Kamotors E30-Turbo to ITB M20
  • alex1979
    • Jul 2012
    • 19
    #1141
    Originally posted by kamotors
    only advise for the head gasket is make sure you clean teh block extremely well, I use parts cleaner and a razor blade. Also I find it not only the easiest but also quickest to bolt the intake manifold and turbo manifold to the head and drop it in like that, makes the oil return tube a piece of cake. will likely need an extra person to help line it up though.
    Sounds good. i will definitely try that. Thanks for the help!
    • kamotors
      • Nov 2007
      • 7102
      #1142
      head swap only takes a couple hours that way.
      7speedshop.com
      • alex1979
        • Jul 2012
        • 19
        #1143
        Do I need to take the head to a machine shop for shaving, it did not over heat or any thing like that. Which head gasket to get? I see mix reviews about gotze being the oem supplier, but then i hear that it's not as good as the oem, Sounds like a contradiction.
        I adjusted the bov , and so far the problem seems to have cleared. i had to set it to harder.
        So how much boost you running now, and for how long without blowing a gasket, I seen you had a couple blow on you. I started like you, automatic turbo. Got a good deal on a complete manual conversion kit, so the auto didn't last long. The auto tranny held well though.
        • kamotors
          • Nov 2007
          • 7102
          #1144
          I got bored
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #1145
            highest elevation auto-x in America. 8200ft. tons of issue at first with barometric correction but got it dialed in. nothing like bashing a $500 front valance into cones:)
            turned into turbo E30 drift/revlimiter party. I probably spent 10seconds of each lap bouncing off the limiter while burning out because gravely pavement.
            7speedshop.com
            • Denny
              • Jan 2010
              • 822
              #1146
              Wow cool pic man. Car is looking great! love the red alpina design...you should get bored more often...lol...
              Denny
              ___________
              1990 BMW red 325IC M30B35 all stock Girlfriends ride
              1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
              Blogs:
              http://bmw325e30.blogspot.com/ (restoration)
              http://bmw325e30turbo.blogspot.com (Twincharge M20)
              http://bmw325e30m62b44.blogspot.ca/
              • MF DOOM
                • Apr 2012
                • 944
                #1147
                hawttt. Whats your suspension set up?
                • kamotors
                  • Nov 2007
                  • 7102
                  #1148
                  H&R race w/ no front spring pads and e90 drop hats up front
                  7speedshop.com
                  • Ray Smoodiver
                    • Jun 2004
                    • 8809
                    #1149
                    ALPINA vinyl ordered today, ships from New Zealand but should be here in a week or two.
                    Do you have a link to purchase?
                    • kamotors
                      • Nov 2007
                      • 7102
                      #1150
                      tahoe drive today, was fun for a bit but got boring.
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1151
                        so on the 100mile drive which was 50miles of fast freeway, 15miles of cruising backroads an then 35miles of twisty downhill mountain roads, I managed just under 26MPG! I think my tune is finally finished, I've got a good amount timing, almost perfect AFR at every single load. I spent a good amount of time at 80+mph kissed around 130mph and still managed great gas mileage. The 3.15 rear end really makes freeway driving awesome, 5th gear cruising keeps RPMs really low. every other turbo E30 used about 1/2 a tank I hardly used a 1/4tank.
                        7speedshop.com
                        • downforce22
                          • Aug 2009
                          • 3186
                          #1152
                          that is awesome, are you running the whodwho pnp setup?
                          I'm excited to get my iX running. The 3.64's should a nice change form the 4.10 I have in my daily
                          • Sagaris
                            • Sep 2009
                            • 2243
                            #1153
                            Are you using Simple/PID EGO control?
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #1154
                              3.15 is awesome, but I need more tuning. I used 1/2 tank.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1155
                                yeah I turned ego control on after I got it pretty much tune spot on, just so it can make minor changes to keep things nice and steady.
                                7speedshop.com
