Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #526
    got my 2 step working. sounds mean, I just needed a new switch.
    7speedshop.com
    • FLG
      • Sep 2011
      • 3165
      #527
      Is setting up 2 step on a ms 2 v3.0 basically just a clutch switch and some software work? Or is it more than that.
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • ak-
        • 12422
        #528
        Did you figure out the WG issue?
        1991 325iS turbo
        • kamotors
          • Nov 2007
          • 7102
          #529
          still havent fixed the issue of low boost but I'm sure that will be fixed with a stiffer spring. I had whodwho setup the wiring inside megasquirt and all I had to do was run some wire to a switch and a 12v source. its best to use a clutch switch but you can do it with any momentary switch or even the ebrake if you wanted.
          7speedshop.com
          • FLG
            • Sep 2011
            • 3165
            #530
            Thanks...I'll have to get in touch with him. Wish I could be more helpful on the low boost problem but I'm fairly new to turbo charging
            • kamotors
              • Nov 2007
              • 7102
              #531
              so DMV has failed me once again, they took my plates and wont let me register the car until october because its failed smog in the last 90day...... not sure what to , might try getting it registered in a different county because non of the surrounding counties have smog laws.
              7speedshop.com
              • JasonBates
                • 265
                #532
                Carson would be your best bet.
                '87 325e 2.7i/5spd
                '02 Subaru outback (Still smells like dirty hippie)
                '86 635csi (Sold)
                '87 4KcsQT (Sold)
                '84 318i (Sold)
                • jaywood
                  • Jul 2010
                  • 4528
                  #533
                  That's very unfortunate man. :(
                  • kamotors
                    • Nov 2007
                    • 7102
                    #534
                    yeah I'm thinking carson or fernly
                    7speedshop.com
                      • 37832
                      #535
                      Wow, who would have thought that Nevada was more strict than California?
                      Hope you work it out!
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        #536
                        Mine did the same, so I registered it in my home town, had the tags sent to my mom, then changed my address back.. Tricky tricky.
                        2014 Alpine White 335i MSport
                        (Daily Driver)
                        Full Mperformance Aero
                        KW V2 Coilovers
                        VRSF Catless Downpipes
                        • kamotors
                          • Nov 2007
                          • 7102
                          #537
                          built a nice screamer pipe out of the stock I exhaust piping. it now dumps near my transmission/downpipe flexpipe area. still waiting on my new wastegate spring should be here the 12th all though the tracking info never got updated in the last week. car should be registered tomorrow out in fernley if everything goes according to plan.
                          7speedshop.com
                          • tigwerks
                            • Jul 2012
                            • 42
                            #538
                            How did you check for boost and exhaust leaks?
                            I keep my vehicles registered in lake tahoe for no smogs
                            • tigwerks
                              • Jul 2012
                              • 42
                              #539
                              I know how to do, just checking to see how you did it. I would make an adapter to psi the exhaust so you can check everything while the piping is cold, and spray soapy water like you do for the intake connections. its a much better way of doing it and you'll be suprised at how many leaks you may find. The same goes for the intake side of stuff. Generally pressurize the system from the intake or the beginning for the intercooler piping and again spray everything with soapy water. And again you'll probably be surprised at the leaks you'll find. Been through it way too many tims with people who say they have no leaks and i make an adapter or one ive laready made to psi there systems and it looks like a bubble bath everywhere.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #540
                                E30 registered finally:) first stop light I get to I flip on 2step, build wastegate pressure and then burnout away. new tires are awesome I got like an extra 10mph out of first because they are over an inch taller than my previous slightly undersized tires.
                                7speedshop.com
