Kamotors E30-Turbo to ITB M20
  • TeXJ
    • 1914
    #3286
    Originally posted by kamotors
    Lol, I kept my wrx for 4 years, and the s60r for a year and 1 month. And I like this car more than both of those... it's only my extra extra cars I sell in a few months.
    Sent from my SM-N920T using Tapatalk
    Do what you want to do man. Heck you may just get a truck next :D lol
    1990 325is
    m52b28
    3.73lsd
    g260 (1987 325is 5spd tranny)
    • BMWManiac
      • Dec 2010
      • 1091
      #3287
      I know there are a gazillion pages in this thread, but can you rehash your setup? What turbo/injectors/MS2? I believe your running wasted spark as well?
      Would you mind posting up your Ignition table? I'd be interested to see what your timing looks like!
      1997 Artic Silver M3
      CES GT4094r 651hp/615tq @ 24 psi
      • kamotors
        • Nov 2007
        • 7102
        #3288
        currently
        155k mile M20B25
        274/280 dual pattern cam
        HD rockers
        Precision 6262 t4 turbo
        RSI manifold
        precision 46mm wastegate
        MS2 w/wasted spark and M50 variable TPS
        Clutchmasters fx400 clutch
        Methanol injection
        401WHP at 17psi on Mustang dyno
        going to start to replace headgasket tomorrow, will try to make a timelapse video of the process.
        7speedshop.com
        • IronFreak
          • Dec 2012
          • 3702
          #3289
          what's typically the difference between the mustang and say a dyno jet? I've heard several people say the mustang reads lower.
          Instagram @rebellionforge
          • kamotors
            • Nov 2007
            • 7102
            #3290
            I've seen dyno jet read 40whp higher than mustang
            7speedshop.com
            • 88SuperETABD
              • Apr 2009
              • 911
              #3291
              Nuts Cameron. How sensitive are the tunes to a cam? I thought we had the same camshafts. Hope your tune will run my motor well enough to break in the cam being its got a 84mm stroke and 284/274 cam.
              Great numbers
              (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
              1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
              • IronFreak
                • Dec 2012
                • 3702
                #3292
                I wouldn't be surprised if it was more. I was just reading up on the difference between the dynoJet (inertia measurement) and mustang dynos (load measurement). many people are saying it much closer to 100hp.
                One article was saying the magic number is 140hp. he cross checked the same car on both setups, factored the 140hp loss along with a .85 multiplying factor for chassis loss and his numbers from dynojet to mustang ended up being about 3hp different.
                I wouldn't be surprised if you were a lot closer to 500hp on a dynojet.
                • whitebulat22
                  • Apr 2014
                  • 330
                  #3293
                  When you said worse damage could have happened if the gasket didn't blow, do you mean more timing to the point of putting a normal gasket in danger is passing the breaking point of the bottom end? And that an mls gasket could do more harm than good for this reason?
                  • Bimmer_man
                    • Jan 2013
                    • 1477
                    #3294
                    His car went on an actual 4 wheel dyno as well. So the number ha has is more real world because he was able to utilize a real world dyno and tune accordingly. If memory serves his rwhp was around 430hp but I could be a little off.
                    Float like a cadillac sting like a Bimmer!:)
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #3295
                      4 wheel or 2 wheel has nothing to do with it. It about how the power is measured.
                      • Bimmer_man
                        • Jan 2013
                        • 1477
                        #3296
                        I don't know the specifics I just know the dyno that was used at a local dyno tuning shop is capable of dyning 4 wheel drive cars as well as 2 wheel. That's all I meant.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #3297
                          thought I would film the process of replacing the headgasket, 40minutes crammed into less than 2 minutes. I dont have much time for wrenching lately but hopefully tomorrow I'll pull the head off.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3298
                            Forgot to mention New webstore as well.
                            Kamotorsperformance.com
                            7speedshop.com
                            • CarsonE30
                              • Jun 2015
                              • 2124
                              #3299
                              Anyone run this kit in an E34? I'm picking up a 525it on Saturday and gonna swap it to a manual ASAP and am trying to decide to finally go boost or do a 532it, M52 or similar...
                              C6Z
                              S2K
                              VeloN
                              • Kershaw
                                • 11822
                                #3300
                                I didn't watch the video, but you did a head gasket in 2 hours? That's just impressive.
                                AWD > RWD
