M60b40 powered Volvo 240
  • potatomash
    • Nov 2014
    • 203
    #61
    These volvo's and bmw seem to go so well together, cool build man
    T U R B O - M 2 0 - B U I L D
    M U S C C O O
    • FireFight
      • Mar 2012
      • 1367
      #62
      Let's build some coilovers
      Here is the strut assent torn down
      With the spring perch and the hub/brake assembly, it won't fit in my chop saw. So I took tape and wrapped it around and over lapped it, giving me a straight light to follow as best I can
      Next I removed the spring perch
      Next I measured the difference between the Volvo and the Saab strut
      Next I marked the spot and tossed this in the chop saw
      Test fit
      The the A1 racing sleeves I got don't fit with the stock thick paint so I knocked that all down
      I also chamfered the ends where I am welding them together so my welds go deep when I grind them flat
      I tossed the old blown Volvo strut in when I did my tack welds to assure its all straight
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
      80 244gl (m60 prepping).
      • FireFight
        • Mar 2012
        • 1367
        #63
        Lets make a M50 powered Volvo 240
        Next I took the old insert out as its tacked straight and did a full weld all around
        Next clean the surface
        Next see how far down I need to weld the lower threaded sleeve perch
        Fully welded
        Primer
        Black
        Still need to adjust both sides even but we are getting closer
        WTB:m60b40 in PNW
        Zachary Ripley
        85 318i M50B25tu.
        92 525it 5 speed.
        • paynemw
          • Dec 2015
          • 439
          #64
          dude, VERY cool man!
          • Staszek
            • 2533
            #65
            Looking great! Need more side pics!
            • Metallated
              • Dec 2016
              • 1074
              #66
              :up:
              • FireFight
                • Mar 2012
                • 1367
                #67
                Originally posted by Metallated
                :up:
                Thanks guys
                It looks a tad bit funny because the rear still at stock, but right now it's in the air getting a new clutch to keep it on the road while I collect the parts
                That's the only one I have
                Pulling the trans was a nightmare, I'm to use to BMWs, this thing looks to be cast iron, heavy as hell, and upper starter bolt and top bell housing bolts are a huge pain to get to.
                Here is a side by side of my used clutch disc I got to keep the thing in the road compared to the one I pulled out. Factory Volvo,220,000 miles hahah
                WTB:m60b40 in PNW
                Zachary Ripley
                85 318i M50B25tu.
                92 525it 5 speed.
                • jeenyus
                  • Aug 2011
                  • 2064
                  #68
                  great work! making those coilovers is pretty damn cool too! I've always wanted to do that with the IX. where did you sort the sleeves and threaded portions?
                  • FireFight
                    • Mar 2012
                    • 1367
                    #69
                    thanks man! its super easy to build if you have a welder.
                    i have been using A-1 racing parts for coil-overs for many years now, never any issue, and cheap
                    A1 Racing Products carries a large inventory of performance racing products like: A-1 Racing Products, A-1 Performance Plumbing, Simpson Race Products, Longacre Racing, Wilwood Performance Brakes, Kirkey Racing Seats, Bicknell Racing Products, Canton Racing Products, Pro Shocks, Outlaw Disc Brakes, Moroso, Hawk Brake, Performance Friction Brakes, ATL Fuel Cells, Howe Racing, Hypercoil Springs, Suspension Springs, Bilstein Shocks, Bell Racing, Racequip, Winters Performance, and many many more!
                    WTB:m60b40 in PNW
                    Zachary Ripley
                    85 318i M50B25tu.
                    92 525it 5 speed.
                    • jeenyus
                      • Aug 2011
                      • 2064
                      #70
                      http://www.a1racing.com/coil_over_ki...on.aspx?page=2
                      :bow:
                      Thank you!
                      • FireFight
                        • Mar 2012
                        • 1367
                        #71
                        :bow:
                        Thank you!
                        no problem man, and summit has great deals on springs
                        WTB:m60b40 in PNW
                        Zachary Ripley
                        85 318i M50B25tu.
                        92 525it 5 speed.
                        • 2mAn
                          SeƱior Mod
                          • 20857
                          #72
                          M60? When did that change
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          -2006 Volkswagen Jetta TDI
                          Make R3V Great Again -2020
                          • FireFight
                            • Mar 2012
                            • 1367
                            #73
                            Well I was thinking that if I'm going though all the work of building mounts and such, why not go big. Then I found a company in Sweden that makes a custom mount that lets the m60 bolt straight to the Volvo sub-frame, my buddy has a e34 530i 5 speed sitting in his garage, and I was able to get a flywheel and clutch kit from a e34 530i for 150.
                            Things just seem to want to go V8, just keeping an eye out for a 740i at the auctions
                            WTB:m60b40 in PNW
                            Zachary Ripley
                            85 318i M50B25tu.
                            92 525it 5 speed.
                            • FireFight
                              • Mar 2012
                              • 1367
                              #74
                              These are from Sweden, from the info I was able to translate over, with these mounts it clears the brake booster and they don't say anything about needing to modify the oil pan. I have emailed the company that makes them to see if they ship to the states
                              I have been emailing the owner of the company in Sweden and he has told me he will ship them to me for the total price of $300USD.
                              those are getting ordered next week
                              WTB:m60b40 in PNW
                              Zachary Ripley
                              85 318i M50B25tu.
                              92 525it 5 speed.
                              • LateFan
                                • May 2013
                                • 4404
                                #75
                                It's crazy that somebody out there already makes those. Sooo Swedish.
