Kamotors E30-Turbo to ITB M20
  • 318aye
    • Jun 2010
    • 895
    #2881
    Originally posted by kamotors
    petrolicious photoshoot finished up today. :)
    Neat. When will they finish that up?
    • kamotors
      • Nov 2007
      • 7102
      #2882
      Kamotors BMW E30 low alpina red fender flares wide by kamotors@y, on Flickr
      kamotors BMW by kamotors@y, on Flickr
      low3 by kamotors@y, on Flickr
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #2883
        exhaust sound video 2min. of m20 goodness
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #2884
          So after a couple canyon runs, my IAT temp got to around 180 degrees, car started pulling timing and running like poo. My trumpets were extremely hot to touch
          Hottest temp my turbo setup IAT EVER made it to was around 120degrees, so designing a boostable aluminum plenum, should be very easy as the RHD setup is multiple pieces and very easy to modify and bolt things onto.
          stay tuned will be somewhat based off of this.
          7speedshop.com
          • Victell
            • 1083
            #2885
            What about a phenolic spacer too?
            • Hooffenstein HD
              • Nov 2012
              • 1388
              #2886
              Open trumpets inside a closed engine bay is never a good idea. Plenum/CAI is where it's at.
              • crappycoco
                • May 2014
                • 250
                #2887
                aw yiss!
                • digger
                  • Nov 2005
                  • 6212
                  #2888
                  i started with a phenolic spacer until i realized they wont do anything except make the throttle bodies and trumpets run a bit colder which wont change anything. its the fact that the air being ingested by the engine is from under the hood (underhood temps are easily 60-70C probably higher with uncoated headers and low speed where little airflow is present. high IAT and high performance engines dont mix, risk of knock goes up drastically. A phenolic spacer usually helps a carb setup as it will lower the heat going into the fuel. the solution is to draw cooler air from else where and try and insulate it. An airbox solution is so much better to drive its not even funny, even moreso in summer.
                  • LoneWolf
                    • 402
                    #2889
                    Come on just put the trumpets through the hood. Do it.
                    • MPLFoster
                      • May 2013
                      • 1490
                      #2890
                      Awesome. Awesome to the max.
                      love petrolicious videos. congrats on the shoot. can't wait for the vid. :up:
                      form.follows.function IG @mplfoster
                      • Wschnitz
                        • 8089
                        #2891
                        That M12/M13 though.
                        You thinking of just making an airbox and having it pull air from the valance/behind headlight instead now?
                        willschnitz
                        • kamotors
                          • Nov 2007
                          • 7102
                          #2892
                          Video from cars and coffee, e30 content https://vimeo.com/127118160/description
                          7speedshop.com
                          • Bullet Ride
                            • Dec 2010
                            • 598
                            #2893
                            Proper link
                            Sorry, we couldn’t find that page
                            • kamotors
                              • Nov 2007
                              • 7102
                              #2894
                              Videoshoot done today
                              7speedshop.com
                              • blck325is
                                • Apr 2006
                                • 1749
                                #2895
                                Yes. Just yes.
                                Originally posted by csermonet47
                                Vlad, you are handling this quite unprofessionally.
                                Also, you are a cock with tacky taste.
                                That is all.
