E30 cabrio v12
  • e30m3s54turbo
    • Jun 2010
    • 3259
    #76
    Looks Soooo good.
    • Alpina
      • Oct 2004
      • 838
      #77
      Wow! I can't believe there's that much room left in front of the engine
      Originally posted by Vivek
      That was my first thought also. Guess it's not much longer than an m20.
      The lenght of the engine ,, as center of cylinderbore is the same as M20 and M50
      the pistons are 84mm in bore,, but the timing case is bigger etc etc
      I think the M70 is a hidden treasure,, in the E30 Swap world,, compact,, not that heavy ((alu block)) ,,but IMO it must be driven on standalone system,, oem electronic on M70 is awful,,
      thanks for your opinion
      Sveinbjörn Hrafnsson
      E30 CABRIO V12 M70B50 ///
      ALPINA B10 BITURBO 346 @ 507
      E34 550 V12 JML
      Finnish wisdom : If you want to Win,, hire a Finn
      http://alpina.123.is/pictures/
      • Coyote_ar
        • Sep 2009
        • 175
        #78
        i dont think the M70 has an alu block. M73 is the one with the alu block.
        ---E30 320i Hennarot 1984 Sedan---
        • Alpina
          • Oct 2004
          • 838
          #79
          Ok,,, then i must be the lucky owner to have the ONLY ,, Aluminium block of M70
          EVER made !!!!
          E34 550 V12 JML
          • mooseheadm5
            • Apr 2009
            • 375
            #80
            EVER made !!!!
            Nah, I have three of those aluminum M70s. Yours isn't that rare. ;)
            -P
            Moosehead Engineering
            • Alpina
              • Oct 2004
              • 838
              #81
              Well small update,,,
              2 x 6 cyl coilpack
              8.5mm MSD
              I have to get a smaller pulley wheel ,, or a bearing
              and put another pulley/wheel here were the 8mm bolt is,, to get as much touch/grip on the crankwheel
              i had the water pulley remade so i can run 1 belt instead of 2
              lots of oil lines.....
              a) 1 ,,main feed from pump to Accumulator.. pressure
              b) 1 from accumulator to mastercylinder feed,, pressure
              c) 1 from accumulator to steering box,, feed,, pressure
              d) 1 from accumulator to oil carrier,, reverse
              e) 1 from mastercylinder to oil carrier .. reverse
              f) 1 from oil carrier to pump,, reverse,, big one
              g) 1 from oil carrier to steering box,, reverse
              got it ???????
              all lines are high pressure and covered with stainless steel sleeve
              the oil lubrication carrier,, i had to make new lines from flex steel hose,,
              3 fuel lines 2 in 1 and 1 reverse
              i had to modifie the gear stick,, so it would fit correct
              E34 550 V12 JML
              • iceman44
                • Mar 2014
                • 283
                #82
                omg:what:
                Sent from my SCH-I510 using Tapatalk 2
                • Zreberlcoe
                  • 1555
                  #83
                  That is gnarly. Sooo bad ass.
                  1991 325i Calypso Coupe
                  Like Grandfather, Like Father, Like Son
                  BMW
                  • Alpina
                    • Oct 2004
                    • 838
                    #84
                    Small update....
                    I finally found a soulution for a single belt drive ,, to get as much grip on the vibration damper
                    Custom made ,, Guibo end to the gearbox.......... 110mm ((beat that)) made out of solid steel and turned by a lathe
                    overhauled diff ......... 3.46 LSD
                    some kind of strenght frame ......... E30 cabrio.......... ONLY i think
                    clean heatshield
                    the rarest brakefluid expansion tank ,,EVER in Iceland .. E34 540 touring 6g,, 1@499 worldwide made
                    Stainless steel rear muffler,,, designed by my idea,, have the dimension as oem 325 muffler,, got it tigwelded ,, and bended hollow stainless plate for pipe through the muffler
                    I will use 2 x 63 mm stainless pipes for exhaust
                    E34 550 V12 JML
                    • badnerd
                      • May 2008
                      • 65
                      #85
                      ooohhh eeeemmmmm ggeeeee all this v12 awesomeness!!!
                      • 2mAn
                        Señior Mod
                        • 20677
                        #86
                        all I see is Red X's .... stupid work filters
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        -2006 Volkswagen Jetta TDI
                        Make R3V Great Again -2020
                        • e30m3s54turbo
                          • Jun 2010
                          • 3259
                          #87
                          Nice and tight in the engine bay.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #88
                            Looks sweet that bay is full
                            1991 318i 4dr slick top
                            Mtech 2 turbo restoration
                            • JGood
                              • Jan 2004
                              • 7959
                              #89
                              Nice work on that muffler! I've never seen anyone do that. What did you fill it with?
                              Any reason you just didn't go with a dual 2.5 in/out Magnaflow or something? I know you'd have to make your own hangers, but that seems easier then building the muffler from scratch! Either way, impressive work.
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
                              • 2mAn
                                Señior Mod
                                • 20677
                                #90
                                ok, now that Ive seen the pics. Whoa!
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
