Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #661
    so worked for 3 hours trying to remove the subframe bushing with a puller and it only budged about 1mm and the flange lip on the lower part of the bushing has started to bend making it impossible to grip and remove.its 29degrees here and the bushing isn't budging.
    going to use some fire power tomorrow and hopefully get it out.
    7speedshop.com
    • acolella76
      • 2950
      #662
      I hope you take the subframe out before lighting them on fire... inches from the gas tank lol good looking build, keep up the great work
      -Alex
      • kamotors
        • Nov 2007
        • 7102
        #663
        of course.. going to drop it tomorrow.
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #664
          just an idea that seems as if it would work and save time in my head. my subframe is not stuck to the car its just the bushings being stubborn
          1-remove rear wheels
          2-remove differential
          3- unbolt the 22mm nuts that hold sub frame to body, my subframe drops down around 1" by doing that.
          4-I can now reach and remove the 2 trailing arm bolts on each side.
          5-subframe can be dropped straight down leaving trailing arms on vehicle being supported by jack stands. .
          this would easily save the hassle of undoing the hydraulic brake lines and messing with the stupid ebrake setup, sway bar and shocks.
          would this work? am I missing something that stops the trailing arms from being separated from the subframe with everything in the car?
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #665
            so decided to just remove everything in the rear, I have the subframe dropped down, differential and exhaust removed, just need to unhook brake lines and rear shocks now.
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #666
              I'm looking into ways to not only replace old bushing but improve my cars handling and I've been looking into lollypop bushings. In my head it seems that there is no way for my car to run more caster because if my thinking is correct I would simply run into clearance issues when turning with the fender liner. Am I right in assuming that clearance is decreased while turning with increased caster? or does the offset not effect clearance while turned?
              currently I hit my brake duct fender liner piece and also it appears I have left rubber on a pat of the valance.
              green x shows where I currently hit while driving spiritedly.
              going for semi- street legal race car build now.
              7speedshop.com
              • ak-
                • 12422
                #667
                I have somewhat beefy tires on my 16's and sold my offset polyurethane CABs because the increased caster would of made it hit the valance actually especially when turning. ):
                Doing polyurethane e36 CABS instead.
                1991 325iS turbo
                • ak-
                  • 12422
                  #668
                  Can't remember if you've already switched out your race springs already but maybe consider GC camber/caster plates when you're able to? Get caster as near as possible without hitting stuff under your fenders or something. I already had to bang out 1/4" in the wheel well from rubbing on spirited driving.
                  1991 325iS turbo
                  • kamotors
                    • Nov 2007
                    • 7102
                    #669
                    yeah I'm contacting AKG about there adjustable lolipop bushings. If they can be set close to stock I think i can get them to work.
                    7speedshop.com
                      • 37832
                      #670
                      Ditch those tall ass tires! Go to a 235/40 or something like that.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #671
                        I got these tires for free so I like them:) also most 235/40 tires only have a tread width of 8.5", that's close to a half inch skinnier than my current tires. For my next set of tires I need something to fill my flares. A 245/40 would have a bit less sidewall but even then tire rack is showing that most are either the same width or only .2" wider.
                        no brand seems to make wide but short sidewalled tires that are under like $300 a tire.
                        My re070's run WIDE, they hang off the rim lip almost 1/4" and the sidewalls are super stiff.. They are no doubt the BEST tires I have driven on.
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #672
                          SO I got my subframe bushings out and new ones in only to discover my trailing arm bushings are completely dead.:( so now i have to wait for more bushings.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #673
                            got my trailing arms off. just waiting for my poly trailing arm bushings.
                            also a quick question is do the revshift poly subframe bushings require the washer that sits above the stock bushings. reason I ask is because it does not fit around the metal sleeve on the revshift bushings.
                            7speedshop.com
                            • e30vert
                              • Jan 2005
                              • 1789
                              #674
                              Are these caps able to be painted to match the body color? With perhaps self etching primer and then base coat /clear coat?
                              • Denny
                                • Jan 2010
                                • 822
                                #675
                                Originally posted by kamotors
                                S
                                Memories...LOL... funny but not funny! Get her done :) I used all POWERFLEX everywhere I could... kind of job you want to do once.
                                Denny
                                ___________
                                1990 BMW red 325IC M30B35 all stock Girlfriends ride
                                1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                                Blogs:
                                http://bmw325e30.blogspot.com/ (restoration)
                                http://bmw325e30turbo.blogspot.com (Twincharge M20)
                                http://bmw325e30m62b44.blogspot.ca/
