'91 318is, 16V swap.
  • shEck3lls0
    • Jan 2011
    • 1154
    #766
    Originally posted by eurotrash
    If i remember right the 2 white wires are connected. I think there was a green wire that runs to a resistored 12v (its the bat light on the mustang) it wont charge from what i read if the resistance isnt right. Black and yellow wire ran to distro block and the other like 10 gauge ran to the hot lead on the starter. Odd thing was it would only charge if it was run to the starter. If i ran it right to the distro block it wouldnt charge. Then it just stopped charging. Not sure if it was wiring or the alt just died.
    Very interesting.... I have it straight to the distribution block. I'll try it to the starter as well as redo the green wire.
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
    • sticksdaman
      • Apr 2005
      • 2987
      #767
      Did she ever make it to bimmerfest? I was looking but didn't see it.
      Wouldve been nice to see another e30 with my wheels on.
      Originally posted by ebelements
      Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
      • FunfGan
        • Jan 2011
        • 4958
        #768
        Nope :/ My friend went to adjust the clutch throw and the slave cylinder broke.
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • jalopi
          • 2370
          #769
          eh? what do you mean, broke? as in your new(ish?) wilwood slave? how do you even pull that off?
          • ballski
            • Jun 2012
            • 345
            #770
            i read through this but maybe I missed it. What fuel pump are you using? If stock, are you just restricting the 40-50 psi down to 7 by the carb with the fpr?
            Keep it up man, I have the same thing going on
            Current Moneypits: e36 m3/4/5 Turbo Techno
            1961 Cadillac deVille bagged -
            IG @bryang513
            • Thizzelle
              • 4422
              #771
              is this real?
              "I wanna see da boat movie"
              "I got a tree on my house"
              • FunfGan
                • Jan 2011
                • 4958
                #772
                I ended up using a Holley FPR. I'll try to find the link if you're interested, but should be fairly easy to find on Summit. Anyway, It doesn't have a gauge port(bit disappointing) but it works quite well and has a return line which is very nice, if not essential because of the amount of pressure it would need to hold with no return.
                Originally posted by Thizzelle
                is this real?
                yus.
                So, burnout video tomorrow. I'm not home, but my friends took one on the way back from Mpact yesterday.
                Go here be happy!
                • FunfGan
                  • Jan 2011
                  • 4958
                  #773
                  Burnout: http://youtu.be/kXnmMHk5iT0
                  I don't know why embedding never works on R3v...
                  Go here be happy!
                  • JasonC
                    Site Manager
                    • 14451
                    #774
                    It works, you need to paste "kXnmMHk5iT0" out of the youtube link.
                    1992 BMW 325iC
                    1978 Chevrolet Monte Carlo
                    • FunfGan
                      • Jan 2011
                      • 4958
                      #775
                      Ohhhhh, I was trying the different ones on Youtube, but sweet, thanks Jason!
                      Go here be happy!
                      • csermonet47
                        • Jul 2009
                        • 937
                        #776
                        About damn time!
                        Are Three Vee
                        Dad Spec
                        • Mr. Tasty
                          • Jul 2011
                          • 3421
                          #777
                          loookking damn good. Sounds even better.
                          2014 Alpine White 335i MSport
                          (Daily Driver)
                          Full Mperformance Aero
                          KW V2 Coilovers
                          VRSF Catless Downpipes
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7283
                            #778
                            yes finally!!!!
                            • dashboardmonkey
                              FUCK YOUR WAFFLES
                              • Jun 2008
                              • 6158
                              #779
                              That thing sounds pretty nasty
                              -Andy
                              • dnick
                                • Apr 2011
                                • 1377
                                #780
                                bee on look out burnout v2.. adjusted a couple things.. spencer and i will bring yall a better one
