Kamotors E30-Turbo to ITB M20
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #1861
    Was the modification you did on the manifold just for more clearance or so it would fit? I ask cause my b35 intake is getting stuck on the booster and wont go down on to the studs.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • kamotors
      • Nov 2007
      • 7102
      #1862
      SO it run,idles,revs just need my revshift guibo............
      I went with a 12" 2300cfm 2.5" permacool fan, if its not adequate I'll try a 16" fan out. I made a new set of spark plug wires and reused my oil coils.
      M30 E30 swap by kamotors@y, on Flickr
      7speedshop.com
      • Sagaris
        • Sep 2009
        • 2243
        #1863
        Looking good! This thread is pretty much the only thing I follow ever since I moved in with Bob Saget.
        Why aren't you using a variable TPS?
        • kamotors
          • Nov 2007
          • 7102
          #1864
          drive ability has been excellent on the E30 TPS so I see no reason to change it. that is the M30 TPS btw ,its a bit thicker/has a different part number but I believe it works the same.
          7speedshop.com
          • kronus
            • Apr 2008
            • 13032
            #1865
            dude, trim your upper rad hose, it's bugging me
            nice job on getting it together so fast!
            you should also be able to use an aftermarket m20 distributor cap blank cover for the m30, they are the same.
            cars beep boop
            • kamotors
              • Nov 2007
              • 7102
              #1866
              intercooler pipe and BOV goes in there so not trimming it.
              7speedshop.com
              • kronus
                • Apr 2008
                • 13032
                #1867
                that's why people flip the TB, I guess. are you worries about lag from the extra 2 feet of IC piping?
                cars beep boop
                • kamotors
                  • Nov 2007
                  • 7102
                  #1868
                  no I'm not...its not 2 feet either its like 6". give me a few days and you'll see. plus in position 3 the flipped throttle hits the fluid res.
                  7speedshop.com
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #1869
                    when do you plan on getting the turbo?
                    • kamotors
                      • Nov 2007
                      • 7102
                      #1870
                      turbo and wg will be here friday, they shipped with UPS so its taking forever.
                      7speedshop.com
                      • MPLFoster
                        • May 2013
                        • 1490
                        #1871
                        Awesome progress so far. Can't wait to see the numbers this things puts down.
                        Any estimates?
                        form.follows.function IG @mplfoster
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #1872
                          I bet between 500-600
                          • kamotors
                            • Nov 2007
                            • 7102
                            #1873
                            500ish is my goal
                            7speedshop.com
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #1874
                              Originally posted by kamotors
                              500ish is my goal
                              Finish it and then tell the guys from Drive to comeback haha
                              • Sagaris
                                • Sep 2009
                                • 2243
                                #1875
                                In my experiences I was unable to get a smooth on/off throttle transition with the over-run fuel cut turned on and an M20 tps. (not a problem if you leave it off obviously)
                                Also, I had much better success tuning with the accel enrichment being TPS based rather than MAP based. MAP based would have required me to run a lazy lag factor in order to avoid a few random spikes setting off the accel enrich.
                                you know what you are doing though, just sharing what I have found on my megasquirt journey
