Kamotors E30-Turbo to ITB M20
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #2656
    So do you plan on running alpha n with your itbs? Or your gonna add a plenum so you don't have to switch it over?
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • emerson.
      • Jun 2012
      • 482
      #2657
      Just dont forget to tighten it and thread lock it :giggle::giggle:
      this needs to be on this page too
      Originally posted by LowR3V'in
      It's in the name e30tech not e30offtopic
      • kamotors
        • Nov 2007
        • 7102
        #2658
        probably alpha N, the ITB's include a new TPS that I believe is variable unlike the stock TPS i've been running for years.
        But I will be doing a plenum after this auto-x season so I can be ready for boost.
        Block is ready for a fresh coat of paint, oil pan is ready to be tapped, and head is ready to install the new cam and rocker arms. Too bad I never have time to work on the car.
        7speedshop.com
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #2659
          You doing a cf or aluminum plenum
          • digger
            • Nov 2005
            • 6197
            #2660
            yeah when running NA i would do alpha-N or alternatively MAF once you have a plenum provided there is enough space and you arent using a big duration cam etc
            • kamotors
              • Nov 2007
              • 7102
              #2661
              Block finished
              7speedshop.com
              • digger
                • Nov 2005
                • 6197
                #2662
                bog stock b25 bottom end?
                • kamotors
                  • Nov 2007
                  • 7102
                  #2663
                  Yes because it will be boosted eventually. That's why I went with the milder cam as well. Just want to eventually replicate my last m20 only better.
                  7speedshop.com
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #2664
                    Just don't get all crazy and run 22psi and crack the block. I'd do some building before I ran 22psi
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #2665
                      john@m20guru.com
                      Links:
                      • Bullet Ride
                        • Dec 2010
                        • 598
                        #2666
                        So is your plenum going to bolt directly to the throttle bodies without the trumpet spacers?
                        Just wondering because the trumpet spacers aren't o-ringed like the throttle bodies are.
                        You'll probably need a gasket in there if you are planning on using them.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #2667
                          Originally posted by ForcedFirebird
                          Iirc he was running mad amounts of boost on a stock bottom end when his block when kaput
                          • kamotors
                            • Nov 2007
                            • 7102
                            #2668
                            these trumpets will not work with my plenum it will have bolt on adapters for the ITBs, then couplers to the plenum. like this
                            the plenum at the least will have aluminum base plate with welded on stacks, possibly a Carbon plenum but more likely just aluminum.
                            installing a gasket vs. oring would be like a 10seconds conversion. just make gaskets similar to how the stock manifold bolts to the head.
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #2669
                              block cracked because I blew the headgasket at 25psi.
                              but it wasnt the boost that cracked it; it was because I drove over 5 miles without coolant to get the car home lol.
                              7speedshop.com
                              • sayed ali
                                • 762
                                #2670
                                Hhhhhh lol
                                M20B28 Turbo
                                My Build Thread
                                http://www.r3vlimited.com/board/showthread.php?t=255839
