the Aluminum Monster. a 318 with a special 24v
  • 2mAn
    Señior Mod
    • 21050
    #901
    I really wanted this post to be an update with the shifter installed but I hit a small roadblock yesterday; getting to the bitch clip...
    I've already removed the trans brace and also removed the nuts and bolts that attach the giubo to the driveshaft to allow the tranny to tilt and get some angle but the tranny isn't moving.
    Do I need to remove all 6 of the nuts and bolts on the giubo, or should I loosen the motor mounts? Any other tips?
    I'll be heading to Harbor Freight today to confirm if the tool mentioned in the DIY is NLA. A new HF just opened by my house so it's not a huge waste of time to go there.
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #902
      You need to loosen up the motor mounts to get it to sag.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • Sh3rpak!ng
        • Jan 2014
        • 2667
        #903
        What tool is mentioned in the DIY? For the bitch clip? All you need to do is loosent the motor mounts and give enough space to slip a flat screw driver under the tab of the bitch clip and pry it open
        Sent from my SM-G920T using Tapatalk
        Shadetree30
        • 2mAn
          Señior Mod
          • 21050
          #904
          I loosened the motor mounts and still not getting any real movement. Only thing I can think of is the exhaust isn't allowing it to tilt. I'll have to address this solid exhaust when I install the supersprint muffler bit for now I only have a tiny bit of space between the top of the trans and the tunnel.
          Charlie this is the tool mentioned in the DIY.
          Harbor Freight item 96572
          I have a similar tool and small stubby flat heads so I'll switch back and forth until I get frustrated and need a break lol
          Edit: also just occurred to me that being a G260 with the 24v the trans is twisted a little more making it harder to get to. Back to the grind...
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • s14brent
            • Mar 2014
            • 573
            #905
            amazon has quite a few selection of those offered with prime shipping.
            here is an otc version for under $10
            https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
            89 325i 4dr s52
            02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
            21' Toyota Tacoma TRD OR 4x4 6 speed Manual
            • 2mAn
              Señior Mod
              • 21050
              #906
              Thanks Brent but I actually already went and got one from pep boys. $10+tax. It worked perfectly but because i couldn't get any tilt it was wedged against the tunnel and after a selection of tools I got it out
              Then came the time to install the shifter, I had to go back and forth between working on the car and watching the warriors game. Frustration ensued in both battles
              Not sure if this is another first year problem but after getting the first 3 in there was no way to get the other 3 in
              Said fuck it and drilled out the holes and tightened the shifter on.
              Unfortunately the DSSR and shifter aren't working well with each other and now I'm stuck trying to squeeze the DSSR over the shifter . I'm pooped and am going to take the rest of the day off
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • 2mAn
                Señior Mod
                • 21050
                #907
                Finally drove the car with the PMC shifter. It's pretty crazy and totally different from what I'm used to. While I was at it doing race car things I also decided to make the interior more racecar.
                Looks like I'm ready to race at the Porsche Owners Club event at Willow Springs .
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • Metallated
                  • Dec 2016
                  • 1074
                  #908
                  Looks good! Very utilitarian. I know it's not new but I love that euro clock.
                  If you want to go all out race car you can install a couple gauges in the center vents, a buddy of mine did it well and it looks almost factory. I think you can buy pre-made metal plates.
                  • 2mAn
                    Señior Mod
                    • 21050
                    #909
                    Its going to happen, but Im only going to lose one vent in the middle. I'll be installing an Oil Temp and Oil Pressure gauge
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • stonea
                      • 2892
                      #910
                      I really like the Podi gauges. I've always considered picking one up during their black Friday sale, but if I really wanted stealth/OEM gauges I'd probably just bite the bullet and get BavRest to work some magic on my cluster.
                      My Garage
                      Feedback
                      Instagram: Stone.Hopkins
                        • 37833
                        #911
                        That's my car. 2005ish.
                        Grover Beach, California
                        BimmerHeads.com
                        • 2mAn
                          Señior Mod
                          • 21050
                          #912
                          Cool.
                          I was hoping to save post 911 for a story about a little E30 embarrassing 911s at the track but since that won't happen now , I washed the car yesterday. Here's a pic for proof
                          They also told me that I couldn't use #26 and that it needed to be 3 digits so I picked 318 just to represent my M10 car lol
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • thatphysicsguy
                            • Mar 2013
                            • 843
                            #913
                            "318 my a$$" mumbled the salty porsche driver as you passed him.
                            '91 325i
                            • Zekerbox
                              • 221
                              #914
                              damm. looking good. I wish I had a white E30
                              • 2mAn
                                Señior Mod
                                • 21050
                                #915
                                Haha I won't be passing anyone but I hope this is the feeling they have when my lap times are faster than theirs
                                That funny because I wish I didn't have a white one. Artikblau is sexy
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
