Kamotors E30-Turbo to ITB M20
  • lambo
    Captain Scene Points
    • 10953
    #511
    I like the wheels! However I would rather have a little more dish or concave.
    Also, are you going to be running adapters for these?
    • kamotors
      • Nov 2007
      • 7102
      #512
      I'm local to adaptec so they are making me some 22mm adapters.
      7speedshop.com
      • ak-
        • 12422
        #513
        da fuq?
        Those aren't APEX!
        1991 325iS turbo
          • 37832
          #514
          Tires look pretty tall, what size on those?
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • kamotors
            • Nov 2007
            • 7102
            #515
            they are a bit over sized but the deal was soo good I had to buy, once these die I will get some in the proper height and much wider. they are 225/45's
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #516
              sooo E30 fired right up with the new setup, new turbo sounds amazing, my 2 step isnt engaging and about 5 minutes into my drive the the oil feed line to the turbo cracked and sprung a leak:( I guess 3 weeks of work and all my money dumped into it only gets me about 5 minutes of drive time.:(
              7speedshop.com
              • F34R
                sLaughter
                • 12376
                #517
                Don't worry man, shit gets bad but it will always get better. Your e30 is so nice! that paint is amazing, I cannot wait for nice paint on mine.
                I am planning on a GT37, how much power does the turbo you bought support?
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • jaywood
                  • Jul 2010
                  • 4528
                  #518
                  How did you do the oil feed? Off of the stock pressure sensor? Did you T into that line to get the gauge signal?
                  • kamotors
                    • Nov 2007
                    • 7102
                    #519
                    I just used my oil filter sandwhich plate, its very easy to setup. I was going to switch to the pressure switch spot but with all the fittings it wasnt cost effective.
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #520
                      got some new pics, more can be found here http://www.r3vlimited.com/board/showthread.php?t=260846
                      7speedshop.com
                      • jaywood
                        • Jul 2010
                        • 4528
                        #521
                        That fitment looks great! More pics plz....
                        • kamotors
                          • Nov 2007
                          • 7102
                          #522
                          more pics in the showroom thread here http://www.r3vlimited.com/board/showthread.php?t=260846
                          7speedshop.com
                          • ak-
                            • 12422
                            #523
                            Maybe the spring sold to you for the WG isn't the one advertised.
                            Though, fiddling with your BC should probably have you figure that out quickly.. Hmm.
                            Good luck though. You have a screamer pipe?
                            1991 325iS turbo
                            • kamotors
                              • Nov 2007
                              • 7102
                              #524
                              yup, its a screamer pipe but its not even opening:(
                              7speedshop.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #525
                                ok so I adjusted the boost controller to the lowest setting and it gives me a solid 4 psi and I can hear the wastegate open. Problem is I can only get it to around 11psi with the boost controller with stiff spring pretty close to maxed out. I have NO exhaust leaks or boost leaks did complete check of everything today. turbo is extremely loud at 11psi
                                7speedshop.com
