86 eta 5.0 swap...
  • Elysian
    • 674
    #91
    Went out to work on the heads last night, found that my overhead lighting was all dead The florescent bulbs have been burning out one by one, right to left, since we moved in... The final one went... Pulled it out and there was a big hole in it, it went out with a bang I guess. Upgraded to LED's, but didn't have time to work after I got back.
    • Zanderr
      • Dec 2017
      • 7
      #92
      What do you expect to gain from the head work? You're a lucky guy getting your hands on some gt40p's, I've been in my garage home porting e7's just to gain whatever little flow I can :rofl:
      • Elysian
        • 674
        #93
        I won't be doing any porting on them, just wanted to be able to do 3/8" studs/guides, roller rockers, etc. I'll eventually go aluminum heads, so I'll be able to sell these on to another enthusiast I'm sure. GT40 and GT40P heads are pretty easy to find here in Austin, the junkyard has several V8 Explorers/Mountaineers.
        • Elysian
          • 674
          #94
          Got plenty of work done today. Lapped the valves in on both heads, and installed them. Spring height is good, going very smooth so far.
          The cam parts I need will be here tomorrow, so I'll be finishing up the cam install, then installing the heads. Moving right along now!
          • Elysian
            • 674
            #95
            Confirmed I can use stock length pushrods, so I'll order those now.
            • Elysian
              • 674
              #96
              Hardened push rods and starter index plate ordered.
              • Elysian
                • 674
                #97
                Bell housing and clutch fork just showed up, all that I'm missing now is clutch, flywheel, and driveshaft.
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3425
                  #98
                  What's the ratio on those rockers? Good that you were able to upgrade the studs.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • Elysian
                    • 674
                    #99
                    Using 1.6 for now, that will give me 0.565" lift intake and 0.574" lift exhaust.
                    We've got snow and ice coming in tomorrow, might have the day off. If I do I'll be installing the rest of the guide plates and studs while I wait for my push rods to arrive.
                    • Elysian
                      • 674
                      #100
                      Had the day off work because of freezing rain/sleet/snow, so got the rest of the studs and guide plates installed, and got the rockers ready for when the push rods get here. Decided to work on my valve covers, these were some aluminum covers I got from eBay, they were powdercoated solid black. I went ahead and ran them across my belt sander to take the finish off the fins, gives it a nice classy look. Here they are sitting in place:
                      • AWDBOB
                        hooptie connoisseur
                        • Aug 2013
                        • 4496
                        #101
                        Looking good! If only there were an easy way to get a BMW logo built into the center of the VC lines :p
                        • Elysian
                          • 674
                          #102
                          I thought the same thing
                          My starter index plate shipped yesterday, but still waiting on the push rods to ship... Believe they're shipping directly from Comp Cams...
                          • AWDBOB
                            hooptie connoisseur
                            • Aug 2013
                            • 4496
                            #103
                            Are you keepin a tally of what you're putting into the swap? I'm curious to see how much cheddar it'll be all said and done since 302 stuff is so cheap (and makes great power).
                            Also, what's the brake booster situation you're working on? I see a geo booster but didn't see any plans you had for mounting it.
                            • Elysian
                              • 674
                              #104
                              Haven't done anything car side yet. No, not keeping a tally, need plausible deniability with the wife
                              • varg
                                Florida Turbo Man
                                • May 2014
                                • 3425
                                #105
                                It would be fairly easy to get a circle of the appropriate diameter milled out of the fins so that a roundel could be placed in it.
                                IG @turbovarg
