Kamotors E30-Turbo to ITB M20
  • 318aye
    • Jun 2010
    • 895
    #2851
    Awesome! Glad you got it sorted. About to bolt mine up, will pm when it's time to get it started.
    • LJ851
      • 7919
      #2852
      Glad you found the problem. It wasn't making a lot of sense, but i was thinking that it was already fully alphaN.
      Lorin
      The M30 is God's engine.
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #2853
        Glad you finally got it figured out!
        • kamotors
          • Nov 2007
          • 7102
          #2854
          Thought this was interesting for E30's running huge turbos.
          The RED graph is my E30 in FIRST gear with an M20, gt35 turbo, stock intake manifold and 274/280 camshaft.
          The BLUE line is my current Naturally aspirated M20 setup in FIRST gear with same cam/internals, rhd itb's, short/mid length headers, X pipe near trans and dual 2.25" piping to the subframe. Picked up considerable amount of N/A power under peak.
          Now to go tune the ignition map.
          7speedshop.com
          • itskingsteelo
            • Jul 2013
            • 1340
            #2855
            title for this just got too stupid.
            Originally posted by dvck
            • ForcedFirebird
              • Feb 2007
              • 8300
              #2856
              According to that virtual dyno, you have stock m20 power.
              john@m20guru.com
              Links:
              • kamotors
                • Nov 2007
                • 7102
                #2857
                numbers dont matter as much as the comparisons and tuning I can run with it.+ i havent tuned ign. map as i wanted to get afr safe/normal first
                7speedshop.com
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #2858
                  What does your timing map look like?
                  john@m20guru.com
                  Links:
                  • kamotors
                    • Nov 2007
                    • 7102
                    #2859
                    2nd gear pull, just needs some touchups still. (the other one was 1st gear)
                    newest ign map.
                    7speedshop.com
                    • whodwho
                      • Jun 2008
                      • 1547
                      #2860
                      Does it really want that low of advance below 2k? Seems like it would fall on its face on taking off and mild gear shifts
                      My M20 Frankenbuild(s)
                      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                      • LJ851
                        • 7919
                        #2861
                        I agree with this, a linear climb in timing from idle to 2k should improve throttle response nicely.
                        Lorin
                        • BMWManiac
                          • Dec 2010
                          • 1091
                          #2862
                          Any examples to take a look at? I like comparing the N/A portion of my Ignition and VE tables with others....
                          Mine looks like this as well and I wouldn't say my throttle response is bad, but maybe I don't know what I'm missing!
                          1997 Artic Silver M3
                          CES GT4094r 651hp/615tq @ 24 psi
                          • kamotors
                            • Nov 2007
                            • 7102
                            #2863
                            its been far too long since the car has had a proper cleaning.
                            Kamotors BMW E30 ITB M20 Fender Flares by kamotors@y, on Flickr
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #2864
                              [IMG]BMW E30 ITB kamotors by kamotors@y, on Flickr[/IMG]
                              0-60 vid, not bad for a stock motor with a cam and ITB's,hauling massive tires around
                              7speedshop.com
                              • Wschnitz
                                • 8089
                                #2865
                                Sounds pretty good, looks like it pulls pretty good to spin the tires all the way to 35 haha.
                                willschnitz
