Kamotors E30-Turbo to ITB M20
  • MF DOOM
    • Apr 2012
    • 944
    #1156
    How did you install the injector for your meth? Just thread it in like they say or did you use a jb weld or something to set it in? Im skeptical about just threading it into the charge pipe..
    • LowR3V'in
      • 4209
      #1157
      Mine is screwed in the pipe. Pressure test to 30psi, no leak.
      • TheTacoMan
        • Nov 2011
        • 2308
        #1158
        I would use apoxy if you go this route, Jb weld holds for a while.
        Ive had some experience with this and Iat sensors.
        • kamotors
          • Nov 2007
          • 7102
          #1159
          Mine is threaded into a threaded bung that's welded to the charge pipe, I've had bad luck with JB weld.Actual welding was the only fool proof way with no worries.
          7speedshop.com
          • Luis325
            • 3847
            #1160
            This thing has to be a beast to drive///
            1986 "C2 2.7 Alpina" Sedan
            1987 325ic Black Vert
            • kamotors
              • Nov 2007
              • 7102
              #1161
              car needs a valve adjustment again, its needed one every 1k miles lol, too much revlimiting,2 step and revving to 7300rpms daily. Then I'll probably get it up to 18psi and see how it performs. Its usually just one or 2 that get knocked out of adjustment but this time they are all pretty loose.
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #1162
                some fall photos
                7speedshop.com
                • whodwho
                  • Jun 2008
                  • 1547
                  #1163
                  Originally posted by kamotors
                  some fall photos
                  There is something about this pic that makes them look like matchbox toys 8^)
                  My M20 Frankenbuild(s)
                  4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                  • Peattie
                    • Apr 2013
                    • 260
                    #1164
                    I was just about to say the same thing. Blakes car looks like a toy
                    • silence
                      • Jun 2007
                      • 1824
                      #1165
                      Nice pics, if you have any close ups send them to condorspeedshop@gmail.com to be considered for next years 2014 calendar.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1166
                        Car is running awesome, some big things happening soon, you'll see it on youtube in about 1 month.
                        Rear window tint removed which took 3 days, completely detailed the interior, replacing the windshield later this week. Installed the 3.73LSD which has a few issues but seems to be working now also cranked up the boost to 19psi which is amazing.
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1167
                          lots of WOT tuning today. Did 7 virtual dyno/datalogs-retunes, all which resulted in a better AFR but consistently dropped in power, noticed it was heat soak. Finally got the AFR dialed in and its feeling great.
                          new timing map,fuel map, Baro correction dialed in better, MAT correction dialed in, and smoothed out the lumpy idle a bit.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #1168
                            well some somewhat not good news.
                            *Rear diff groans on tight turns with clutch out.
                            *replaced windshield and they messed up my paint and the new gasket, but i guess its better than a huge crack.
                            * rock hit turn signal cover cracking it, and burning out bulb, replaced bulb and it still wont work, its all plugged in as well.
                            7speedshop.com
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #1169
                              YO BRO.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1170
                                texture painted valve cover, MSD coils, fresh VC gasket and retourqed the head.
                                7speedshop.com
