Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
Beer fridge. Though it's led to some less productive evenings :P I gotta say though after some minor upgrades and tweaks the blast cabinet is a dream come true. Do you have a big enough compressor?
it was good to see you simon
Ha, figured that. Unfortunately my compressor would be underpowered. I rent a garage at my apartment complex and it runs on 115V, if I have too many things running at the same time (compressor, vacuum, or space heater) I trip the breaker all the time. I bought the biggest I could buy that would run on 115V (30gal/1.5hp). Would need a 220V hookup to get a good enough motor/tank setup, another reason I need to move along a get a house sooner rather than later.Beer fridge. Though it's led to some less productive evenings :P I gotta say though after some minor upgrades and tweaks the blast cabinet is a dream come true. Do you have a big enough compressor?'86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
Albie325 Build Thread | Albie325 COTM Jan 2021Comment
for sure! same to you
I hear ya. In my old "tent garage" I was running everything off of like a 200' extension cord... even at my last place we'd trip the breaker with the old compressor, angle grinder and a fan on. You really do need a 220v compressor. I got lucky that my garage has a sub panel installed in it (for some garage->living space conversion that got abandoned) so I put a 220v breaker and ran some temporary wiring. Funny thing is that I remember buying the old HF compressor ~10 years ago and was beside myself so thrilled to have compressed air and an impact gun.Ha, figured that. Unfortunately my compressor would be underpowered. I rent a garage at my apartment complex and it runs on 115V, if I have too many things running at the same time (compressor, vacuum, or space heater) I trip the breaker all the time. I bought the biggest I could buy that would run on 115V (30gal/1.5hp). Would need a 220V hookup to get a good enough motor/tank setup, another reason I need to move along a get a house sooner rather than later.
In my old rented garage, it actually had no outlets so I used the pullstring light bulb to pull power from. Got one of these lightbulb socket adapters and ran more lighting, stereo, power tools, etc haha
https://www.amazon.com/Adapter-Split...dp/B07Y4RBR4J/
The things we do to get our wrenching in!Simon
Current Cars:
-1966 Lotus Elan
-1986 German Car
-2006 Volkswagen Jetta TDI
Make R3V Great Again -2020Comment
it's a miracle more of us haven't started electrical firesIn my old rented garage, it actually had no outlets so I used the pullstring light bulb to pull power from. Got one of these lightbulb socket adapters and ran more lighting, stereo, power tools, etc haha
Progress.
Replaced my cheap HF tap and die set after nearly destroying one of the swaybar links attempting to thread it with an old beat tap. Apparently they have a lifetime warranty though so I'll still exchange it and use it to chase threads rather than cut them.
Test fitting new flares... these are the clinched classic 90mm (3.5") flares. They're actually an excellent fit and very nice product, just too wide!! I wish they made a 70mm (2.75") but the next size down is 50mm which is about the same as the kamotors flares they're replacing. Good to know there's a flare option that'll accommodate another inch of wheel/tire!
Compared to the old flares
Front view. Looks pretty badass. Oh well. Ordered some cheap ebay china flares to see if they're any better.... this may be an irritating trial and error process.
Prepped the trailing arms for blasting. Did my best to seal off the bearings because I didn't want to take them apart. We'll see how well that works or if they get jacked up with sand in them. I'm sure I'll know pretty quickly.
Perches blasted and painted.
Perch bases blasted and pained.
More parts arrive! Settled on 25mm spacers all around. 23mm was the minimum needed to allow the wheel to clear the front strut. These motorsport hardware pieces are quite nice.
FRSport/swift finally drop shipped the springs - 10kg and 6" length. Same rate as before, just longer, and also 60mm ID. Added benefit that the front and rear springs are now the exact same dimensions, and also identical to my E36. Might be swapping some spare springs around shortly.
Lastly, half of the ground control roll center/bump steer kit arrived. Actually the more important half since I need to remove the control arms to replace the outer ball joint with this special spherical bearing and stud. The adjustable tie rods should arrive soon... had a small delay due to covid and their local heat treat shop.
Here is one of the arms painted and assembly mocked up! Looks fresh! (I installed the AKG TA bushings too).
Next up are the front struts to get blasted and painted (should I do boring black? Yellow? Red?), spacers/mods around the front swaybar to help clear the exhaust, diff case blasted and LSD refresh, some rock guard, final flare decision, rest of the tires mounted, install all the parts, alignment, done!
Sent from my SM-G960U using TapatalkLast edited by Sh3rpak!ng; 07-15-2020, 05:59 AM.Comment
man that's fresh. i've been meaning to upgrade my spring rates, at least the rears...if you want to get rid of the standard length 10k's shoot me a pm!!89 325i 4dr s52
02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
21' Toyota Tacoma TRD OR 4x4 6 speed ManualComment
Thanks! I might be selling them later. First I want to try them out on my E36 since I'm looking to actually lower the rates on that car.Comment
cool, just keep me posted!
Did you have to make new holes/rivnuts to mount up the clinched flares? I bought some 50mm ebay flares, and they are complete utter garbage. (def not 50mm either).
89 325i 4dr s52
Will do. Yes, I will eventually need to mount with new holes/rivnuts. I started with a set of the clinched flares, but the 90mm I bought is too big by about an inch - though quality and fit are great! Then I got 2 sets of cheapo flares off ebay - both with different dimensions and both were not only not matching stated dimensions, they were the exact same china flares... so now I ordered a set of 70mm flares from this russian company called Jumdoo. Got them this past week, and they're perfect! Fit and finish are superb. Seeing if I can pick up another set of fenders to start fresh with.Comment
I looked up that jumdoo company, and I'm going to try to remember this for my 4door because I sold all my KAmotors flares after I ditched my iX and decided not to cut up my iS...
The longer I look at my 4dr, the more I realize I'm not motivated to fix it into a "daily".Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30Comment
yea they lay down nice and flat, are very flexible, and apparently can take some heat to help contour them. Free shipping is nice too (though I paid the express shipping because I couldn't wait a few weeks)I looked up that jumdoo company, and I'm going to try to remember this for my 4door because I sold all my KAmotors flares after I ditched my iX and decided not to cut up my iS...
The longer I look at my 4dr, the more I realize I'm not motivated to fix it into a "daily".Comment
