Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #481
    OK so I believe MAT correction fixed the lean problem. It was seeing 140degree air after sitting for around 15minutes. Now it ran at 13.5AFR at idle when heatsoaked instead of 16afr.
    I increased the correction percent by 7% and it seemed to do the job.
    7speedshop.com
    • kamotors
      • Nov 2007
      • 7102
      #482
      Had an awesome day at Auto-X today. Car ran flawless and had tons of sideways moments.
      7speedshop.com
      • 325ix
        • Aug 2009
        • 7783
        #483
        I wish I had your problem. I'm bored because I have no monies!
        Car looks great! I would love a turbo e30 one day.
        • Mr. Tasty
          • Jul 2011
          • 3421
          #484
          why not incorporate the RSM studs with the bracket?
          2014 Alpine White 335i MSport
          (Daily Driver)
          Full Mperformance Aero
          KW V2 Coilovers
          VRSF Catless Downpipes
          • irish44j
            • 2763
            #485
            this project is looking great. I especially like that your wheel/tire/suspension setup is for max functionality and the tires have a lot of meat on them.
            Stage rally/rallycross e30 build/competition journal
            Track/street e21 build
            visit Condor Speed Shop
            visit Motorsport Hardware
            [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
            • kamotors
              • Nov 2007
              • 7102
              #486
              so I re grounded the wire at the shock tower and I'm still getting the code. I'm guessing that the harness normally grounds at the ECU correct? so I'm guessing the problem is with the heater power and I need to get it 12v of pow
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #487
                Getting spark blowout at 17psi and can only make about 15.5 in 3rd gear,I think my wastegate is leaking a bit.
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #488
                  http://www.youtube.com/watch?v=Cb1AtOuTrIAthe videos not too good but it shows the hesitation in 4th gear going 0-100.
                  7speedshop.com
                  • Cronopoulos
                    • Jul 2011
                    • 2187
                    #489
                    That looks killer, in for more pics of the finished product...
                    Project log -- DIRTY 30
                    2.7i * Megasquirt tuned * E85 powered
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      #490
                      apron is needed now
                      • Ian Bowers
                        • Apr 2008
                        • 1120
                        #491
                        More aggressive skirts, ACS rear valance, no mudflaps, and more wheel/less tire. My car was kinda similar at one point. :D
                        • kamotors
                          • Nov 2007
                          • 7102
                          #492
                          I'll get there eventually, really want some big wheels now.
                          7speedshop.com
                          • Zacm829
                            • Jan 2008
                            • 1919
                            #493
                            Yep some baller wheels will complete your car. Quick progress!
                            1987 325i-M60b44 swap
                            • kamotors
                              • Nov 2007
                              • 7102
                              #494
                              I think my turbo is dead my drain is still good, I have vacuum to the turbo inlet, a nd the feed has what I measured as a 1.5mm restrictor. It smokes like crazy at idle but not at anything above idle untill I let off and go into overrun and then it smokes quite a bit, enough to make cars behind me angry and have them go around me.
                              I'm first going to get a new oil pan and have a 3/4 fitting welded to it and run a bigger drain and if it still smokes I'll put the car out of commission for the season and save up a for a new turbo
                              7speedshop.com
                              • sayed ali
                                • 762
                                #495
                                Great idea
                                M20B28 Turbo
                                My Build Thread
                                http://www.r3vlimited.com/board/showthread.php?t=255839
