91' 318is S52 Swap "The Beast"
  • fight4life28
    • Apr 2014
    • 821
    #646
    Looks good, got a very similar coilover kit i just brought from r3v facebook, though non shorten coilovers.
    • Northern
      I like cupcakes & sh!tboxes
      • 5288
      #647
      Looks like the coilovers are coming along well!
      Originally posted by priapism
      Originally posted by shameson
      • s14brent
        • Mar 2014
        • 574
        #648
        i would have totally sold you my front gc setup since I won't need it any more. curious. what did you do for the rear coil setup? Sucks because that's the only part I need to keep after going 5 lug
        89 325i 4dr s52
        02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
        21' Toyota Tacoma TRD OR 4x4 6 speed Manual
        • craiggroves91
          • Oct 2009
          • 3024
          #649
          Dang, too bad. Just missed you.
          I just have the classis coil over sleeve and adjuster on there now. Just going to change the shocks out to the Mustang konis
          Sent from my SM-N920V using Tapatalk
          1989 BMW 325i SOLD
          1998 BMW Estoril Blue e36 M3/4/5 SOLD
          1987 BMW 325 (The Piece) SOLD
          1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
          • fight4life28
            • Apr 2014
            • 821
            #650
            got some info or pictures of the setup?
            • craiggroves91
              • Oct 2009
              • 3024
              #651
              Got the Mustang top adjustable konis a few days back. My modified rsms slid right on and are ready to go.
              Wondering if I'll need to remove the bump stops or at least trim them down. Might not be able to know that until I try them on.
              Still trying to figure out rear trailing arm situation. I'm not sure if I want to add toe and camber correction or just replace bushings.
              1989 BMW 325i SOLD
              • 2mAn
                Señior Mod
                • 21093
                #652
                Definitely add the camber corrector kit. What model # are the Konis?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • craiggroves91
                  • Oct 2009
                  • 3024
                  #653
                  Okay I guess I will. Cause you said so
                  8041-1186SPORT for rear
                  1989 BMW 325i SOLD
                  • pandaboo911
                    • 2070
                    #654
                    I had the 1186 sport. They are pretty good. Rated for max. 650lb spring, which is what I was running. I had to run them fully stiff most of the time otherwise it'd be too bouncy.
                    Def need camber adjusters, gonna have like -3 in the back otherwise.
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      #655
                      Awesome! I'm at 700lb in the rear so I'm hoping they cope well. Would the 50lb difference be enough to mess things up?
                      1989 BMW 325i SOLD
                      • pandaboo911
                        • 2070
                        #656
                        Not really, you'll just get more bounce and not be able to use most of the adjustment range. I switched to Koni DA, which eliminated the bounce altogether and the ride is improved a lot.
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          #657
                          I imagine the bounce will be less prevalent than it is now with my who knows how old/possibly blown bilstein HD's? haha
                          Yeah, I can't afford those DA's, but I really wanted them. Good to hear you have used the 1186 I couldn't find much info from people who used them with higher rates.
                          1989 BMW 325i SOLD
                          • pandaboo911
                            • 2070
                            #658
                            I started on Bilstein Sport, and the bounce was downright dangerous on mountain roads. The car would bounce around and before you know it you're in the other lane. The DA's are not worth the price IMO, more than double the price just for rebound adjustment.
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #659
                              haha yeah, I've had some scary moments with the rear bouncing.
                              Well, then it looks like I made the right choice. What about your front setup?
                              1989 BMW 325i SOLD
                              • pandaboo911
                                • 2070
                                #660
                                Front is still 400lb spring / Koni SA (ix)
                                Meant to say DA is not worth it for comp. adjustment.
