14 years - 1991 325ix, Stroker/5-Speed (N52 swap?)
    yeah, I wanted the 21mm version, but ended up with the 23mm instead. the 21mm version came on E46 323i's and is plenty stiff enough in relation to the stock 17mm front bar. I'll probably want to couple it with a 17-19mm rear bar so the ratios don't get out of wack.
    pretty much it should bolt right up, but I need to find (or make) a bushing first, and I also need a set of the bushing brackets to test fit with.
      Great read. I just figured out you're Chris325iX... lol.
      I got my iX the same time you did.
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
        really? yours looks like a pretty much ground up resto. I bet at this point, yours is probably nicer than mine! :)
          lemme just say, i like this thread. so much info. not that I would attempt any of them. but I'm surely impressed by this.
          89 E30 S52
          Transaction Feedback.
            Fantastic write-up and beautiful car! Great workmanship too!
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
              This thread is so gangster
              1991 318is - Sold
              1986 325 - Sold
              Instagram - Lamoursum
                I think I just realized something...your username on e30tech. You have helped me out quite a few times over there!
                Amazing car. It's good to see you still have interest in it after 10+ years!
                  Maybe you'll like this:
                    what springs did you switch to when coming from h&r?
                      Hmm - I can't figure out what you're doing to that cluster...
                        always been fond of your ix nando..
                        :up:
                        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                          Working on your parts and decided to see if you have a build thread. Low and behold. Always loved your car.
                          john@m20guru.com
                          Links:
                            I really have nothing to say but amazing build. Clean and thought out to perfection. Love it
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
                              Molesting it :p
                                eventually I'll update the 2012 post, but finally some progress being made on my suspension V3.0
                                Courtesy of John at WOT tech (forcedfirebird)
                                the struts actually cleaned up pretty well. unfortunately, the hubs were trashed (damaged threads). That explains this picture:
                                new hubs are about $200 for the pair...
