Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #1276
    20g at low boost will never break the wheels loose past first gear and gets boost at 2100rpms. I've never run any other small turbos but it sure kills a gt35 in the 0-80 but the gt35 was a bit faster for 60-120+
    7speedshop.com
    • silence
      • Jun 2007
      • 1824
      #1277
      Congrats on the Video-Article
      • Simple_Smith
        • Aug 2011
        • 585
        #1278
        Just read the entire thread and have watched your feature about 4 times now. Awesome build. Gives me motivation to get rolling on my build again.
        1989 JDM-Tech 2
        2010 335 D for daily
        • kamotors
          • Nov 2007
          • 7102
          #1279
          New tires mounted I'lll get pics n the morning, 235/40/17 Falkens rt615
          .5" smaller overall diameter
          same treadwidth
          .7 wider section width
          3lbs less weight per tire
          drives good, plenty of clearance still, does good burnouts.
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #1280
            poor quality garage pics at night
            7speedshop.com
            • Ray Smoodiver
              • Jun 2004
              • 8809
              #1281
              E30 COTY2013.
              Regardless of forum, this is the one that other E30's wanna be.
              • delamaize
                • Nov 2013
                • 1465
                #1282
                Your car..... so much hawtness...
                Last edited by delamaize; 01-03-2014, 08:20 PM. Reason: Autospell and autogrammar on my phone is derpy.
                Dumpster Fire Pilot
                  • 37833
                  #1283
                  Height of those tires looks much better! I like what you did with the lettering too.
                  Grover Beach, California
                  BimmerHeads.com
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5284
                    #1284
                    Looks really good. You make me second guess my dreams of 24v goodness.
                    Originally posted by priapism
                    Originally posted by shameson
                    • JCarp90
                      • Feb 2011
                      • 1759
                      #1285
                      That looks fantastic. Always wondered about white letter tires on your car.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1286
                        installed one AKG adjustable lower control arm "bushing" today, turned out to be huge pain. took a good 2.5hrs on one side:(, other side should take around 1hr because I have a puller setup that works now.
                        almost maxed out and didn't add as much caster as I thought it would. also not sure if there is enough of the control arm poking through.
                        7speedshop.com
                        • kronus
                          • Apr 2008
                          • 13032
                          #1287
                          you can get more caster with AKG camber/caster plates, if you're after it.
                          cars beep boop
                          • kamotors
                            • Nov 2007
                            • 7102
                            #1288
                            already have those installed and maxed out
                            7speedshop.com
                            • jute91
                              • Nov 2011
                              • 581
                              #1289
                              Good work Kameron :)
                              Also found on Facebook - Juuso Tero, Tampere
                              https://www.facebook.com/JuusosGarage
                              • Bullet Ride
                                • Dec 2010
                                • 598
                                #1290
                                Originally posted by kamotors
                                Does the wheel rub against the body at full lock?
