Kamotors E30-Turbo to ITB M20
    • 34839
    #466
    Originally posted by kamotors
    I Have a weird surging idle now and not sure why. My valve cover was leaking after i did my head studs so I figured it was that but I replaced the gasket and it still surges and after a long drive it seems to still leak even after benign torqued multiple times..
    MS is pretty insensitive to vac leaks. Could be the ICV or just some idle settings that need tweaked.
    • kamotors
      • Nov 2007
      • 7102
      #467
      Originally posted by Sagaris
      Do you miss the NA character of the engine at all?
      no WAY:) I love how violent it is when boost hits it always keep you on your toes and and having fun.
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #468
        SO I think I'm just too lean at idle now although I'm not sure how my idle leaned out so much randomly. When cold the car runs fabulous, super smooth idle just a bit rich at 11-12AFR once warm I get to 15AFR and it becomes unstable and bounces.
        7speedshop.com
        • TheTacoMan
          • Nov 2011
          • 2308
          #469
          • kamotors
            • Nov 2007
            • 7102
            #470
            so whodwho got me a new tune that was a bit richer at idle and now its a smooth as can be, I lowered the acceleration wizard values a bunch and now its free revving response is also great.
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #471
              some new pics and a nice little burnout
              and a tiny burnout
              7speedshop.com
              • sayed ali
                • 762
                #472
                We need in car camera please!
                Great by Btw :)
                M20B28 Turbo
                My Build Thread
                http://www.r3vlimited.com/board/showthread.php?t=255839
                • kamotors
                  • Nov 2007
                  • 7102
                  #473
                  So I believe I'm having heat soak issues with my IAT sensor. I can drive all day and the car will run perfect but when I shut it off for around 15minutes and come back to it and go to start the car it gets a very lean unstable idle, runs pooey and feels very"flat". If I do one WOT pull the car goes back to normal. my meth spray probably cools the sensor off very quickly since it is with in a few inches of it. What can I do about this? my piping gets very hot after driving the car and then parking it for about 15-20 minutes.
                  It seems to be 100% heat related so I'm not sure whats up.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #474
                    also I did lots of burnouts and what not today.
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #475
                      well no matter what my valve cover was leaking after a drive, I've been messing around with it for a week and even replaced the gasket twice because I wasn't sure why it was leaking. Well today I took it off one more time to figure out why it was leaking once and for all and put a small amount of mega grey on the end of the gasket so it stops dripping on my manifold and smoking everywhere.
                      I Discovered that this issue was my valve cover vent hose was completely kinked in half. Obviously the lack of ventilation was pushing oil out of weird spots and also causing my turbo to smoke due to lack of vacuum.
                      All fixed now...I hope.
                      7speedshop.com
                        • 37832
                        #476
                        You have the Hallman Pro RX MBC right? I'm looking to buy one soon. Wondering how you like it?!
                        Classic BMW Specialists
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #477
                          The hallman pro RX is the BEST boost controller I've used and I love it, Its super easy to adjust and use and doesnt boost spikes ever. I used a turbosmart controller at first and it was garbage and would spike to 12psi when set fully open.
                          I'm also using a hallman in my subaru and its a great quality piece.
                          7speedshop.com
                            • 34839
                            #478
                            why not control boost with MS? closed loop boost control FTW - you can make your torque curve flat until redline.
                              • 34839
                              #479
                              there are two curves you can use to account for this, IAT correction curve and IAT correction %.
                              also, are you using an open element sensor?
                              • kamotors
                                • Nov 2007
                                • 7102
                                #480
                                oh cool i didn't know I could change settings to fix this; I'm using the GM open element sensor. Where exactly do I find where to change the setting?
                                So think I found the MAT correction map. so basically If I'm understanding right I would need to slightly increase the correction% for the hotter temps.
                                7speedshop.com
