Kamotors E30-Turbo to ITB M20
  • iwantspeed
    • 3164
    #3241
    Awesome results congrats!
    Project
    Parts for Sale
    Feedback
    YouTube Channel
    • ahrensNW
      • Mar 2015
      • 1716
      #3242
      Merp. I have more turbo wants than turbo moneys as a result of those sheets.
      Hank Ahrens
      1984 Alpine Coupe
      1978 911sc
      • kamotors
        • Nov 2007
        • 7102
        #3243
        7speedshop.com
        • Wschnitz
          • 8089
          #3244
          Volume on that is a little extreme lol
          willschnitz
          • stanhayward
            • Mar 2013
            • 765
            #3245
            Nice and linear power band. Also 400whp isn't too shabby ;) Congrats!
            1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
            1984 316 Coupe - The Base Model - Pain in the Ass
            1988 750iL - The Daily Driver
            ...And a couple others...
            • grinchxvx
              • Dec 2015
              • 295
              #3246
              Originally posted by kamotors
              (Real pics and videos later)
              The results are in! First dyno run destroyed my tires as the car was tied down to the point of tucking rim and It was bottomed out on body of car. I had to jack the coil overs all the way up, which isn't too fun on a dyno with wheels on the car.
              All testing was done on a Mustang dyno, with only minor fueling changes from the base tune I supply with my kit.
              So first real pull 330whp at 13-14psi
              Second pull made 396whp at 16psi
              And 3rd pull made 401whp and 370trq at 17psi.
              I'll be going back with my tune for meth and maybe some more boost.
              Sent from my SM-N920T using Tapatalk
              good shit, thats easily 400whp+ on a dynojet which is pretty much the standard. what does your car weight like 2500lbs?
              • kamotors
                • Nov 2007
                • 7102
                #3247
                Around 2600
                7speedshop.com
                • 88SuperETABD
                  • Apr 2009
                  • 911
                  #3248
                  Nice Kameron. I hope you gave me that second tune @ 16 psi :) good numbers! Happy to see this. I have a feeling my motor will be 400+ then with your tune.
                  Crazy 2 psi jumped 60whp. What were torque figures for 330 and 2nd pull. Did you mess with timing between 1 and 2?
                  (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                  1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3249
                    no timing adjustments or fuel changes were made between any runs. I made all the changes after 4th run to go back and get dyno'd again. I'm guessing it was in its efficiency range better or something.
                    7speedshop.com
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #3250
                      So none of these runs where done on meth? Or did I read that wrong?
                      Instagram @rebellionforge
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3251
                        My wheels will be for sale around the end of the month, who wants them?
                        7speedshop.com
                        • Bimmer_man
                          • Jan 2013
                          • 1478
                          #3252
                          He always is on method cause of the grade of fuel we have in Nevada. Too many additives and with high boost I think it can cause damage. I'm sure I'll be corrected if I'm wrong.
                          Float like a cadillac sting like a Bimmer!:)
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3253
                            Meth was used but i left the car in a running rich untuned state with only my base tune timing map. I expect at least another 30-40whp on my new tune. And nothing to do with additives. Water meth gives benefits of cooling as well as greater detonation resistance. So you can either run higher boost, more ignition timing and a leaner afr.
                            During that dyno I was only using around 14degrees of timing in boost, and around 11.2afr, since the dyno chart I've upped timing to 19 degrees and corrected afr to 11.8. Although the guy running the dyno said he prefers around 12.0 with meth. I want to be a bit on the safe side.
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3254
                              7speedshop.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #3255
                                7speedshop.com
