May the gods have mercy on my soul
'91 318is, 16V swap.
Originally posted by csermonet47 View PostAbout damn time!
Originally posted by codyep3 View Postloookking damn good. Sounds even better.
Originally posted by Pantless Spency View Postyes finally!!!!
Originally posted by dashboardmonkey View PostThat thing sounds pretty nasty
Originally posted by dnick View Postbee on look out burnout v2.. adjusted a couple things.. spencer and i will bring yall a better one
Originally posted by lambo View PostMay the gods have mercy on my soul
Originally posted by davi tech View Postlove it!
Originally posted by dnick View Postlol im in your sig. sweet.
Originally posted by FunfGan View PostWell it was a damn nice shot ahaha. A little editing and boom.
Originally posted by FunfGan View PostI ended up using a Holley FPR. I'll try to find the link if you're interested, but should be fairly easy to find on Summit. Anyway, It doesn't have a gauge port(bit disappointing) but it works quite well and has a return line which is very nice, if not essential because of the amount of pressure it would need to hold with no return.
Sounds great! Thanks for the extra motivation
Do you still have open headers? Or how did you run your exhaust on the driver side?Current Moneypits: e36 m3/4/5 Turbo Techno
1961 Cadillac deVille bagged - IG @bryang513
Originally posted by ballski View Postok I figured I'd try to get one with a gauge, but yes the return line is necessary since we're going down to ~7psi from ~50 lol
Well I was told I didn't need one with a return line, but er, I'm assuming that's why the first FPR I had failed on me after a few drives. If you have any more questions, feel free to ask!
Here's the first part of my suggestion/ help guide for the swap. I have a lot of other things to add, just short on time at the moment. I'll update when I can!
Engine/ Driveline:
1. Buy engine/ bellhousing/ trans together, this cuts down on the chance you may accidently(or be lied to) buy the wrong trans or bell housing.
2. Don’t be scared of the wiring, it’s really not as difficult as it seems.
3. Trim down or cut off the CSB mounts, that will provide much more room for the driveshaft, even if it’s just piece of mind for an emergency.
4. 3.73 is a perfect street/ track gear. However, if you’re looking at a lot of highway miles, it may be a bit too low of gearing, so look into alternatives.
5. If at all possible, use Explorer accessories. If you’ve read my thread, you realize the issues I’ve run into with clearance from the rad to the water pump pulley.
6. If you’re running a skidplate, it must be meant for an M42 and you must remember to notch a hole so you can change your oil. Also know that the top power steering bolts will be inaccessible once the engine is in, so install it before hand.
7. An early model, m20 rad is you best (stock) bet. I then used an inline filler cap from Morroso. I ran a random, universal overflow from Summit Racing.
8. Make the core support removable BEFORE you start putting the engine in. There are a number of ways to do this, just search google. This allows you to much more easily install the engine/ trans combo(albeit, we were able to do it multiple times, but it takes about an hour and involves lots of anger and swearing).
9. Ideal driveshaft diameter is 3”.
-Wiring:
1. Again, it’s not as difficult as it seems. Just go over the diagram a few times, and go for it!
2. Don’t be surprised if you need to buy 2 or 3 engine side c101 connectors. Not all cars had the correct pins that I needed to do FI wiring. Alternatively, you can simply order new pins from BMW.
3. Cheapest way to wire the tach is to cut the control wire straight off the connecter, then run it back in the loom to the distributor and tap into the ground wire.
4. As with any swap, wiring can be a bit messy, even after clean up. Tuck all the light/ horn wires before you start to keep clutter down.
- Brakes:
1. I recommend keeping away from Remote Mount Booster setups for a number of reasons(go boosterless if you can find the kit), but if you must go the remote mount route, junkyards will have the full setup for much cheaper. Also make sure to grab the ENTIRE assembly.
- Pedal assembly:
1. The ideal setup is to skip the entire Wilwood kit, and simply order a full pedal box, and separately order the Wilwood slave cylinder. If you go that route, ignore the rest of this section’s suggestions.
2. Instead of ordering the whole Wilwood kit, you can get away with ordering just the slave cylinder and modding the attachment point on the stock clutch pedal to have enough throw to fully actuate the slave cylinder.
3. If you do use the whole Wilwood kit, make sure to reinforce the mounting points and the sheet metal surrounding it.
Shifter/ Clutch:
1. While the shifter lines up fairly well in the stock shifter cut out, it’s not perfect and will most likely not allow full access of all the gears. To fix this, I cut a square chunk out of the trans tunnel in front of it, and then riveted and sealed a new piece with circular notch in front of it. Follow this up with a spare grommet to keep water/ noise/ exhaust out.
2. Make sure to cut down the corner of the clutch fork to prevent binding on the trans tunnel. This may even void the need to hammer that section of the tunnel out, providing much more room for the new gas pedal.
3. The stock t5 shifter is 2 piece. The top piece sits at an angle towards the driver. Because of how high the shifter sits, this can become annoying and also get a little too close to the steering wheel. To solve this, simply cut and weld to your desire!
Originally posted by ballski View PostI'm not familiar with setting up cooling systems. So you used the inline filler and a separate overflow tank?
Thanks for all the great info man; it's much appreciated
Originally posted by eurotrash View PostJust an fyi you dont have to run a return but you have to use a fpr designed as a deadhead fpr. Also you already have a return setup. Its easier on your fuel pump and better mileage. Please get a quality fpr. Ask funfag why.
Inline filler setup:
Added some stickers
Had this digital voltmeter installed
Overflow setup.
