Kamotors E30-Turbo to ITB M20
  • NYSE30
    • Nov 2013
    • 166
    #1411
    First off beautifully done e30, but I can't help but wonder what it would look like if the fender flares were painted body color...especially with your new wheel setup.
    • kamotors
      • Nov 2007
      • 7102
      #1412
      I've p-shopped them body color plenty of times,I like them black the best, plus leaving them unpainted means I dot have to worry about rock chips or scratches.
      7speedshop.com
      • golde30
        • 11464
        #1413
        Looks fuckin beefy. Awesome.
        IG: @Baye30
        • kamotors
          • Nov 2007
          • 7102
          #1414
          UUC BBK issues all day everyday.
          Had vibrations so I reinstalled it all. Retorqued insured that the caliper was centered. I rebed the pads, around 1-2 miles later coming to an intersection my brakes failed, pedal went to the floor and I couldn't stop, I Pumped the brakes and it built pressure and stopped, I pulled into the gas station and the right front rotor was smoking and crackling.
          they were smoking
          7speedshop.com
          • Jb325is
            • 2137
            #1415
            Were they dragging? Whats up with the groove at the top of the pad?
            I considered these briefly because of price but I'll be buying Massive stuff I believe
            Oh and new wheel/tire setup is on point! Well done
            - '88 m54 coupe
            <3
            • kamotors
              • Nov 2007
              • 7102
              #1416
              the pads overhang the rotor it seems, dont think they were dragging as the car rolled very straight and smooth without hesitation.
              7speedshop.com
              • LJ851
                • 7919
                #1417
                Thats really hot!
                A dragging brake is just about the only way to build up that much heat on one side only.
                Whats up with the worn down section of one anti rattle spring?
                Lorin
                The M30 is God's engine.
                • Jb325is
                  • 2137
                  #1418
                  Originally posted by LJ851
                  Thats really hot!
                  Probably popped out at one point and drug on the rotor, I think that's a problem with these. I've heard of it happening before.
                  - '88 m54 coupe
                  <3
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4504
                    #1419
                    How do you like the Comp 2s? I have been eyeing them up in a 255/45, but can't seem to find a solid reviews on them from an enthusiasts perspective?
                    • ScHpAnKy
                      • 1573
                      #1420
                      omg the new wheels look awesome man
                      91 318i | 87 535iS
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1421
                        those anti rattle clips are the stupidest thing ever, you can bend them into a nice sharp V, tighten the ends so they have tons of tension and around 10 miles later they will fall into the rotor.
                        When I received the kit about 2 were in the caliper and the rest was just loose in the bag.
                        I've been messing with the brakes since earlier today.
                        I went with willwood 600+ fluid ran 32oz through the system to ensure its good and the brakes are working again just fine(except the massive vibration).
                        Fluid removed from the passenger side(the smoking blue side) was around 4 or 5 shades darker than the fluid on the driver side. Its all a nice yellow now but the amount of trouble this kit is causing is unbelievable.
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1422
                          Installed a 16mm rear sway bar today, definitely helped keep things flat without being too stiff. rear end sits a tiny bit taller but thats fine.
                          also UUC is shipping me a replacment rotor and hat so hopefully that fixes the issue.
                          7speedshop.com
                          • MPLFoster
                            • May 2013
                            • 1490
                            #1423
                            Love the new set up man. Very nice.
                            form.follows.function IG @mplfoster
                            • Jb325is
                              • 2137
                              #1424
                              If the rear sits higher the swaybar is binding.. Did you get adjustable end links?
                              - '88 m54 coupe
                              <3
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1425
                                They arent adjustable and seem to be the same length as stock just with nicer bushings , the bar moves freely up and down and is perfectly centered. The wheel is held up a touch higher when jacked up and it doesn't droop as much when on the ground I'm talking like maybe 1/4" something that most people probably wouldnt notice.
                                7speedshop.com
