Drift Trike Project - any else have one?
  • Poopie
    • 295
    Not sure if this is the correct forum for this kind of stuff. If it gets moved let me know. I usually don't really do build threads. Most of the time I post what i want to do, then a few months later I update the thread that whatever i was building was finished, and it was fun, and now its sold. haha.
    I'll try and update this one. This one is a little different because I'm building it in the basement and my wife as no idea. I feel like I'm pretty incognito here so I can share my progress aside from some of my friends in our group chat.
    It all started in early March when I was at an auction and saw a go kart. Bidding got heated because I think a lot of guys were bidding emotionally because they never got to have one as a kid like myself. Anyway, some poor soul over payed for it and I was sad so I went on craigslist to find one. Then I discovered drift trikes since they are mostly go kart rear ends with bmx front forks.
    There was a couple styles, but I was set on doing a 26x4 fat tire front and a bit stretched out like these.
    Most of the trikes i saw were running the 212cc predator motors. They didn't seem to have the torque i was looking for unless you were running a converter and they didn't rev very high either.
    ColinFurze on youtube built one with a pit bike motor with a semi auto 4 speed trans. but his trike was a smaller with a bmx front end.
    It looked like this
    I decided to build something of a hybrid between the two styles.
    Source parts was pretty easy. They sell a trike axle kit on ebay. I bought a set of used racing wheels and tires on ebay as well. The front end was tricky. It was cheaper to buy a whole bike and chop it up than buying the forks, rim, disk brakes and inner tube and tire.
    This was $200 on amazon and comes with disk brakes.
    Took it for a lap and it was pretty fun. It was shame I had to cut it up. Oh well! no turning back
    I got a Lifan 125 on ebay for $300. Its kick start, but lifan 125s with electric start and semi auto trans is a rare find. I didn't want to be messing with clutches.
    Here is the bars, axel and engine to get an idea for space.
    I wanted the motor so sit forward as much as possible to distribute the weight as well as make the jockey shifter more accessible. This is about as much engineering I did on this build. I have an engineering background so i did measure and stuff, but as far as design, i had an idea in my head and now i'm just winging it.
    here is i bent some DOM tubing to do the frame. I was just getting an idea on the angle since i wanted to go around the cylinder head and clear the spark plug and exhaust. I did not like the how steep the angle of the headset was so I had to go for more stretch. Side note - I only had a tig welder, but i decided since i was tacking so many parts I bought a 140 amp mig off amazon. I own a business so the motor, welder, and bike were purchased with points. This is how I got away with keeping this a secret from my wife so far.
    Something like this
    the rear sprocket interfered with the tube so I had to flare the rear end to make room for the sprocket and brake disk. Where I joined two tubes I machined a pipe to fit the ID to give the joint more strength and plug welded it as well as weld the seam
    Piping was notched using a notcher I bought as a garage sale for 10. I had to machine a new bronze sleeve bearing for it, but over all it does a nice job.
    The headset tube off the bike frame I cut off was was super long and the material was pretty thin. I machined a new one from DOM tubing to accept the bearings and chopped the whole assembly down. Also flipped the bares and headset.
    How it sits now.
    This is like my 5th string of mig welds I've done in my life. I was going to just tack most of the trike and tig all of it. I've found this triike is given me a good opportunity to play with the welder.
    This is the motor mount plate. Gonna install some studs on the motor and maybe order some poly isolators.
    Thats were I am so far.
    To do list
    -foot rest/pegs
    -brake pedal
    -rear disk brake mount
    -machine sprocket adapt for motor.
    -Finish welding
    -fabricate/buy a seat
    -build fuel tank
  • Kershaw
    • 11822
    Haha, very cool project. I've always wanted to build a go kart. Drift trike is an interesting idea.
    AWD > RWD
    • stonea
      • 2892
      I've always wanted to build one of these along with a go kart, but I barely have enough time to change the oil in my car let alone start a project like this.
      My Garage
      Feedback
      Instagram: Stone.Hopkins
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        Awesome Ive wanted to do one of these. Question why is motor in the middle? wont it get a little hot around your legs and what not? Most I see are rear mounted.
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • Kershaw
          • 11822
          Motorcycles have that set up. It seems pretty ok.
          AWD > RWD
          • Poopie
            • 295
            Yes the trikes build with the lawnmower based engines like the 212cc predator are mounted in the rear. This pit bike engine is air cooled so you do need some decent flow. It's also mounted to a trans so making a linkage from the rear to something reachable in the front would suck. This engine is also kick started so I need to be able to twist the throttle too.
            The 212cc predator engines are rated 6.5hp peak. The lifan 125 is rated 11.5 peak hp and revs to like 7k while the predator revs to like 3.5k. They can modded to removed the governor and put a new carb and jets on them. But at that point they would cost more than the pitbike motor I got. Plus mine is geared to hit 60pm lol plus have tons of torque with the gearing. J
            • Northern
              I like cupcakes & sh!tboxes
              • 5283
              My question is how are you going to run the chain to the sprocket without having the seat high?
              Edit: I guess it's pretty obvious that the seat will be higher than the chain lol, and it doesn't look really high.
              Originally posted by priapism
              Originally posted by shameson
              • Poopie
                • 295
                Seat wil be above the motor slightly behind it
                • 86gt635
                  • Jun 2012
                  • 99
                  This look dangerous as F* having a chain spinning pretty fast underneath your leg, added to the natural instability of a 3 wheeled vehicle with sticky tires, intending on just flat out ripping it. Looks super fun. Be sure to wear some "third member" protection having a explosion powered machine in front of your nuts.
                  • Poopie
                    • 295
                    Haha I'll have a sprocket/chain guard. I mean these weren't supposed to be safe to begin with haha
                    Won't be too different from a pit bike I suppose
                    • Poopie
                      • 295
                      Also the rear tires will have pvc sleeves on them so no need for a diff. Just controlled sliding
                      • delamaize
                        • Nov 2013
                        • 1463
                        No sticky tires, they have PVC pipes on them. they are for drifting, Sticky would be Counter-intuitive.
                        Dumpster Fire Pilot
                        • Miuge
                          • Feb 2015
                          • 201
                          We did few motorized drift trikes last year, it was fun for a while.. Later at autumn speeds were reaching 50mph, going sideways with minimal traction, still didn't find it too wild. Would need more grip and more power, then it would be exciting again.. Maybe that's why I'm concentrating on my car build again :nice:
                          Facebook - MRT Engineering
                          eBay - MRT Engineering
                          Instagram - mrtengineering
                          YouTube - miugemrt
                          • iflytii
                            • Jun 2004
                            • 482
                            I've been working on one for too long. Had to move it into the "spare room" from the garage to make room for other projects - I need to finish this...
                            It needs a longer stem, foot rests, seat mount, lower frame gusset, and to hook up throttle/brake cables. I have another drawn up for a 2 seat version as soon as this one is done. :-)
                            I like the 2 tube down tube on yours. I had thought about doing that but the guy who will end up taking possession of this when done wanted it clean with a single tube.
                            • Poopie
                              • 295
                              https://www.youtube.com/watch?v=g6QKqrSVHTI
                              NICE! details on your motor setup?
