Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • 2mAn
    Señior Mod
    • 20087
    #1636
    Originally posted by Sh3rpak!ng
    I also cut out the sheet disk for the spare tire delete. Prepped and welded it in along with a cross bar for support.​​​​​​​
    ​​​​​​​ Sent from my SM-G960U using Tapatalk
    ​​​​​​​so much room for activities!
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • ForcedFirebird
      • Feb 2007
      • 8300
      #1637
      I think you may be confusing my usage for it. Were you thinking I was straight up tapping the OE front spindle sleeve? I needed to chase threads in the front spindle coilover sleeves (that were welded on) after I unscrewed the shock cartridge and had some galled threads due to a bit of rust. I am runnign megan coilovers, and the front shock cartridge is 100% an M50x1.5 thread. Otherwise this wouldn't have worked :D
      Yup, exactly. Now it makes sense how you already ran the tap through. ;) When doing the GC style coils, I just run the tap in and cut the top off to avoid a butt weld on the strut tube.
      john@m20guru.com
      Links:
      • Sh3rpak!ng
        • Jan 2014
        • 2667
        #1638
        Painted the double ear diff mount and spare tire delete. Upgraded my workbench with a 1/4" steel top (made it +3" larger in each direction to squeeze a bit more surface out of it). Realized I had 5 different cans of underbody spray, so I did a test to compare them all. Started fussing with the trailing arms again... passenger side requires a different style reinforcement to clear the fuel filler hose. I think I'm going to go back to my original idea of modding the TA to accept these slick ground control pivoting height adjusters since I haven't been able to find off the shelf components to convert my rear shocks to true coilover. And truth be told I really dont feel like pulling the rest of the trunk apart to do reinforcements etc etc. Sent from my SM-G960U using Tapatalk
        Shadetree30
        • Digitalwave
          is a poseur
          • 6277
          #1639
          Interested to see how the articulating joints play out. I know our spring location is not ideal, but won't the articulating joints mean you have to use an even shorter spring (that will have less travel and more chance of coil bind)?
          FWIW I haven't had any coil bind with 5" Eibach ERS springs in the rear.
          RISING EDGE
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            #1640
            Yes and no. If I were just to slap it on flat against the existing spring landing, I could use the same spring and have more or less the same travel (actually a bit less since the articulating cone ends up a bit taller than the tallest point of the standard coilover rear adjuster at my current ride height). With my old setup, I noticed marks on the tip of the top nylon spring pad cone indicating that the bottom adjuster had bumped it. I also see marks on the spring between 2-3 coils where they've contacted. What I plan to do is to actually recess the base of the articulating assembly about 1 inch into the trailing arm and then use a 1 inch longer spring. I think that should help me end up with an additional inch or so of travel and give me a bit of leeway to adjust up/down. Probably will end up adjusting up a bit because I'm planning on running a wheel/tire combo thats a bit shorter than current. Hopefully that explanation makes sense...
            Shadetree30
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #1641
              Committed.
              Shadetree30
              • Digitalwave
                is a poseur
                • 6277
                #1642
                dis gonna b gud
                RISING EDGE
                • Sh3rpak!ng
                  • Jan 2014
                  • 2667
                  #1643
                  dis gonna b gud
                  Oh god.... I got the popcorn smiley... trust me I thought the same thing to myself as I was man handling the hole saw
                  Shadetree30
                  • glnr13
                    • 1334
                    #1644
                    solid work charlie. can't wait to see this thing in action again
                    • iansane
                      • 1341
                      #1645
                      I recently hole sawed the trailing arms for airbag brackets on my trailer and was surprised at how much grease there was in there!
                      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                      • 2mAn
                        Señior Mod
                        • 20087
                        #1646
                        I can come over one of these days and give you more bad ideas, while enjoying my popcorn
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #1647
                          thanks glen, me neither. We need to do an "OG supercar sunday drive + neptunes net" soon...
                          Its nasty!! There's like a pound of it sludged in there!
                          You know how much I love to make bad ideas come true to reality.
                          Shadetree30
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            #1648
                            Looking good. Havent yet determined final depth. Ill trim the extra metal off the top/bottom tubes once its welded in place. Sorry for the rotated photos. Sent from my SM-G960U using Tapatalk
                            Shadetree30
                            • Albie325
                              • Jul 2016
                              • 515
                              #1649
                              The more I see from builds like yours and guys that can weld, the more I know I need to just buy a house so I can get a good welding setup and learn to do this type of work. Looks great man
                              '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                              Albie325 Build Thread | Albie325 COTM Jan 2021
                              • rzerob
                                • Jun 2013
                                • 2315
                                #1650
                                Wow Sh3rpak!ng, what a creative idea. Great job.
