325IX restore and build continued(turbo, e34ix diff, DCT)
  • nomansland92
    • 1657
    #196
    picked up this thing this weekend for 500 bucks, 91 auto ix. has a bad vc but is surprisingly clean, a lot cleaner then my Ix started actually haha.
    I've been planing a bother build for a little while now and I think this may be the candidate I need. of course I'll finish my 88' ix first, I'll be working on it this winter again
    it's going to be awhile till I start it but Im planning on a entire driveline swap, remaining awd but 24v turbo but not from a bmw
    IX being restored here
    Ix turbo build here
    • 2002tiiguy
      • Jul 2013
      • 467
      #197
      Those wheels tho, i dont even know what to say
      Sent from my SM-N920V using Tapatalk
      • nomansland92
        • 1657
        #198
        don't lie you want them on your ix
        Ix turbo build here
        • stonea
          • 2892
          #199
          Originally posted by nomansland92
          It's going to be awhile till I start it but Im planning on a entire driveline swap, remaining awd but 24v turbo but not from a bmw
          I'm actually really excited for this, can we at least get a country of origin for the drivetrain?
          My Garage
          Feedback
          Instagram: Stone.Hopkins
          • driftxsequence
            • Apr 2015
            • 203
            #200
            The trailblazer SS used a similar through oil pan design.
            325IX Build Thread
            RX7 Build Thread
            • nomansland92
              • 1657
              #201
              unfortunately I'm not going to let myself start it until I pay off my truck so that's going to be a few years, unless of course I come across some great deal on parts then maybe I'll cheat a little haha.
              Ix turbo build here
              • 2002tiiguy
                • Jul 2013
                • 467
                #202
                http://www.ebay.com/itm/JDM-NISSAN-S...1XvHvr&vxp=mtr
                you have a tig welder, get to work
                • nomansland92
                  • 1657
                  #203
                  I noticed the car was just starting to lean out in high boost high rpm, the afr was wondering towards 12.0 when my target was 11.2. So I finally got my fuel pressure sensor in. After a quick drive I checked the logs and found pressure to start dropping of above 13psi of boost. Since I'm planning on switching to e85 soon I figured this would be a great time to order new parts
                  Walbro 450 in tank pump and a second tank return. This isn't everything to switch to e85, still need a content sensor and I might switch up the rail and go semi-returnless to manage fuel temp better.
                  Ix turbo build here
                  • ccsdo5
                    • Mar 2013
                    • 707
                    #204
                    It's going to be a JZ engine isn't it. If it's not I'll be sad. But man this thing makes some good power, looking at your thread always makes me wish I kept and turbo'd my IX but it wouldn't be nearly as well done.
                    -Dee
                    5-lugged turbo 318is Barn car
                    IG: @deebelmont
                    • nomansland92
                      • 1657
                      #205
                      Got the fuel pump all in and found my miss fire to be bad coil packs. I believe they were a Chinese knock offs because all 6 showed same resistance with as multimeter and the new ones showed 4x that amount.
                      The local shop had a dyno day so I figured I'd strap it on.
                      It did 429hp and like 423 torque. I really need to make some changes to stop the car from falling on its face over 5k.
                      I'm actually debating selling this s256 and getting a s362sx-e, because I am way over efficiency at 25psi with the 2.8 litter. So if anyone wants a good borg warner s256 with pretty low miles let me know haha.
                      Sent from my SAMSUNG-SM-G891A using Tapatalk
                      Ix turbo build here
                      • nomansland92
                        • 1657
                        #206
                        Some parts arrived today and the ix is getting ready to be torn apart and getting some upgrades.
                        My plan for the winter is to finish the e34 diff swap, build intake manifold, and redo the entire fuel system. Well that's my goal at least but we'll see how it goes.
                        Ix turbo build here
                        • 2002tiiguy
                          • Jul 2013
                          • 467
                          #207
                          this is like turbo plus itb, and its already stupid quick.
                          • nomansland92
                            • 1657
                            #208
                            Unfortunately no itb's just a short runner manifold.
                            Ix turbo build here
                            • downforce22
                              • Aug 2009
                              • 3192
                              #209
                              Interested to see your intake design, there has been some talk recently about the factory intake manifold and its drawbacks. That's on an n/a car though. I forgot about your build, looks like you have got it ironed out well, 2.8L m20 with 8.5:1 CR and 17 psi making 400 hp on pump gas and you haven't blown the diff. nice!!
                              Maybe I shouldn't have gone with such a high CR, I'm at 9.5:1 in my 3.1L turbo, but I also think i'm getting boost creep at the moment and my map sensor only goes to 121 kpa.
                              What are you going to do with those sick wheels on the second ix?
                              • 2002tiiguy
                                • Jul 2013
                                • 467
                                #210
                                shhhhhhh, dont say anything about the front diff, it might hear you and blow up just on the principle.
