Kamotors E30-Turbo to ITB M20
I did datalog and only thing I can see is that I was too aggressive on timing it was around 19.5degrees and pulled down to 15degrees at peak torque.
AFR was at 11.5
other interesting facts
-injectors are at 70% percent duty cycle WITH meth.
-coolant never exceeded 170 degrees even end of 4th gear
7speedshop.comComment
If the headgasket didnt blow it could of been worse damage. I'll be putting another goetze in and tuning accordingly. It was 100% my fault it was 100% solid and reliable at 3degrees less timing I didnt even adjust boost only timing and this happened.
I was able to absolutely beat on the car for miles on end without issue before this retune.
interesting, its done very well for a stock bottom end. At that level I suppose its on the tipping point and you need to have everything BANG ON.
once summer comes round do you back the timing off a bit again? must be very sensitive to ping at that levelBoris - 89 E30 325i
84- E30 323iComment
I have it setup so that after a certain point timing is reduced as inlet air temp increases, I do not have to change tunes between seasons
Sent from my SM-N920T using Tapatalk
EDIT:just checked manual, its definitly what its used forLast edited by kamotors; 12-23-2015, 08:49 PM.
E38s are fucking hot. Very nice car. Any plans for it?1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
1984 316 Coupe - The Base Model - Pain in the Ass
1988 750iL - The Daily Driver
...And a couple others...Comment
