Kamotors E30-Turbo to ITB M20
  • dhd1
    • Dec 2013
    • 41
    #2356
    Originally posted by jalopi
    Doesn't take much reading to figure out that Kam is a huge fan of megasquirts. Don't get uppity when people don't immediately answer the noobiest of noob questions... if it's clear you didn't use the search bar you will not be treated kindly here
    http://lmgtfy.com/?q=how+to+calculate+turbo+size
    I apologize for acting like a noob. I was simply asking a question from someone who is more experienced than myself; in an attempt to learn. I quoted myself because I was unsure if he saw my post the first time. I am really sorry this offended you.
    Now; today I award you one internet tough guy point. Congratulations, you peaked in high school. :)
    • jalopi
      • 2370
      #2357
      you got uppity with one of your betters... we don't tolerate that kind of attitude around here, shape up or ship out
      o btw welcome to r3v
      • dhd1
        • Dec 2013
        • 41
        #2358
        you got uppity with one of your betters... We don't tolerate that kind of attitude around here, shape up or ship out
        :-d
        • delamaize
          • Nov 2013
          • 1458
          #2359
          regardless, the search function is there. freaking use it, rather than looking like a tool.
          Dumpster Fire Pilot
          • ForcedFirebird
            • Feb 2007
            • 8300
            #2360
            I average 1.2 posts per day since 2007. Pretty sure I get the n00b award. :P
            Oh wait, I posted 2x today :(
            john@m20guru.com
            Links:
            • jalopi
              • 2370
              #2361
              Meh... whatever. Just type "megasquirt m30" into google and it'll take you to the right place. Do some reading on megasquirts.
              Sizing the turbo is a little bit more complicated than that. You have two options:
              Option 1
              1. Read this http://www.gnttype.org/techarea/turbo/turboflow.html
              2. Use this calculator to pick a turbo, just make sure you read up on how to read a map http://www.motorgeek.com/?fullpage=true&page=flowcalc
              Option 2
              1. Assume Kam's the man and knows what he's doing (protip, he does). Copy his setup or alternatively buy his kit when it eventually comes out
              2. Profit
              • kamotors
                • Nov 2007
                • 7102
                #2362
                here is how i size turbos
                1.research what works on what motors and how to size correctly
                2.buy turbo- see how it works on your car
                3. if things did not go according to calculations sell the turbo and grab another that has the qualities your current turbo was missing. you'll lose a couple hundred but you'll learn what works.
                I personally used or built M20's running 5 different turbos, before I found one that worked perfect.
                7speedshop.com
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  #2363
                  Do you think you sized your turbo properly with the m30
                  1991 318i 4dr slick top
                  Mtech 2 turbo restoration
                  • kamotors
                    • Nov 2007
                    • 7102
                    #2364
                    yup, breathes very well up top, and spools by 2800rpms. It might be a little big for lower boost levels but for my goals it worked perfect.
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #2365
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #2366
                        sooo, went to start car to go to car meet but sounds like terrible knocking noises and like something is kicking the clutch pedal.
                        But for some reason clutch still works? I rolled like a foot to check, if I raise rpm it kind of quiets the knocking but still lots of vibrations on the pedal.
                        I did notice some vibrations on the pedal during the drive today but everything worked as expected and there was no clattering/knocking noises
                        not sure what happened, car was running when parked.
                        really hoping its just like severe getrag rattle and not the motor or clutch
                        7speedshop.com
                        • E30_Pare
                          • 7801
                          #2367
                          Need to bust out a mechanics stethoscope. If its the motor you'll know real quick. Good luck hopefully its nothing. Maybe a blown out mount?
                          DREWLIENTE
                          1$ PShops PM me
                          • LJ851
                            • 7919
                            #2368
                            The fingers of your pressure plate are at uneven heights (damaged).
                            Lorin
                            The M30 is God's engine.
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #2369
                              Damn I hope its not this. I dont wanna see this car have any more problems but the problem of needing tires.... Good luck kam hope its nothing major
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2370
                                I'm thinking its the the input shaft bearing on the trans, I also now remember I had what seemed like driveline vibration and a small clicking noise like the driveshaft was scraping on something, but when jacked up I couldn't re create it unless the car was moving under its own power.
                                I'm going to film a video of the noise soon.(just idling in garage) the rattle is louder than a straight piped car so I doubt this is the getrag rattle that people can live with.
                                But I'm thinking I need a new g260 for the M30, so who has one they are willing to sell me?
                                7speedshop.com
