Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #3361
    So even with a perfect afr the car was feeling down on power in 3rd -5th. I switched back to a single meth injector for now. The little 2.5l just can't handle that much meth. Will retune now and see how it feels. Also although I was set to 15psi with my manual boost controller the data logs were showing it creep open at right around 12psi. So I switched from a 9psi spring to 15psi in hopes to get full boost sooner. Will datalog and report back later.
    Sent from my SM-N920T using Tapatalk
    7speedshop.com
    • ForcedFirebird
      • Feb 2007
      • 8300
      #3362
      Why do you have the oil dipstick tube blocked off?
      john@m20guru.com
      Links:
      • kamotors
        • Nov 2007
        • 7102
        #3363
        It's not blocked off, the loop snapped off so that's how I pull it out, it not actually touching the black tube as the red part is a bigger o.d. I just grab it from that to remove now.
        7speedshop.com
        • dugly52
          • Oct 2012
          • 372
          #3364
          Originally posted by kamotors
          So not sure if I should just buy some 18x10's put my ultrawides on and 285/30/18 rear tire or just have fun burning out?
          Just.... yes!!!
          Project: 87' 325iS... 325iS
          88 Alpine 325i
          1/2 88 325iX
          • kamotors
            • Nov 2007
            • 7102
            #3365
            got boost down to 18psi, still need to go down 1 or 2 more psi so I can go WOT sooner.
            7speedshop.com
            • Coupelx
              • Oct 2013
              • 169
              #3366
              Have you considered setting up the traction control on MS?
              • kamotors
                • Nov 2007
                • 7102
                #3367
                its very tempting as it can retard timing to pull power based on front wheel speed sensor, however I feel 2nd gear would just become a bog zone as even at power as low as 10psi I still spins ALL of second gear.
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #3368
                  How accurate is virtual dyno? very.. I guessed 415whp, made 419whp so I'm impressed, this was back at 17psi. The RED lines are mustang virtual(with a better tune, stiffer wastegate spring and shorter charge piping, over the real life mustang dyno.
                  7speedshop.com
                  • ocCube
                    • Dec 2015
                    • 5
                    #3369
                    Nice work man! Do you use a boost controller w/ closed loop?
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      #3370
                      Cool, i know youre feeling about the traction problems :D
                      But i must say, no matter what traction control is nice to have!
                      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                      E30 M50 6 spd 764whp @ 24psi.
                      E30 M20 6 spd 675whp.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3371
                        I may of solved my traction problems..... the 285's will be here tomorrow.
                        7speedshop.com
                        • BMW_TUNER
                          • Jul 2006
                          • 1379
                          #3372
                          You are going to have to switch to your ultra wide flares. Currently my 255/35/18's clear no problem but I have another 20mm in the inner fender well for tire, I just need new wheels with better backspacing to utilize that space. The limiting factor starts to be the factory vapor return lines on the passengers side. But I am a little lower than you I think.
                          1989 332IS -S-Fiddy Four-Some weight removed.
                          5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
                          • BMW_TUNER
                            • Jul 2006
                            • 1379
                            #3373
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3374
                              That's fine but with my new wheels offset I will only have 4mm more poke that my 17x9 at et0 and I'll have 12mm more inner clearance than I did at 17x9 et20 so I may be able to get away with just shaving the inner lip out of flares.
                              The new wheels are 18x9.5 et2 with 285/30/18. But i have a pair of ultrawides sitting here just in case.
                              7speedshop.com
                              • BMW_TUNER
                                • Jul 2006
                                • 1379
                                #3375
                                Sounds like fun. If you want to see 255 clearance just shoot me a text. My current rear is 318ti rear with et25 on 18x9.5's. If I had my choice of wheels right now I would run et35-42, the. I could run some more tire.
