stage 5 do?
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • kamotors
                      • Nov 2007
                      • 7102
                      #2215
                      the spec was rated at 634
                      7speedshop.com
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #2216
                        my bad i meant clutch master
                        • kamotors
                          • Nov 2007
                          • 7102
                          #2217
                          havent found a suitable clutchmasters kit yet
                          7speedshop.com
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #2218
                            twas wondering about that
                            • gotaloveRWD
                              • Jul 2011
                              • 708
                              #2219
                              So any word on what they are doing for you to fix the problem?
                              IG- nv_e30
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2220
                                old clutchs are mailed back to spec and now I wait for a refund, Any one have a Clutchmastes M30 setup and a part number for the clutch? (doesnt matter stage # I just need to get a reference point)
                                7speedshop.com
