Kamotors E30-Turbo to ITB M20
  • TeXJ
    • 1914
    #3301
    Originally posted by Kershaw
    I didn't watch the video, but you did a head gasket in 2 hours? That's just impressive.
    he's done a few of them now lol
    1990 325is
    m52b28
    3.73lsd
    g260 (1987 325is 5spd tranny)
    • Bullet Ride
      • Dec 2010
      • 598
      #3302
      Originally posted by kamotors
      ...but hopefully tomorrow I'll pull the head off.
      Seems as though you didn't read either...
      • kamotors
        • Nov 2007
        • 7102
        #3303
        And I only did 40min of work so far lol
        Sent from my SM-N920T using Tapatalk
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #3304
          Got head out it another 20minutes, so only 1 hour labor and ready to reassemble. All 6 cylinders were ovaled but only one had the water jackets in the cylinder hole lol.....
          I'll be uploading the time lapse of it this week when I can get WiFi working on my laptop.
          7speedshop.com
          • Bimmer_man
            • Jan 2013
            • 1477
            #3305
            dude why dont you invest in a MLS?
            Float like a cadillac sting like a Bimmer!:)
            • kamotors
              • Nov 2007
              • 7102
              #3306
              I get this question like once a week so ill give a full answer, but you have to get block machined flat and if the headgasket doesn't blow on a bad tune than much worse happens.
              A great tune can get away with stock headgasket without issue, I'm pretty sure I've proven that as I beat the snot out of my m20s.
              This is my second headgasket since the beginning of this build thread, the ONLY times I get a headgasket issue is when I go all crazy trying to get the absolute last bit of hp via ignition advancing WITHOUT increasing boost levels.
              This is how you learn and the last thing I want is $$$$ money dumped into my motor when it's literally capable of killing me as is lol.
              401whp and 2600lbs is just about unusable anywhere under 65mph,The car has never been faster than this latest iteration. The car is to the point where spirited overtaking on the freeway usually ends up with you leaving some nice black 11's behind you.
              I run junkyard motors because I spend less than $400 for complete motors and get years of use at 400whp.
              7speedshop.com
              • 88SuperETABD
                • Apr 2009
                • 911
                #3307
                ^ well said. I'm against o-ring for this reason as well. Headgasket is a fuse. Rather take a few hours to do a gasket than rebuild the bottom end because the pressure has to go somewhere.
                (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
                • Bimmer_man
                  • Jan 2013
                  • 1477
                  #3308
                  I never thought of a oem head gasket as a fuse for the engine. That actually makes pretty good sense. Ill have to keep that in mind.
                  • potatomash
                    • Nov 2014
                    • 203
                    #3309
                    Wow so you were on oem gasket when you ran like 19psi through the kinugawa?
                    Sent from my HTC One M9 using Tapatalk
                    T U R B O - M 2 0 - B U I L D
                    M U S C C O O
                    • Coyote_ar
                      • Sep 2009
                      • 175
                      #3310
                      do you have the water passages on the head welded? or not even that?
                      using the gasket as a fuse makes a lot of sense.
                      ---E30 320i Hennarot 1984 Sedan---
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3311
                        Yup I've run 25psi on stock head gaskets
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #3312
                          Nope, all original besides cam and rocker arms
                          7speedshop.com
                          • potatomash
                            • Nov 2014
                            • 203
                            #3313
                            One less thing to buy. I like things that get my budget down :)
                            That's with a freshly skimmed head yeh?
                            M U S C C O O
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3314
                              Got the motor back together now just need to finish a few things up like rerouting charge pipes, adding my new water temp gauge in.
                              I filmed it but no WiFi still so can't upload. Took less than 2 hours so far. I plan on going to the catuned open house on the 30th
                              Ignore the grime, I'll be cleaning and replacing all gaskets, rocker shaft plugs etc tomorrow
                              7speedshop.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #3315
                                7speedshop.com
