Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #1006
    new turbo in:D
    7speedshop.com
    • downforce22
      • Aug 2009
      • 3193
      #1007
      Nice. I think the fenders would look better color matched
      • kamotors
        • Nov 2007
        • 7102
        #1008
        new turbo in:) might spool too quickly not sure yet, but I get 1 psi at 6500rpms in neutral.
        tdo6 20g with 10cm housing water cooled and antisurge ports. its a kamak kinugawa, excellent service, fast shipping and awesome product
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #1009
          ok so car is super fast now, not even comparable to before. I creep into boost at 2100rpms and now full boost at 4100rpms of 19psi I picked up enough torque to break the tires loose just rolling into boost. its insane, new dyno probably tomorrow evening.
          7speedshop.com
          • Dj Buttchug
            • Jun 2010
            • 7688
            #1010
            this is where you wanna be at.
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • lambo
              Captain Scene Points
              • 10953
              #1011
              I'm mad jelly...
              • e30nub
                • Jun 2008
                • 1741
                #1012
                Originally posted by Dj Buttchug
                this is where I wanna be at.
                -Pierre
                1987 535is
                1988 325is
                • Cambiocorsa
                  • Jun 2013
                  • 47
                  #1013
                  Sounds awesome, that is a lot of torque down low! How much boost can a 20g push efficiently? Car looks incredible.
                  • kamotors
                    • Nov 2007
                    • 7102
                    #1014
                    handles more boost than I'll be running, its a pretty efficient turbo, most who run the td06 20g run them in the 25-30psi range.
                    7speedshop.com
                    • FLG
                      • Sep 2011
                      • 3165
                      #1015
                      Damn. Do they have an internally waste gate model?
                      Sent from my Galaxy Nexus using Tapatalk 2
                      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1016
                        yes they do, they are an awesome brand and highly regarded in the subaru and evo world.
                        I got email replies within 12hours and it was shipped out within 24hrs.
                        7speedshop.com
                        • FLG
                          • Sep 2011
                          • 3165
                          #1017
                          Where did you order from? Is there any further specs I should know or if I tell em that model that's it? I And if you don't mind my asking how much?
                          • kamotors
                            • Nov 2007
                            • 7102
                            #1018
                            I ordered directly from their page(cheaper than ebay). It also includes a bunch of goodies.
                            and specs
                            Application 1.8~2.5L petrol engine / 300~450 HP
                            Bearing Type Journal Bearing / Performance Thrust Bearing Kit with larger thrust ring and flinger.
                            Cooling System Water cooled
                            Compressor Wheel 52.5 mm / 68 mm (20G wheel)
                            Turbine Wheel 61 mm / 54.1mm (TD06SL2 wheel)
                            Turbine Housing 10cm
                            Turbo Boost Limit 2.8 Bar (Based on Performance bearing kit with larger thrust bearing )
                            Condition Brand New
                            Kit includes -1 x Oil feed line kit ( 70cm Braided Line )
                            -1 x Oil drain pipe kit
                            -1 x T3 Turbine Inlet Gasket
                            -2 x 20cm 6AN Water Line Kit
                            (Everything shown on picture included)
                            Warranty 1 year
                            Also the exhaust is a 2.9" vband with a inner lip that seals up so you need to weld that to a 3" vband to fit a 3" exhaust(its really easy and what I did if you look closely.) the compressor housing uses a snap ring which is annoying but easy if you have one of these. which is less than $5 at harbor freight
                            I'm running mine with a -12an drain.
                            7speedshop.com
                            • FLG
                              • Sep 2011
                              • 3165
                              #1019
                              Thanks
                              I checked the site and only found external waste gated ones, some internal waste gated ones but they also have a built in bov which I don't need.. Guess I'll have to email them?
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1020
                                built in BOV?
                                EDIT just looked thats wierd.
                                I've never seen a turbo like that
                                DOUBLE EDIT, I believe i see a BOV block off plate
                                7speedshop.com
