Let's make an E30 M3! (M3 S14 cabrio clone project)
  • hankolerd
    • Oct 2012
    • 280
    #151
    What crinkle paint did you use for the valve cover? I am tempted to this soon myself, any tips you can give is appreciated!
    Also, I realized I never got back to you on the driver side window motor/regulator, seat belts, and exterior window trim. If you still have any or all the parts I am still interested.
    Keep up the good work!
    Daniel
    1990 M3 - http://www.r3vlimited.com/board/showthread.php?t=376104
    2011 328i Sport Wagon - 6sp Manual, RWD, Sport
    • IronJoe
      • 2275
      #152
      I just used some VHT hi-temp wrinkle black engine paint. Application is pretty simple, I did this ~6 years ago when I first got my M3, it lasted all the way up until the valve cover was damaged in the accident. Pretty simple application, I masked the holes and sprayed it then baked it in the sun for a few hours. After it got tacky, I used a razor blade and scraped off the paint from the lettering and lines. Once it was totally dry and set up I lightly sanded the lines & letters until they were clean.
      Yep I still have parts for you, let's try to get together soon!
      '89 Schwarz E30 M3 Cabriolet Build
      • IronJoe
        • 2275
        #153
        Things are moving along. Received my new(to me) cam box yesterday, it was a great deal easier than having to weld up the original. I'll be checking the tolerances this week and if all goes well, I'll have the motor back together this weekend.
        I got a few items in from various vendors. First, my ground straps were a bit questionable, especially the hood and valve cover strap. I received the S14 ground strap kit from Bavarian Restoration, these are absolutely great and worth the money! I had no idea how bad my alternator ground was until I removed it
        Also I received my injectors back from MEPEH, freshly cleaned, refurbished and painted. I'm thrilled.
        More to come, stay tuned!
        • iwantspeed
          • 3164
          #154
          nice work on that valve cover it came out great
          i got the chance to meet mepeh in person and he took care of my injectors in house
          good guy
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • ArtFoodBMW
            • Feb 2014
            • 765
            #155
            Coming along nicely!
            • Matt-B
              The Waffler
              • 3856
              #156
              Originally posted by flyboyx
              the dash on that m3 cabby is grey. i've never seen that before.
              or tapped logos, but leaving the cluster un taped lol
              Originally posted by IronJoe
              Top-end work is in progress. Hopefully once its done I can at least drive her around the block!
              i read this as an engine rebuild joke lol
              Good progress Joe
              • hankolerd
                • Oct 2012
                • 280
                #157
                How hard was the alternator ground strap? Does the intake manifold have to come off to get to it? I also got the ground kit from BavAuto (and agree it is an awesome kit), but have not done that strap yet as it looked like it was going to be tricky to get to.
                Daniel
                • jhaurimn
                  • Nov 2012
                  • 2224
                  #158
                  It takes maybe 15 minutes to remove the plenum, its definitely worth doing.
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • IronJoe
                    • 2275
                    #159
                    I actually replaced mine without removing the plenum. Having the airbox out of the way was enough, I was able to slip my hand behind the alternator to undo the nut on the back holding the ground strap down.
                    In other news, the cam box is coming home today and we've taken all our measurements to ensure all the caps are within spec. The engine will be all back together soon.
                    Oh, and I picked up the E30 M3 Diablo exhaust from Rogue Engineering. Great price and sound, I'm very excited to hear it rumble.
                    • 2mAn
                      SeƱior Mod
                      • 21017
                      #160
                      Once the engine is put together how quickly are you going to finish it?
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      Make R3V Great Again -2020
                      • IronJoe
                        • 2275
                        #161
                        Made a bit more progress this weekend.
                        Cleaned out the shell, got it bolted to the old vert 4-lug, made it a roller and prepped it for sale. It'll be on eBay in a few weeks, if anyone is seriously interested shoot me a PM.
                        Got the S14 cam box installed, cams in, and timed. What a pain - there are two sets of marks on the S14 camshafts and it turned out I had them lined up with the wrong set of marks. Spent quite a while scratching my head on what I had done wrong - wasn't until I referred to my teardown pics that I saw I had the cams misaligned. Thank goodness for thorough pictures!
                        Also I splurged a bit on some wheels from a forum member. Absolutely unnecessary for the rebuild but they've been on my mind since I first got my M3. Excited!
                        Once I have the motor sealed up I'll start work on replacing the rusty battery tray. Fun.
                        • M3pare
                          • Aug 2009
                          • 93
                          #162
                          Great work so far! PM me if you're ready to sell those Startecs. :)
                          1989 M3 Diamantschwarz/Black Bison (Current)
                          1995 M3 Alpine/M-Cross Grau Slicktop 1 of 16 (Sold)
                          1995 M3 Cosmos/Schwarz RMS Supercharged (Parted)
                          2001 M5 Schwarz II/Silverstone-Black (Parted)
                          1995 M3 Dakargelb/M-Cloth Anthrazit (Sold)
                          1990 325i Sedan Bronzit/Schwarz (Sold)
                          1995 M3 Dakargelb/Schwarz (Sold)
                          • 2mAn
                            SeƱior Mod
                            • 21017
                            #163
                            Specs on the BBS?
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • IronJoe
                              • 2275
                              #164
                              Originally posted by 2mAn
                              Specs on the BBS?
                              They're RS005s front, RS061s rear. They were for sale by a member here. He replaced the barrels from 16x7 in the front to 16x7.5 square. It will be very similar to my current setup.
                              Made a bit more progress in the engine bay. I pulled the power steering pump as it had been weeping fluid a tad bit over time, bought the rebuild kit so I'll be walking through that in this thread for anyone interested in doing theirs. I also found weeping coming from the oil filter housing so I'm going to reseal that while I'm in there.
                              • M-technik-3
                                • 18946
                                #165
                                Are you relocating the battery to the back? New tray is just to mount the coolant overflow bottle correct?
                                Wonder if you swap your BBS lips if you would get a non staggered set up
