Kamotors E30-Turbo to ITB M20
  • BMW_TUNER
    • Jul 2006
    • 1386
    #3391
    Sumitomo HTR Z-II -- I presume ?
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • BMW_TUNER
      • Jul 2006
      • 1386
      #3392
      Originally posted by kamotors
      Staggered, I went 8.5" wide front. So i can still do u turns. I've run huge front wheels and it hurts turning radius. 8.5" is perfect front imo.
      Sent from my SM-N920T using Tapatalk
      18x9.5 isn't to bad but you have to get the spacing just right to get the turning radius back but I can still u-turn as tight as an e46 m3.
      • kamotors
        • Nov 2007
        • 7102
        #3393
        Ya At 17x9 et10 I only had 4mm strut clearance and just rub inner wells at full lock. At 17x8.5 et15 I have stock turning no rub. Im 18x8.5 et2 now so it will rub at full lock but I don't u turn too often. The 9.5" et2 front would have far too much poke for my liking.
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #3394
          Htr z111, cheap and enough meat that it shouldn't need to be a super racey compound to get some grip. Fronts are 245/35/18 poteneza's they look almost identical tread wise and have exact same o.d.
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #3395
            7speedshop.com
            • e30 gangsta
              • 3877
              #3396
              5 lug life
              • BMW_TUNER
                • Jul 2006
                • 1386
                #3397
                Spacers or suspension swap?
                • kamotors
                  • Nov 2007
                  • 7102
                  #3398
                  Back to 5 lug adapters, but this time studded ones.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3399
                    I did it. 285/30/18 no trimming to the standard width flares. I'll likely shave off a few mm from the inner lip though.
                    7speedshop.com
                    • BMW_TUNER
                      • Jul 2006
                      • 1386
                      #3400
                      Getting a bit of the pokey goodness .
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3401
                        Gonna need some bigger brakes lol
                        7speedshop.com
                        • LJ851
                          • 7919
                          #3402
                          That should work great as long as you don't have any suspension.
                          Lorin
                          The M30 is God's engine.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3403
                            Started trimming one side, also going to test some ultrawides on the rear.
                            7speedshop.com
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #3404
                              Why not go 5 lug?
                              1991 318i 4dr slick top
                              Mtech 2 turbo restoration
                              • kamotors
                                • Nov 2007
                                • 7102
                                #3405
                                Why not go 5 lug?
                                I may but this works for now
                                7speedshop.com
