Classic Daily E30 325iX S54 Swap
  • fresh_TD
    • Aug 2013
    • 2457
    Originally posted by jakeb
    I do live in Michigan and most iXs around me don't live very happy lives. Where they are driven in the snow and put away for the summers. So they rust rust rust. This car is not from Michigan but not all that far away.
    Yours looks minty. :-)
    Thanks I try to keep it clean, living in FL helps.. Yea I guess living in Michigan the weather will beat up cars if not taken care of.. I can't wait to see how this turns out :-). I'm wanting to swap an S54 in mine at some point.
    Sent from my Samsung Note 3
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • M-technik-3
      • 18946
      Jake
      where do you reside? I am driving over that way this summer to Saginaw. Might swing by if your enroute.
      • jakeb
        • 1909
        Originally posted by M-technik-3
        Jake
        I am in Bay City...about 15 minutes north of Saginaw. More than welcome to come by the shop for a visit. Shoot me a PM or email jake@classicdaily.net
        www.classicdaily.net
        1970 m42 swapped 2002
        1985 LS1/T56 Swapped e28 (557e)
        www.blunttech.com - For all your parts needs
        Follow me on Instagram for constant build updates @classicdaily
        https://www.facebook.com/ClassicDailyLLC
          • 34827
          Yes will be doing the frankenpan. I agree with nando...abuse will kill drivetrains not just power (well within reason). The owner knows he cannot be doing burnouts and clutch drops otherwise stuff will break.
          Yes something will have to happen with the brake booster. More than likly I will go to a GM hydroboost. I've done it on other cars and they work great.
          What's this jute91 spine extension you speak of? I'll have to send him a PM.
          you found it :)
          the only bummer is you have to remove the transfercase or front diff to remove the shaft. however, since it has a grease fitting you don't have to remove the shaft to inspect & grease, so the only time you'd really need to remove it is to do the front diff or drop the transfercase anyway.
          • downforce22
            • Aug 2009
            • 3191
            very nice. Want to see more
            • jute91
              • Nov 2011
              • 581
              I have spoken with Matti several times and he says that with latest horsepower (+800hp) he had broke couple stock front diffs. After he reinforced the front diff ( added 2 extra gears into differential, the pinion broke down... 3.91 ratio isnt the strongest.. but it seems to be the only option here in Finland.. Also in the last time he drove 1/4 mile, the gearbox broke down.. third gear.. it is because the axles are tiny so they start to bend under hard load.. front output shafts he had only broke once by doing donuts and kicking clutch..
              Also found on Facebook - Juuso Tero, Tampere
              https://www.facebook.com/JuusosGarage
              • randomtask37
                • 3154
                Yes. I can't wait to see more.
                That is all.
                98 M3/4/5
                • kid325e
                  • Sep 2007
                  • 6421
                  Subscribed. This is going to be awesome.
                  clutchCTRL!
                  Move with a purpose.
                  - 1991 325iX 4dr/5spd
                  - 2000 323i AT
                  2016 Mazda CX3 Sport AWD
                  • AWDBOB
                    • Aug 2013
                    • 4390
                    Builds like this are not good for my wallet.
                    • F34R
                      sLaughter
                      • 12385
                      Two amazing builds...Jake is really carving out a name for himself!
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                      • stonea
                        • 2892
                        Sub'd
                        My Garage
                        Feedback
                        Instagram: Stone.Hopkins
                        • ngampleh
                          • Jul 2012
                          • 466
                          subscribed
                          [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
                          [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
                          Transaction Feedback
                          • nowak18
                            • Aug 2005
                            • 91
                            Subbed.
                            • jakeb
                              • 1909
                              Pulling stuff apart
                              For the most part the oil pan lines up the the bolts in the mock up m50.
                              Made a locator for the oil pickup.
                              Did a little shop cleaning this afternoon...
                              moving the s54 closer to its new home.
                              The ix oil pan will get combined with an m50 pan. Also will run an m50 oil pump and a combined m50/m20 iX oil pickup.
                              • kid325e
                                • Sep 2007
                                • 6421
                                PLEASE! Take good pictures of when you do the "Frankenpan" I know every one turns out different but there really isn't too many good photos of them being built/completed. I have an M50 Block for mockup and spare iX pans. Been meaning to do it, just on my list of shit that will probably never get done!
                                Thanks for the update, keep it up!
                                clutchCTRL!
                                - 2000 323i AT
